Question about Vivitar ViviCam 10 Digital Camera
Vivi cam 10 data cable
Two side with usb port
  • 30 Answers
Why dont you just buy a usb adaptor to fix your computer,they sell all can male to female,female to male, etc.
Posted on Mar 06, 2008
Do you have any user manual for front panel usb
http://www.msi.com/product/mb/PM8M-V.html
(MSI PM8M-V H, is version 2.0 )
Hover your mouse cursor on the Download tab.
(Overview / Specification / Download / Support / etc.)
In the drop down list, click on - Manual
Under the subheading - Download, click on the blue -
M7104v1.0.zip
[ This is a Zip file. A Zip file is a file that is compressed, to send easier. The above manual is for the M7104v1.0
It will work for the version 2.0 also.
You need a program to 'Unzip' it. (Decompress)
If WinZip is not working on your computer, go to 7-Zip, and download for free.
If you need guidance in downloading, and unzipping, post back in a Comment ]
There are two USB headers on the motherboard for the Front Panel,
JUSB1 and JUSB2. (Junction USB 1 and Junction USB 2)
Looking along the bottom of the motherboard, FROM the Right going towards the Left;
JFP1 header; (Front Panel main wires)
Header with 4 pins on the Top row, and 5 pins on the Bottom row.
JFP2 header; (Dual color Power On LED, and Speaker)
Header with 4 pins on the Top row, {Speaker}, and 3 pins on the Bottom row.
JUSB2 header.
JUSB1 header.
EACH USB header will support TWO USB ports in the Front Panel.
JUSB1 supports two,
JUSB2 supports two.
For each USB header there are 5 pins across the Top, 4 pins across the Bottom.
The pins are numbered EVEN across the Top, and ODD across the Bottom.
Starting from the LEFT side going across to the RIGHT side;
on the TOP row for JUSB2 and JUSB1;
Pins 2, 4, 6, 8 and 10.
on the BOTTOM row for JUSB1 and JUSB2;
Pins 1, 3, 5, and 7. There is NO pin 9.
A) Pin 2 is VCC
B) Pin 4 is USB1-
C) Pin 6 is USB1+
D) Pin 8 is Ground
E) Pin 10 is USBOC
Pin 10 is N/C -> Not Connected.
It is there, and Pin 9 is not there, to key which way a connector can go on. Only ONE way.
F) Pin 1 is VCC
G) Pin 3 is USB0-
H) Pin 5 is USB0+
I) Pin 7 is Ground
There is NO pin 9.
(The USB technology used is USB 2.0)
http://pinouts.ru/Slots/USB_pinout.shtml
Let's read together,
Under - USB pinout signals;
"USB is a serial bus. It uses 4 shielded wires: two for power (+5v & GND) and two for differential data signals (labeled as D+ and D- in pinout). NRZI (Non Return to Zero Invert) encoding scheme used to send data with a sync field to synchronise the host, and receiver clocks. In USB data cable Data+ and Data- signals are transmitted on a twisted pair. No termination needed. Half-duplex differential signaling helps to combat the effects of electromagnetic noise on longer lines. Contrary to popular belief, D+ and D- operate together; they are not separate simplex connections."
See the USB examples in the link above, where it labels the contact pins?
The MALE connectors are shown on the Left side.
The FEMALE connectors are shown on the Right side.
Your USB ports will be FEMALE, on the Front Panel.
They are also the A style. USB A style. The Top example to the Right.
Just noting the following in case for some reason, the wires coming from those contact pins in the female USB connector, are not color coded correctly;
Even after you have the wires sorted out, as to which contact pins they go to, DOUBLE-check again. Do NOT just go by the color code of the wires.
Why?
You do NOT want to accidentally connect the +5 Volts (VCC), to the Ground!
Explaining further;
You connect the VCC wire, (Red), of the USB port in the Front Panel, to the Ground pin on the USB header on the motherboard.
(Which means the Ground wire of the USB port, (Black), will probably also be connected to the VCC pin, on the USB header of the motherboard)
Zzzzzzap! There goes your front USB ports. Both USB front panel headers on the motherboard, will be DONE!
Make sure!
Going on;
1) VCC or Vcc, goes back relating to Transistor technology.
Just think of it as the Positive, or power wire.
It is.
It is 5 Volts DC.
2) GND is Ground. It's a DC circuit, and you have a Positive, and a Negative, or Ground.
3) USB1-
That is -> Data-
USB0 is for one USB port in the Front Panel.
USB1 is for another USB port in the Front Panel.
