Question about Epson LX-300 Matrix Printer
Constant beeping I've this Epson Lx300+, and when I switch the paperfeed lever, it starts beeping constantly without stopping. No matter what I do. I've pressed and held the buttons, switched off to restart. Only if you switch the flick to normal A4 paper does it stop, but I need to use the continuous paper setting. Can someone please help me?
  • 75 Answers
Insert the paper first to your paper loader, as per my knoledge it beeps only in roller feeder is empty,make sure your lever selection is corect ,
if not- refer thr manual ,you can find the soluton
it is basically from paper loading problem
all the best
Posted on Mar 06, 2008
  • 3 Answers
The LX300+ models have issues with the wiring harnesses chaffing against the metal chassis. They will often randomly show a paper-out condition as well as beep, etc...
We use the LX300+ models with our products as a logging printer and I frequently have to add a sheath over the wiring in these locations to take care of this issue.
Posted on Mar 28, 2008
Constant beeping when turned
The freewheel lever isn't re-engaged properly. Try moving the lever to "free" then back to "drive" again. The lever moves a small micro-switch.
Apr 02, 2014 | Electric Mobility Health & Beauty
I cannot print the endless paper
The Epson LX300 has a paper release lever which should be set
; forward for continuous paper printing and
: back for single sheets.
Oct 03, 2011 | Epson LX-300+ II Matrix Printer
LX300+II when switch on all lights are blinking and 5 beep sound and the head move only a little bit..what suppose to be the problem?
Check the printer for dirt inside or any broken levers or gears and clean the printer. It the problem persists take it in for repair.
Aug 08, 2011 | Epson LX-300+ II Matrix Printer
My problem is im using a laptop, in my printing is EPSON LX300, what would do to make it run?
You need extra USB to Parallel device.
If you bought LX300 without USB interface you need this device... The USB port will be attached to your laptop and the Parallel port will attached on your printer parallel interface.
Oct 23, 2009 | Computers & Internet
Won't start - 3 beeps when Start button pushed
CHECK THE FOLLOWING--
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever.
May 31, 2009 | Kenmore Dryers
Epson lx300+ii with serial port to fujitsu pc
use the com1, and use a baud rate like 9600, with 8 and 1 bit stop. dont. be sure that is in ESC/P or IBM as you requiered. if your software use directly the serial port, be sure that the bios set up is properly. i think that the lx300+ have less buffer than lx300+2
and if you use high speed, could loose info.
Jan 28, 2008 | Epson LX-300+ II Matrix Printer
Beeping Epson lx300
The scanner rail (silver round bar running width if printer that head with ribbon runs on) can get dry making head stop, lube with light machine oil.
Canalso be from a faulty ribbon, the ribbon is driven when head moves and if riibon gets stuck head stops toooooo, remove ribbon and ensure you can turn it by hand easierly, replace ribbon...
Nov 11, 2007 | Epson LX-300 Matrix Printer
Printer not Print data in English Language
Hi, you may want to reset/restore the Epson LX300 to default settings. This can be done by pressing down on the FONT button while powering on the printer. If done right the LX300 will print a test page with the firmware version. It is also possible that the drivers are corrupted. In Start, Printers & Faxes, delete the LX300 printer, restart your PC and then re-install via Add Printer. In some cases, defective parallel cable can also cause problems. Unfortunately the only sure way of checking is by replacing the printer/parallel cable with a known good/operation cable. If the printer would really be requiring service, a Service Manual is available at (http://www.eserviceinfo.com/index.php?what=search2&searchstring=DPA-300) Hope this be of some help to you. Good luck and pls post again how things turn up.
May 26, 2007 | Epson LX-300 Matrix Printer
DOT MATRIX PRINTER PROBLEM
Hi, to perform a self-test on an Epson LX300 > start with the power switch off. Press LF/FF (middle switch), without releasing that button, power on the printer. If everything is ok it will print a sel-test page. To do a Hex Dump > start at power off, simultaneously press Font and the LF/FF buttons (left & middle buttons), then power on; to revert the printer to its factory default setting(s) > start in off position, press Font (left) button then power on. (Slightly different with an LX300+) Hope this works out for you. Cheers.
Apr 19, 2007 | Epson LX-300 Matrix Printer
Epson LX-300 Matrix Printer Logo
1,476 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
