Zanussi fl884 door will not open
Door will not open on a zanussi fL 884 wash machine, would the door interlock unit be faulty, The front door pannel has been damaged by owner trying to open door, where could i order interlock and front door pannel and get delivered to ireland, thanks paul.
  • Anonymous Mar 30, 2014
    INTERLOCK ?
Try http://www.partmaster.co.uk/cgi-bin/catalogue.pl?section=10422 For parts they have lots on there and very good service,think they will deliver to ireland as is a U.K company
Posted on Mar 06, 2008
Zanussi washing machine ZWF 14581 error code 43 is showing up. How can I reset the machine so that it works normally?
Zanussi code 43 states 'problem with the door interlock triac', sorry- likely service call ;-0(
Good luck
John C.
Oct 08, 2011 | Zanussi ZWF1430W Front Load Washer
E20 error
There is a problem with the machine interlock system
The interlock for the machine sends an error to the motor control unit if the door lock relay is not closed before a wash. Probable cause is that the door lock unit is faulty. Check if the machine closses the door before it indicates the error
Oct 03, 2010 | Zanussi IZ161W Front Load Washer
Power going to washing machine but wont start
The door (interlock) is likely faulty & needs to be replace.The door probably doesn't lock at all because the (interlock) is not energizing.
May 30, 2010 | Zanussi ZWF1230W Front Load Washer
Zanussi FL884 Washing Machine door lock broken.
More likel that the door latch or handle is broken.
Only way to open door now is to remove the top cover and force the door lock open from inside, you may possibly break the lock by doing this, but there is really no other alternative.
Mar 29, 2010 | Washing Machines
Door not locking and program reverting straight to end
initially i would replaced the door interlock then if no result the control boart could be faulty.
Mar 13, 2009 | Zanussi ZWF1430W Front Load Washer
there is no emergency release.
two ways of opening door.#
break handle off and you can lever door peg with a small screwdriver
or
disconnect from mains
take top off. feel down to the door interlock and feel for the end of the door peg. push this sideways and you can sometimes release the door
Oct 03, 2008 | Zanussi Washing Machines
I have problem E40 on Zanussi zwd 1680 w
E40 is door interlock error, it means that either the door interlock is stuck or faulty, or the wiring from door interlock to main control board are not connected.
Oct 03, 2008 | Zanussi FJS1225W Front Load Washer
Door wont open
Either clip on the door is faulty or its the door interlock in which the door locks into easily replaced by undoing the clip pullling back the door rubber and replacing ..
Dec 23, 2007 | Zanussi FJS1225W Front Load Washer
Washer stopped midcyle-error code do, then FL
The door interlock could be faulty. The only way to open the door if the door interlock is faulty is to remove the top of the machine, after turning it off at the wall and pulling the plug out of the socket, and locate the door interlock from the inside. There should be a metal "slide" which can moved back to release the door catch. The interlock could be warped from getting hot, which will make the slide almost impossible to move. Remove screws holding the interlock from the front panel and from the inside pry the interlock from the catch. Replace interlock.
Oct 21, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
184 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
