Simpson de luxe 823 washing machine
How do you get the old cutof valve out of the washing machine, to install a new one.
We have a top loader.Water is not cutting of as quick as it should.
  • 55 Answers
You usually have to remove the top panel of the washer to get acess to the inlet soleniod valves in back to remove and replace them. However, you can first try to clean the old valves to remove sediment and deposits. This usually works. After you get the valve assembly removed from the machine, take apart one valve and soak parts in vinegar for a few ours. Scrub parts with toothbrush and reassemble. Then do same with other valve. Doing one valve at a time is better so if you forget how parts go back together you can follow other valve. Or just take good notes. When both are reassembled, try with a garden hose to see if valves no longer leak. If they don't you have solved the problem!
Posted on Mar 07, 2008
Simpson Eziset 750 top loader washing machine won't fill with water.
might be the inlet valve has failed or the main controller
Dec 03, 2016 | Simpson Washing Machines
Simpson washing machine ezi650 still wont drain after installing new pump
Why did you change the pump? Had you tested the old pump & made sure it was faulty? You need a multimeter and test the pump, the wiring for breaks and then check that power is actually getting to the pump. No power - No go!! If no power then probably a fualt on control board.
Jun 13, 2016 | Simpson Washing Machines
Simpson eziset 605 wont take in hot water
Hot valve in washing machine required. Part is between $25 & $60 STEP 1: unplug machine STEP 2: undo the 3 Phillips screws on top of machine the fold top console forward STEP 3: Undo hot tap,disconnect 2 wires running to hot valve,remove valve,fit new valve. STEP 4: Refit top console. DONE
Jun 17, 2012 | Washing Machines
GE WWSE5200B Top Load Washer does not drain or spin
Jim, we have same problem with Simpson top loader washing machine.
Our repairer eventually diagnosed it as a problem with the electronics but it can't be fixed. So we have a 3 year old machine with good pump , motor, gearbox etc but need to buy new machine now. Yours might be similar problem. Don't buy a simpson. Sorry, this is just what we've been told.
Jenny
Dec 03, 2011 | GE WWSE5200B Top Load Washer
What causes water to leak from underneath the unit?
Most often the problem is that the rubber rings are too old. The best is to open the machine, put the lid back on top, add the water container, add water. Push the espresso button, and afterwards (when the espresso is finished) open quickly the lid and check the origin of the water. I have a magic de luxe and it turned out that when i replaced the boiler, one of the high pressure tubes were damaged. Other frequently occuring problems are related to old rubber rings. the cost virtually nothing, and are easy to replace!
Cheers,
Andre
Apr 01, 2011 | Saeco Magic De Luxe Espresso Machine
Water is coming out of the steam valve; however the water will not work on the brew function. I have taken all the parts out and washed them and attempted to run vinegar through to clean the pipes. The...
The blockage is at the brew unit, check the tube leading out of the top shower screen, you might have to remove screen and the 2 screws holding the tube leading to the spout, careful not to lose the spring and valve in there.
Aug 30, 2010 | Saeco Vienna De Luxe Espresso Machine
What's the capacity of a Simpson 175 HD washing machine (approx 22 years old). What new top load should i buy? dials or push button?
about 6to7 kg.to b honest the machines i find that last the longest r kleenmaid top loaders,maytag top loader,whirpool top loaders,and miele front loaders, i would try to advoid electronic units.nothing will b as robust as your 175.
Apr 06, 2010 | Washing Machines
Long term storage?
Descale the machine before you store it, that is no problem to store the machine.
/Mirran
Aug 22, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Vienna De Luxe Espresso is leaking water
It can be the steam valve or the boiler that is leaking.
Aug 05, 2008 | Saeco Vienna De Luxe Espresso Machine
Washing Machines Logo
82 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
