Pay tv cable
Moved into a rental house recently where the aerial on the roof was connected by a pay tv cable to a box onthe side of the house (which was previously installed by the cable tv company) - this box then had (amongst others) a cable running under the house and into the tv room. I don't want pay tv I just want free to air - can I simply plug into the outlet in the tv room and get free to air through the pay tv cable - or do I have to disconnect the pay tv cable from my antenna and install a new co-axial from the roof antenna to my TV?
    Problem Solver:
  • 13 Answers
You may bypass the box by using a straight connector, find the cable that lead to the TV room and connect it to the cable from the aerial antenna.
Posted on Mar 07, 2008
Moved into new home & it has 3 port Austar connection but no tv aerial connection. How do connect my tv to the Austar wall port without an Austar box
You can't. You either pay Austar for the service, or you put an aerial on your roof and get over air stations and run a cable, or you get another cable or satellite company to hook you up,v or you experiment.
This might help you though
Austar Wall Plate Help Me Understand It
and here
Anyone hooked up their free to air TV through Foxtel wall outlet australia
lots more here
connect my tv to the Austar wall port Google Search
Apr 01, 2018 | Televison & Video
I have a Panasonic tv model TH 42PZ80B; a Panasinic Blu-Ray dvd model DMP-BD50; a sky box (not as yet HD) and a Sony video SLV-SE 830G. I have a Satellite dish and a normal TV aerial. In the loft I have a...
You need to try and isolate the piece of equipment which is causing the problem.
You've already tried the aerial lead direct to the TV and this is OK.
Disconnect all scart leads and try the RF on its own.
Try the Aerial lead to video, then video to TV.
Try aerial direct to Sky box, then to TV.
Try just connecting the RF out from the Sky box to the TV (no aerial input), can you tune into a good channel 68 picture from the Sky box.
Then Try the VCR to the Sky box (no aerial input), see if you can tune into the VCR and Sky channel.
Hope that helps.......
Jul 10, 2008 | Televison & Video
Can't get a picture on our free to air TV set it keeps coming up no signal, we have a picture and sound on foxtel
you may find that the aerial inside your home was disconnected and used to wire up Foxtel in the roof, some technicians do that,
meaning all your Tv Outs on the wall would now be connected to Foxtel now instead of the aerial
if you can gain access to the junction of where all the Cable Coax wiring is in the roof make sure they haven't used the tv aerial cables for Foxtel ....just go check where your Aerial comes in and see it is still connected to the junction and not pulled out and a foxtel is going into it instead of the aerial
Apr 26, 2017 | Televison & Video
No dvb signal on Vierra Panasonic tv
If the tvs share the aerial but only one is working then the wiring of the non functioning socket has shorted. Perhaps the cable you used to connect the second set is damaged,try another. PERHAPS THE AERIAL SOCKET HAS BECOME DAMAGED,THIS ONLY COSTS A FEW PONDS/DOLLARS TO CHANGE. Alternatively it might be the wiring from the roof to the wall socket that is faulty.
First things first, check that the tv is working by connecting it in the other room. If it does work there you will know that theaerial socket in the second room is faulty and can begin testing.
Jun 03, 2015 | Panasonic Televison & Video
No Channels
HI, the first thing to check is that your TV aerial or cable connection is ok. Try removing the connection from the back of the TV and re-seating. If you use an aerial on the roof or in the loft, check the state of it, if it has moved or been damaged in anyway that may be your problem.
Mar 20, 2014 | Sharp Aquos LC42XD1E 42 in. LCD TV
We moved house and when we set the tv up, the set top box kept saying "no signal"
Check you have an aerial connected to the lead you are using.
If the aerial is on the roof, has it got an inline box about 18" from the aerial? If it has it is a mast head amplifier and requires a power supply to work.
Hope that helps.
Nov 15, 2010 | Televison & Video
KEEPS SAYNG NOT PROGRAMMED TO WATCH NORMAL CHANNELS
Do a first time installation, move the TV or bite the bullet and either buy an external aerial or extend the main house aerial cable to reach the TV. assuming your TV has no signal where it is now
May 04, 2009 | LG 42LC2D 42 in. LCD HDTV
Coaxle cable (from aerial on roof to TV or top box)
I believe that you use the same type of connector as in the UK.
If so, this site or this video should help you.
Even if your connector is a slightly different design, the principles are the same.
Hope this helps,
Matt
Mar 05, 2008 | Audio Players & Recorders
Setting up my freeview box- NO CHANNELS FOUND
Hi.
The cable & wireless system is not capable of picking up the digital freeview frequencies.
Idealy you need to put a new aerial on the roof,
If this is not possible try an indoor aerial that you to plug in to the mains electrical supply.
http://dysonmanuals.inc.io/
Chris..
Dec 11, 2007 | Televison & Video
Televison & Video Logo
85 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
