It does have a thermic switch, but I don't beleive that's your problem. I guarantee you that the problem is a loose or broken wire.
Take the electrical cover screw(s) off and check the electrical cable connetion to the Iron's hot plate, usually they come loose or break because of the heat. Don't be fooled by the look of a normal looking wire, it may be broken inside. Feel the wires with your fingers, bend it, pull it and look for a bump or soft spot. The best way y to check continuity.
Good Luck
