Question about Printronix Line Matrix P5005B Printer
Printout problem I have followed solution #1. I do print test page but the print out is small, i think its setting has a low scale percentage
  • Anonymous Jun 24, 2008
    printing haji
  • slg_protech Jun 24, 2008
    printing haji
I need driver fover for priner p 500
Posted on May 24, 2008
How to increase font size on printer
Cartridge have ink? If so try running a test pattern to see if printer responds.
Jun 13, 2016 | HP OfficeJet 6310 All-in-One Printer...
My hp5150 printer won't print in black ink. When i do a test page it will, but when I go to print a document it prints in red?
while printing the documents go to the printer options and select the gray scale printout
and share the result
Jan 30, 2011 | HP Office Equipment & Supplies
Printed text is very small, not legible and does
Go to to print menu box i.e. press ctrl P. Look for zoom. There you will see "scale to paper size." Here select from the drop down list "no scaling" or "A4" depending your paper size. This shoule correct it.
In case you do not see these on your print menu click "properties" on your printer. In the box that appears look for "scale" and make it 100%. These are the components that control percentage size of original documents printed.
Dec 08, 2009 | HP DeskJet 930c InkJet Printer
Need to change my print size on my C6280 Photosmart All-in-one printer, make it larger
It depends on what you are printing, but generally this needs to be adjusted in the software you are using.
If you print pictures or photos, you have to find an option to scale the printout up, either during printing, or beforehand.
If you print PDF documents, in the Print dialog box there is an option to "fit printer margins" or "auto-adjust to printer size" or something to that effect in every PDF reader application. If however the document is formatted for your paper size it will not be scaled, and if it's formatted for an even bigger sheet size, it will scale down the printout.
If you print documents from Word, there's no easy way to make the printout bigger - you can change the font size to a larger one in the whole text, but chances are, that this will ruin the text formatting.
In Excel there is an option to scale everything by a given percentage, which will automatically tile the table into as many sheets as necessary. and then the area will be printed on as many paper sheets as necessary to get
There's no one solution, unless your printer driver has an option to do a fixed scaling - but this will usually be sensible only for enlarging printouts that occupy a smaller area on paper, and you want them to use the maximum paper area. I'm sorry, but you have to experiment a bit to get the hang of it.
Nov 12, 2009 | HP Office Equipment & Supplies
How to change print size on deskjet 3820 printer
whichever browser you are using print preview it first. does it look the same as the printout?
if so got the the page setup option of the browser
and make the scaling and margin changes from there. you may have to remove any option set to "Shrink to fit" printing
Jul 24, 2009 | Office Equipment & Supplies
Printing too small
Try going to File>page setup and uncheck the shrink to fit setting. You should also be able to preview the printed page in the Print Preview window from your browser and adjust the zoom percentage to modify the scale of the printed page.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 22, 2009 | HP PSC 1410v Printer
When i print a document, part of the print will be perfect, a couple of sentences, and then several sentences you cannot read at all, its too light or part of the letters are missing - for instance on an...
Follow the steps below to perform basic print quality troubleshooting.
1. Check your paper and verify that the all-in-one has clean, white, inkjet-rated or multipurpose paper in it. In many cases copier grade papers or paper specifically for Laser printers should NOT be used. These papers are frequently coated and are not intended for dye-based inks. The paper container should also have a brightness and weight listed on it. Generally speaking, the brighter and heavier the paper, the better the printout will look. HP recommends papers with at least 90 brightness and 75 g/m2 (20 pound) ratings.
2. Verify that the all-in-one is on a firm surface that fully supports its weight and does not move as the all-in-one prints. If the all-in-one is placed on a desk or other surface that is free to move or shake as the all-in-one prints, the printout will not look as good as it should.
3. Refilled or remanufactured print cartridges will often produce inferior results. HP will not support any print problems that result from the use of remanufactured and refilled print cartridges since their quality is not in HP's control. If you are using refilled or remanufactured print cartridges, replace them with a new HP print cartridge.
4. Print a self-test page from the all-in-one to verify that the all-in-one is working correctly. If the self-test prints correctly, go to Step 3. If the page does not print correctly, verify that the ink cartridges have ink in them. Then, unplug the power cord from the all-in-one, wait five seconds, and plug it back in. Contact HP for assistance if a self-test page still will not print. To print a self-test page, follow the step below:
5. Press SETUP (or MENU ) until " Print Report " displays, then press ENTER .
6. Examine the self-test page printed by your all-in-one.
i. If the colors are correct and the text is sharp and clear on the self-test page, the problem is not the all-in-one or the print cartridges. The problem is the print settings, the file being printed, or the program you are printing from. Continue to step 7 below.
ii. If the colors on the demo page are not correct or are missing, review HP document Printed Pages Are Missing One or More Colors but No Error Message Appears (buu02176) (in English).
iii.If the printout is not sharp or clear, skip the remaining steps in this section and review the remaining information in this document.