[ Each USB header on the motherboard can be connected, to TWO USB ports on the Front Panel.
Therefore for the two JUSB1 and JUSB2, you can connect Four USB ports in the Front Panel ]
Data- on one USB port in the Front Panel, goes to USB0-
Data- on the other USB port in the Front Panel, goes to USB1-
4) Data+
Same thing.
Data+ on one of the USB ports in the Front Panel, goes to USB0+
Data+ on the other USB port in the Front Panel, goes to USB1+
EACH side of JUSB1 and JUSB2, will support one USB port on the Front Panel.
Two sides per JUSB1 and JUSB2 = 4 USB ports on the Front Panel.
For additional questions, or clarification to anything I have stated above, please post in a Comment.
Regards,
joecoolvette
Jul 20, 2012 | MSI Computers & Internet
For some reason the computer cannot find or recognise my camera and keeps saying communication error ?
Ok. there're three possible causes for this. I'll list them and the relevant procedures of resolution by probability of occurrence.
  1. Damaged data cable- (confirmed if the following 2 doesn't fix the problem) if this is the case, you need to get a new cable.
  2. Damaged USB port on computer- Confirm by trying to connect cam to a different port (i.e.- try the rear ports if you were using one on the front) or to a different computer. If this is the case, you need to get a USB expansion card that will give your computer some extra USB ports.
  3. Damage on camera's side (could range from a simple broken port tab to circuit damage) confirm by: connecting a different camera to your computer using the same data cable. If this is the case you will have to take the camera to where you bought it from for repair (remember to check whether you can still claim your warranty.)
Sep 25, 2011 | Canon PowerShot SD750 / IXUS 75 Digital...
Memory car is full--not sure what to do..can you help
your memory card is full you need to copy the data to a computer then delet them from the memory card of your camera. to do that you need to plug the camera via usb cable that cam with the kit when you bought the cam, usualy one side of the cable(smal side) in the camera and the other side(big side) in the computer usb port. you may need to install special drivers for the camera to be identified by your computer, use the disk that cam with the kit.
alterativly, if you have a memory card reader, you can take out the flash car from the cam (consult the cams manual in the kit) and plug it in the card reader, the the card reader in the computer. this way is easier because you dont need to install drivers! and the copy the files to the computer..
gd luck
Jul 14, 2011 | Cameras
Will a usb cable fitting the Vivi Cam 8025 charge the lith battery; I can't locate a port on the camera to plug in a wall charger?
Yes, you can charge the 8025 through the USB port, assuming the computer puts out enough current to do so (not all USB ports do). Or you can take the battery out of the camera, put it into the charger, and plug the charger into a wall outlet.
Dec 04, 2010 | Vivitar ViviCam 8025 Digital Camera
I CAN'T COPY THE DATA FROM CAM TO PC
1.If you have mac Operating System You surely need your driver cd came with your camera.
2.Install your driver software to the computer.
3.You want a Usb Data cable for your particular camera .
4.Then connect your camera with the data cable .
5.And another end to the usb port.
6.Now your camera can detected by the computer.
7.Open your camera partition in the computer.
8.Now you can view the photos taken by the camera.
9.Using the copy and paste (cut&paste) or import photos option to import your photos to the computer.
10.This is the way to import the photos from the camera to computer.
Sep 12, 2010 | Sony Handycam DCR-SR42 Camcorder
What sizw USB cord???
http://www.memoryforless.co.uk/
this website has all usb cables for all cameras
hope it helps
Jul 18, 2009 | Mad Dog Multimedia (MD16XDVD9) DVD±RW...
Where i get the fxd sigmatel 3600 driver to connect mobile and pc
Thanq for your kind information, but i need to connect GPRS from Sigmatel 3600, how can i do this
May 14, 2009 | Cell Phones
How to connect JVC GR-D820E camcorder to PC
Hi, connect the cam and PC using 4 pin firewire cable. Switch on the cam. Open Windows Movie Maker and import the video from device.
Dec 28, 2008 | JVC GR-D370 Mini DV Digital Camcorder
What cord do I use where to upload photos onto computer
The Panasonic Lumix digital camera you bought comes with an USB cable. Try to find the data cable port in the sides of your cam and insert. The other end must also go to your PCs USB port. Even without an installer, the PC will be able to detect your camera as a removable drive. Explore your Camera as a removable drive and extract your desired picture files into your PC of laptop.
Mar 28, 2008 | Cameras
Vivitar ViviCam 10 Digital Camera Logo
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
