Question about Smeg FAB28
Light bulb in FAB28 Fridge
Could someone explain how I change the light bulb in my FAB28 fridge.
I do not have a manual. Will any bulb do?
  • Anonymous Feb 09, 2009
    Smeg Fab 28
Just squeeze the light cover and it should pop off forwards (ie. away from the fridge side.
Posted on Jul 06, 2008
Here's the bulb (double check your model number):
http://www.smeg-service.co.uk/smegshop/index.php?productID=50653
The manual may be online somewhere - just do a Google search. I'd imagine it's very easy - get a couple of screwdrivers and have a go!
Posted on May 22, 2008
HOW TO CHANGE FRIDGE LIGHT BULB SAMSUNG rl41ecps
I have Samsung American fridge RS21FCNS and need to change light in the fridge
May 23, 2012 | Refrigerators
How do I remove the cover of the light fitting to replace the bulb?
Just squeeze the light cover and it should pop off forwards (ie. away from the fridge side).
Nov 12, 2010 | Smeg FAB28
Replace door switch
Try taking the knob off with a knife, under that there are 2 long screws, another screw is under the light bulb cover.
Nov 05, 2008 | Smeg FAB28
The Fridge is to cold.
yes thermostat in middle section is faulty one
change it
Oct 21, 2008 | Smeg FAB28
Smeg Fridge light
What you need to locate is the door switch mechanism for the fridge. These are normally located towards the top of the door and protrude so that when the door closes the switch is pushed in. To find out if you have a problem with the switch just press it when the door is open and the light should go off. The switch itself can appear in various forms either as a protruding rod or a curved plate which pushes upwards against the door side when it closes. If I could draw in this section it could be better explained. But if you look around the inside of the fridge on the side away from the door hinge then you should find something you can push. Sorry to be this vague. If you do need a replacement switch they are normally quite simple to change depending on where they are located, most are two screws, or just a push in type. Hope this has been of some help.
Jul 04, 2008 | Smeg FAB28
Smeg 50's stle fridge
we had so much frost that the fan couldnt turn to keep freezer cold. we defrosted it and it ran fine. someone left the door not shut all the way and tahats how it got wet and then refroze.
Dec 22, 2007 | Smeg FAB28
Fridge
Sopunds like a gas leak, No gas, fridge gets hot instead of cold
Aug 20, 2007 | Smeg FAB28
SMEG FAB28
This is a known problem with these fridges. The only fox is to replace the fridge.
Jun 16, 2007 | Smeg FAB28
Smeg FAB28 Logo
987 people viewed this question
Top Smeg Refrigerators Experts
John Tripp
John Tripp
Michael Galve
Michael Galve
ashburton
Are you a Smeg Refrigerator Expert? Answer questions, earn points and help others