7. Try printing the document again but try changing the print settings by following these steps:
1. Within the application you are trying to print from, click File and then click Print . This will bring up the print screen.
2. Verify that the correct printer is selected and then click Properties .
3. On the Quality tab, verify that the correct paper type is selected, and then change the Print Quality setting to Best . Verify the settings on the remaining tabs are correct and then click OK .
4. Print the file you were trying to print again.
i. If the problem is corrected, the problem was the print settings. There is no need to continue troubleshooting.
ii.If the problem still exists, try printing on different paper.
8. Print a different file or image. If you have a file that printed well in the past, try printing that file. Low quality originals will not print very well. Screen captures and images from the internet are often at around 75 dpi. These images are at too low of a resolution to print well. If the self-test page looks good but your image does not, even after changing the print settings, the problem may be the original file. Cheers!!
Apr 21, 2009 | HP PSC 2175 All-In-One InkJet Printer
Is my Dell 1700 Laser Printer photoconductor drum truly fried?
The drum collects used toner for apprx. 30,000 pages. After that, the printer recommends that it be changed to prevent used toner from spilling internally into the printer's mechanisms. The whole photoconducter/drum can be replaced. The new part from Dell is apprx. $50.00 US.
http://accessories.us.dell.com/sna/products/Printer_Accessories/productdetail.aspx?c=us&l=en&s=dhs&cs=19&sku=310-8710#Overview
You might have reset the "counter" for the photoconducter. Ever  have a water  fillter with an electronic timer? You replace the filter, then you reset the timer? Perhaps you reset the timer without actually replacing the filter. So to speak. :)
The question you should ask yourself is: would I like to spend $30 - $60 [it's cheaper for refurbished parts- Google it] replacing the drum head on a 7 year old printer, or would I rather invest that in a new printer?
Feb 23, 2009 | Dell 1700n Laser Printer
Can i print the image smaller?
  1. Select the 'Page Setup' tab and under 'Printing Type', select 'Scaled Printing'.
  2. In 'Page Size', select the paper size specified in the application. If you select a size that cannot be selected in your printer, a message will display informing you that the setting has been changed to 'Fit-to-page' printing. Select 'Scaled Printing' again.
  3. In 'Orientation', select the same orientation as specified in the application (either Portrait or Landscape).
  4. In 'Printer Paper Size', select the paper size loaded in the printer. In 'Scaling', the magnification at which the document will print so as to fit exactly on the output paper size will appear as a reference value.
  5. In 'Scaling', specify the percentage. You can select from 20% to 400%.
  6. Click 'OK'.
Mar 19, 2008 | Canon Pixma MP500 All-In-One InkJet...
Small print
Turn off and unplug the printer from its electrical source for several minutes. Turn off the computer. Turn on the printer boot up the computer. Try to print something. Try checking for viruses or spyirus http://www.usa.canon.com/consumer/controller?act=SupportDetailAct&fcategoryid=257&modelid=11993 this is the site for your printer. Scaled printing To enlarge or reduce a printed document by specifying a percentage, select 'Scaled Printing'. You cannot use this setting with borderless printing. 1. Access the printing preferences by opening the printer Properties/ Preferences. For Windows Vista * Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'. * Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears. For Windows XP Home Edition * Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.' * Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears. For Windows XP Professional Edition * Click 'Start' from the bottom left of the Windows screen, and 'Printers and Faxes.' * Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears. For Windows 2000/Me/98 * Click / Select 'Start' from the bottom left of the Windows screen, and 'Settings,' then 'Printers.' * Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears. 2. Select the 'Page Setup' tab and under 'Printing Type', select 'Scaled Printing'. 3. In 'Page Size', select the paper size specified in the application. If you select a size that cannot be selected in your printer, a message will display informing you that the setting has been changed to 'Fit-to-page' printing. Select 'Scaled Printing' again. 4. In 'Orientation', select the same orientation as specified in the application (either Portrait or Landscape). 5. In 'Printer Paper Size', select the paper size loaded in the printer. In 'Scaling', the magnification at which the document will print so as to fit exactly on the output paper size will appear as a reference value. 6. In 'Scaling', specify the percentage. You can select from 20% to 400%. 7. Click 'OK'. Let me know what happens. Good Luck, Tim
Mar 15, 2007 | Canon PIXMA IP5200 InkJet Photo Printer
Printronix Line Matrix P5005B Printer Logo
Top Printronix Office Equipment & Supplies Experts
Chinmay Joshi
Chinmay Joshi
Cliff
Are you a Printronix Office Equipment and Supply Expert? Answer questions, earn points and help others
