Question about SanDisk Sansa e270 MP3 Player
MP3 will not charge
I plug my e270 MP3 into the computer to recharge , but it is not recognised, just reads SanDisk on the screen instead of connected. Never had a problem in the past. Have reinstalled the program using the original CD.
Please help
Daryl
Just reconnect it, sometimes it works, or just change USB or clen the port, dust can get in the way sometimes form a proper connection
Posted on Mar 11, 2008
  • 151 Answers
Change usb cable or clean usb port and connector
Posted on Mar 06, 2008
Can MP4 folders be read by sansa 270? Folders on PC not recognised on Sansa 270... Wow to convert MP4 to Mp3 if necessary?
The simple solution is to use windows media player to add and remove songs to this device. Media player is setup to convert the songs if need be so that this device can play them.
Mar 20, 2011 | SanDisk Sansa e270 MP3 Player
Unable to charge my mp3 player
usually, when you connect the USB to the computer, it will begin charging right then and there.  can you please be more specific?
Sep 21, 2008 | SanDisk Sansa e270 MP3 Player
Sansa e270 freezes when USB cable disconnected
Reformat the whole thing with Rockbox. That's the whole point with buying the Sansa, as far as I understand.
Jul 12, 2008 | SanDisk Sansa e270 MP3 Player
Sansa e270 black screen
I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..I think the reason you are getting that screen is because you have formatted it under my computer...next time you want to format it use the windows media player instead.
Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Apr 05, 2008 | SanDisk Sansa e270 MP3 Player
Stuck on refresh/black screen
I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
Thank you
Computerrep
Mar 22, 2008 | SanDisk Sansa e270 MP3 Player
Wont go past starting screen PLEASE HELP!!!!!
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - Slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Then run the recovery tool. Select format when prompted. FYI, if you are using music from Limewire or other P2P sites, they are to blame. They are usually poorly encoded and cause the device to freak out. Best of Luck.
Sep 14, 2007 | SanDisk Sansa e270 MP3 Player
Cannot charge or copy music onto the sansa e270
You might not have the battery "seated" correctly. Try removing and replacing the battery.
Sep 04, 2007 | SanDisk Sansa e270 MP3 Player
Sandisk Sansa e270 MP3
Are you trying to transfer songs using windows media player?
Aug 22, 2007 | SanDisk Sansa e200 MP3 Player
Sansa Sandisk E270 - Refreash Database
I found that the unit needs to be turned on first then plug it into your usb port.
Dec 20, 2006 | SanDisk Sansa e270 MP3 Player
Sandisk e270 video won't work
Download the latest version of Quicktime
Oct 26, 2006 | SanDisk Sansa e270 MP3 Player
SanDisk Sansa e270 MP3 Player Logo
32 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
