Question about Kitchen Ranges
Smeg gas hob issues.
I have a smeg hob. Only 2 years old.From time to time when its in use and when its not in use, the hob pilot light/spark starts to light. Its that flicking sound with the spark, and only when I turn the big hob on does it stop. I am worried there is a gas leak, but I dont smell any. Also it happens when I am not in the house so could be dangerous.Its just really strange the cooker tries to light itself almost.
please help. thanks a lot g
  • 833 Answers
Ghazwan,
Relax. The problem is in the switch that is activated when you turn the gas on. It has either misaligned or broken. The gas itself is not involved. Generally, raising the top of the burner area will gain access to the switch and valve. Inspect and readjust or replace. Oh, and disconnect the electricity before touching the switch itself.
Posted on Mar 07, 2008
Smeg mod nu.sar93xlpg gas cooktop is 20 years old and in good condition The gas igniter recently has been sparking once every 5 mins. works fine except one spark every 5 minutes,any ideas
probably find that after so long the igniter is starting to fail
call smeg and see if there is a replacement one available
there may be after market units from your local gas shop
Jun 25, 2016 | Smeg Cooktops
Cda gas hob Pilot light not sparking to light hob, can use a match to light burners no problem.
IS THE POWER TO THE HOB ON ?
IF SO IS THE FUSE OK ?
IS THE PLUG WIRED CORRECTLY ?
TRY THESE FIRST, IF NO JOY YOU CAN DOWNLOAD YOUR PRODUCT GUIDE FROM CDA ON LINE
Dec 27, 2013 | CDA 4X4SS Cooktop
SMEG SE435X-1 60CM Electric hob. Keeps tripping fuse
It's possible that one of the burners stay on for a long time, which cause one of the wires to overheat, breaking the connection and touching the body of the unit, please turn the breaker off and check for a loose connection, replace the wiring if you feel confortable doing it yourself or contact a technician.
Jan 06, 2010 | Smeg 23 in. SA435X Electric Cooktop
Smeg gas hob ignition
There is a problem with the board. It has malfunctioned onto an ignition mode. By switching it off, it shows the capacitor is holding chage untill flat.(Hence the continual sparking) Replace it.
Sep 20, 2009 | Cooktops
Rheem water heater pilot light goes out
REPLACING THE SPARK IGNITOR WOULD BE MY FIRST GUESS .
Feb 23, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Installing Smeg Gas Hob PGF75-3 Ultra Low Profile.
yes u can install it at the top of the drawers but check the gas connection before closing the drawers to make sure ther no problem,the inlet gas connection is in rigth side facing to u.
Nov 28, 2008 | Smeg Cooktops
Oven Pilot Light
hi not sure but if your oven is activated like the gas hobs? ie electronic spark? not actual flame pilot thentry this ? turn gas dial to start? or the rq'd temp setting? then push/press the dial inwards whilst you press the ignitor button for hob ? rather like the operation start up of mobile valor gas heaters??
Oct 29, 2008 | Hotpoint RGB524 Gas Kitchen Range
Smeg SE64 Gas cook top
problem with hob is probably water ingress in area of ignition unit - will probably cure itself oven is a completely separate unit from hob. problem with it is that you have to re-set the clock - you have it on automatic. after power outage, oven clock always has to be reset
Apr 04, 2007 | Smeg 23 in. SE64 Gas Cooktop
Kitchen Ranges Logo
548 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
