Question about ViewSonic VA1703wb Monitor
SCREEN RESOLUTION CHANGES IT SELF
I am unable to set the screen resolution as it is not appearing in display properties, it goes to 1280x768 instead of 1440x900, i did install the drivers and restart the pc, run it in safe mode then run in normal mode but still unable to solve the issue. it happens time to time and some time it fixes automatically.
  • 6 more comments
  • mcdtomm Mar 21, 2008
    I don't have a solution, but I have the exact same problem, but my monitor is a Viewsonic VA1916W. It fixes itself and then the same problem returns. Been trhough all the so called cures for the problem, but no results. Would like to know if anyone has come up with a solution for this problem. Could it be the monitor is defective?
  • Anonymous Apr 09, 2008
    I have the same problem.
  • Anonymous May 27, 2008
    I found an easy and effective solution: When the screen goes out of resolution, simply turn off the computer power surge protector, then reboot. Works every time
    What does not work is trying to get help from View Sonic. They dont write back and I cant get them on the phone. Sorry I bought View Sonic and will never do it again.
  • gabrielagull Jul 19, 2008
    I´d the same problem the resolution changes it self and then I don´t have the option to change it back to 1440x900. What it worked for me was to plug my old monitor start windows and shut it down. Then I plug again the viewsonic monitor and "magically" the resolution was available again. I don´t understand why this happens but it worked.
  • stottc Sep 05, 2008
    i have a va1703wba and a laptop with 945 chipset.
    I am also a microsoft engineer and i cant get it work for me either.
    I have even edited the registry to force that resolution to appear but it still dissapears. It seems to happen only if i switch the screen off but leave it plugged into the laptop and then just close the lid of laptop making it "sleep"
    then "wake" the laptop without switching the screen on 1st.
    You can be rest assured i have tried every version of the 945 driver and nearly every generic driver that supports 1440x900. This is a Vista problem. It does not happen on my xp virtual environment but anyway. thanks for the cool space to vent a little.
  • Anonymous Mar 21, 2009
    "I found an easy and effective solution: When the screen goes out of
    reboot" this really worked for me....but this repeatedly will k--f hard drives and installation.....probably it has some thing to do with bios setting on our PC or some tiny memory chip on monitor it self.
  • Anonymous Mar 29, 2009
    1360x768
  • Ashton Sep 04, 2013
    Same here .. with va1703wb .. I face the same issue ... kinda bugs me when it happens automatically
  • 40 Answers
Check out for the latest update of display driver .
also refer to user manuals of your monitor/display adaptor/ motherboard { may be a compatablty issue with the os}
and make sure that your pc is free of viruses
Posted on Mar 10, 2008
How do i make the screen smaller
Make the resolution higher under the Display. Right Click on any open area on your desktop and select Properties. When the Display Properties window opens select the Settings tab. Change the resolution. The higher the resolution, the smaller the icons and the more things will appear on the screen.
You can also get to the display by clicking Start/Control Panel and look for Display or Appearance and Personalization. When the Display Properties window opens select the Settings tab. Change the resolution. The higher the resolution, the smaller the icons and the more things will appear on the screen.
May 01, 2012 | Acer Computers & Internet
Screen Resolutions My resolutions changed to very small, when I clicked on the monitor.
Your operating system?
For Windows XP,
  • Right click in an open area on the desktop.
  • On the window that opens select properties.This opens the Display Properties window.
  • Click on settings.
  • On the screen resolution option,set to around 800x600 pixels.
  • Click O.K to save.
For Windows 7,
  • Click on the start button.
  • Click on the control panel and under Appearance and Personalization,select Adjust screen resolution.
  • On the list next to Resolution,move the slider to the resolution you want.e.g 800x600 pixels.
  • Click on keep to save the changes.
For Windows Vista,
  • Click on start button.
  • Click on the control panel and then on Appearance and Personalization.
  • Click on Personalization and then on Display settings.
  • Under Resolution,select the resolution you want.
  • Click Apply to save the changes.
Hope this helps.Thanks!
Please rate this answer.
Oct 28, 2011 | Computers & Internet
How do I increase screen resolution in PC mode running Windows XP Pro?
To change your monitor's resolution
1. Right-click the desktop, and then click Properties.
2. In the Display Properties dialog box, click the Settings tab.
3. Drag the Screen resolution slider to the left to decrease the resolution of your monitor, making text and pictures appear larger. Or drag the Screen resolution slider to the right to increase your monitor's resolution, making text and pictures appear smaller.
4. Click Apply to have the new resolution take effect.
5. If the Monitor Settings dialog box appears, look at your display. If you like the new resolution, click Yes. If you do not like the resolution, click No, and return to step 3 to try a different resolution.
6. Click OK.
Hope this help.
Mar 21, 2011 | Computers & Internet
The graphics are not normal,they are big.
First try changing the display resolution by going to display properties in control panel. Move the slider to the right. Hit apply.
If this doesn't help you out, it could be a display graphics driver problem. Try going to the support website for the laptop manufacturer and download the drivers for the display adapters.
Dec 08, 2010 | Computers & Internet
I have knocked a button on my laptop the screen has gone small i can not make it bigger i have been into properties but dont know where to go next
Position your Mouse on your Desktop. Just on the background. Right click. Select Properties. Select the 'Settings' Tab. You can select the resolution of "800 x 600" for larger icons or if you want more desktop area move to the right. I am set to "1400 x900"
The other setting you should look for is the Color Quality. Generally this should be largest number. IE 32 bit.
Jan 01, 2010 | E-Machines eMachines Desktop PC
I have samsung syncmaster 740nw how can i increase screen resolution to 1024x768?
you cannot set the resolution to 1024x768 but instead try 1280x720 or if you have graphics card try to set the resolution using its custom resolution by setting 1280x768.
It will surely solve your problem.
-ravi
Dec 31, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Computer screen says imput not supported what do i do?
i believe at boot you should hold f8 for advanced booting options, and then select safe mode, which will start the computer in a lower resolution graphix. from there, set the resolution down on the display. right click on the desktop and select properties or personalize, then look for the display setings for screen resolution. its prolly set to 1680 x 1050, and needs to be set to something around 1280x768 or something: maybe its set to a different aspect ration or just plain different size.
Oct 09, 2009 | E-Machines eMachines Monitor E15T4
I do not know how to change the resolution size on the screen
please go to desktop properties. select setting option and now you can change your computer resulation.
Aug 11, 2009 | Computers & Internet
Laptop display is 1/4" in from the left?
1.
67366-click-properties.jpg 2.
3.
Drag the Screen resolution slider to the left to decrease the resolution of your monitor, making text and pictures appear larger. Or drag the Screen resolution slider to the right to increase your monitor’s resolution, making text and pictures appear smaller.
67366-drag-screen-resolution.jpg 4.
67366-click-apply.jpg 5.
6.
Click OK.
Microsoft Windows XP changes the resolution to the settings you chose.
In the advanced tab you can center the screen
LB
Oct 05, 2008 | Computers & Internet
Unable to have 1280x768 full screen with DVI cable
Use the menu button on the monitor itself to adjust for the screen size in DVI mode.
On your SVGA adapter, go to your display properties (right click on desktop) click ADVANCED and change the refresh rate to fix the first problem mentioned.
Oct 15, 2007 | ViewSonic VG2030wm LCD Monitor
ViewSonic VA1703wb Monitor Logo
204 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
