Problem for PC Desktops
Generic problem for all PC Desktops
Dead Acer L320
I have a dead Acer L320. Tried to start it one morning. The on light on the front comes on and the fan can be heard, the hard drive starts up an the dvd drives spins when a disk is inserted but no output to the monitor and no diagnostics beeps. Unfortunately, I bought this new on ebay 6 months ago, I cannot contact the seller to obtain a dealers invoice and Acer will not honour any warranty even though the manufacture date on the case is 31/5/2007. Any idea what the problem is? Brian
Comments:
Mar 06, 2008
- Thanks for the prompt reply. as it is a desktop, it only plugs into ainexternal monitor. I have tried 2 monitors but no output from the PC.
I am in the UK and Acer says even though the PC is under a year old, they will only honour the warranty if PC is accompanied by a dealer invoice.
Brian
Mar 06, 2008
- Monitor tested and is ok. All internal connectors reseated. Cannot detect and internal speaker but used headphones and no sound. Suspect may be a faulty motherboard or graphics chip. No slots for graphics cards in the tiny PC. Anyone know of a source for replacements motherboards?....Mar 06, 2008
- Thanks for the comments but there are no PCI slots in this PC to fit a graphics card. The graphics chip is a surface mounted component and way past my soldering skills to replace it, even if I could find a source of supply. A replacement motherboard would probably resolve the problem. The CPU would appear to be OK as I would expect no life at all if it was faulty
Same Problem
Mar 06, 2009
-   I have a dead Acer L320. Tried to start it one morning. The on light on the front comes on and the fan can be heard, the hard drive starts up an the dvd drives spins when a disk is inserted but no output to the monitor and no diagnostics beeps. Unfortunately, I bought this new on ebay 6 months ago, I cannot contact the seller to obtain a dealers invoice and Acer will not honour any warranty even though the manufacture date on the case is 31/5/2007. Any idea what the problem is? Brian-   Guest Nov 02, 2008
-   Ditto here two, though JUST after it scraped through the warranty period... No post beeps, no docs and after a strip down and clean out, can't find anything on the web to match against the motherboard model numbers or any of the components... going to be tedious...
-   Guest
Solution #1
posted on Mar 06, 2008
Rank: Wiz
Rating: 84%, 90 votes
have you tried plugging it in to an external monitor?
If this works, you might need a replacement screen
I'm pretty sure Acer are legally obliged to honour your warranty for 12 months, it depends what country you are in though
Comments:
Mar 06, 2008
- Hi, sorry, i thought we were talking about a laptop.
Have you got another graphics card you could try?
Solution #2
posted on Nov 16, 2008
Rank: Apprentice
Rating: 100%, 1 votes
I have the same system acer aspire l320 and had the same problem. They sent an engineer hhhhhh replaced my motherboard This is the only fix to this problm, dontbuyreplacement monitor as u r wasting your money.
Was this helpful?1 person thought this was helpful
Solution #3
Rank: Wiz
Rating: 85%, 128 votes
The first thing to do is make 4 sure that the monitor in not faulty, maybe the comp is booting up well but the small speaker used 4 diagnostic sound is not connetted. i suggest u open the computer and check all the connections make sure they are conneted properly and firmly, even 4 the monitor.
Comments:
Mar 06, 2008
- You need to buy a new PCI graphics cards
Popular Solutions for PC Desktops
E-Machines eMachines Refurbished EMA SYSTEM BOARD MODEL...
1 Solution
Questions and Unsolved Problems for PC Desktops
What is the best NAS for about $300 (+, - $100)? I was looking at...
(More)
What is the best NAS for about $300 (+, - $100)? I was looking at http://www.bhphotovideo.com/c/product/629822-REG/Buffalo_LS_XH2_0TL_2TB_LinkStation_Pro_LS_XHL.html,I need 2 TB of space, about 40 MegaBytesPerSecond, bittorrent, dlna , and web (configuration) access.
Cameras Sharp sharp ar-5316-paint the No. 2 Li* + box I would like to send
Machinery until you...
(More)
Machinery until you return to Dsna coude reset sharp ar-5316
my pendrive is not working properly whenever i double click on it , it shows u want to format it but...
(More)
my pendrive is not working properly whenever i double click on it , it shows u want to format it but when i click yes it is not getting formatted
Using window vist.In window media player I cannot connect the player to the ststion. Before I used...
(More)
Using window vist.In window media player I cannot connect the player to the ststion. Before I used to listen to the station but no more.
built in camera is not working.
