I have a alesis pico verb and a wharfedale r-2004 mixer i think iam using the wrong jack plugs i am using ts jacks should i be using trs jacks the same aplies to m cd players which are plugged into the line ins on the mixer they go from rca to a ts jack converter should they be trs aswell
  • spuddys Mar 08, 2008
    thanx 4 gettin in touch im gettin sound and great qaulity but the picoverb has a vocal eliminator effect on it i cant seem to lose any of the vocals from a cd when played is an rca jack just ts if so will putting it into a1/4 inch trs converter make a difference all other effects work but not sure if i am getting full effect
  • 42 Answers
First I need to know if you are getting any sound at all or dead. Are you switching from RCA to 1/4 plug if so just look up the model and it will tell you the proper connectors to use for your circumstance.
Posted on Mar 08, 2008
  • 26 Answers
Make sure you have the right jack before ever plugeing it in you can damage the receptical and short out your amp
My pedal had its phone jack end severed off. I'm trying to replace the jack. The units internal pot has 3 wire connection but the jack only has 2. What wires go where on the jack.
The jack uses three wires because it supports TRS (Tip-Ring-Sleeve) type ¼" jacks as well as standard TS (guitar) jacks.
To best see which wires go to which posts, it's easiest to find a TRS type jack and unscrew the cover to see the configuration.
If you can't find one, keep this general principle in mind:
Typically, the ground wire is black and is soldered to the main body of the connector, and the remaining wires are soldered together as one to the other post.
Feb 17, 2016 | Yamaha FC3 Sustain Pedal (Half damper)
I have a Samick KK1 weighted controller keyboard and I can't get the sustain to work - any ideas?
I would check the input plug on your pedal. Some contollers will be wired for a 1/4" TS jack, some for a TRS jack, and you may have the wrong one.
Feb 17, 2015 | Music
What is the best way to connect a Yamaha MG102c to a Canon Xha1s?
It could be the type of cables you're using. Are they balanced or unbalanced?
The jacks on the end will tell you what type of cable it is.
If the metal jack (plug) has 2 circles, it's a three-conductor plug (TRS or "tip-ring-sleeve"), which means the cable is balanced. It's meant for stereo connections.
If there's only 1 circle, the plug is two-conductor (TS or "tip-sleeve"), meaning the cable is unbalanced. It's meant for mono.
There's a 3rd kind, (TRRS "tip-ring-ring-sleeve). It has 3 circles, which makes it a four-conductor plug. The extra ring is specifically made for microphone connections in 1/8 in. This is the one you would want to use for a cellphone connection, for normal operation.
But because of what you're doing, the connections and cables have to have to be specific, otherwise you'll end up with lots of noise and interference. It's much easier if you have pictures to look at, that way it won't seem so overwhelming.
This should be able to help. If not, just let me know and I'll do what I can to help you figure it out another way.
TS TRS TRRS TRRRS Combating the misconnection epidemic by Allan Tpper...
Oct 09, 2017 | Yamaha Mg102c Stereo Mixer
Connecting compressor and equalizer to pmp5000
Use a two channel INSERT SNAKE. Plug the TRS connector for each channel into the INSERT jack for the mains in the area above the effects unit. Plug the TIP of each channel of the snake into the input of your effects unit and the RING plug into the output of your effects. The snake has ONE TRS connector and TWO TS connectors per channel.
Sep 14, 2012 | Behringer Europower Pmp5000 Powered Mixer...
What is the best way to connect an external EQ or Feedback Destroyer unit to a Behringer PMP3000
Get an "insert snake" which splits each of two TRS plugs into TWO TS plugs.
Plug the TRS ends into the MAIN INSERT jacks and each of the "TIP" plugs at the other end into inpout jacks of the destroyer. Plug the "RING" plugs into the output jacks of the destroyer. You will need a snake with at least two sets of splits. I use a Behringer PROCOM compressor. For those the TRS plugs go into the channel insert jacks and the tips and ring plugs go to the in and out of each channel of the compressor respectively.
Jan 11, 2012 | Behringer Pmp3000 16 Channel Audio Mixer
We have a pmp6000 mixer hooked up to our ep 4000 and b1800 and b2520,it seems we can only hook up the amp to the mixer into either mono's 1 and 2 or the main 2 however not in main 1 with full...
MAKE SURE the cables you plug into 1/4 inch mains are TRS plugs, and not mono cables (TS). The main output 1/4 inch jacks are TRS balanced outputs and if you plug mono (TS) cables that shorts out the ring connector reducing the power by 6 Db. USE ONLY TRS balanced cables for interconnects !!!! Also read my tip on Fixya regarding PMP mixers. If you use 1/4 inch SPEAKER cables or adapters, if you short the SLEEVE of channel A output to ground you can pop the channel A amp. The TIP of channel B is the hot BUT the SLEEVE of channel A is the HOT. The ttip I posted explains why this is and it isn't mention in the Behringer documentation.
Aug 06, 2011 | Behringer EUROPOWER EP4000 4,000-Watt...
I had just recieved a brand new DM6. Upon setup the kick drum didin't seem to be working. I switched the cable going into the kick drum pad with the Tom 3 cable and the pad was responsive. When I...
THERE IS A TINY SWITCH ON THE BACK OF THE MODUELE
THAT MUST BE SET TO PAD , IF IT IS IN THE WRONG POSTION YOU WILL NOT GET ANY SOUND OUT OF YOUR KICK DRUM
Jan 12, 2011 | Alesis DM6 Electronic Drum Set
No sound conning out of speakers from wharfdale mixer
Speakers are working OK otherwise?
Do you get sound from headphone jack?
It's probably some pot control not turned up.
Is MAIN OUT turned up
Are speakers connected to monitor out or main out.?
Is gain for mic turned up?
Is there a MAIN OUT switch (on/off)?
Is there a MUTE control on the board?
Aug 05, 2009 | Wharfedale Force One Main / Stereo Speaker
Connection to Mixer
I am not sure about that brand but on my Roland Speakers, the TRS jack lives inside the XLR. I first missed it. Take an XLR and try to connect. I can't imagine that they would not have XLR especially for studio monitors. Also are your speakers passive or active, that is something that I would seriously at. No amplitude, low signal, no active.
Aug 18, 2007 | M-Audio DX4 Active Studio Monitors (Pair)...
42 people viewed this question
 Grubhead
Grubhead
