Question about Xerox WorkCentre M20i All-In-One Laser Printer
Cannot remove "scanner locked"
Hi, I have a xerox workcentre which I cannot get to print or copy as the scanner seems to be locked and the only message showing is "scanner locked" does someone have a solution to get my printer back up and running.
thanks
christine
  • 2 more comments
  • winger2000 Mar 06, 2008
    thank you for your assistance. this worked great!!!
  • br1ghteyes Aug 22, 2008
    scanner wont scan, says "scanner locked", how do i fix it?
  • bbbisht Mar 08, 2009
    hello i am birendra xerox work centre m20i i am network setting but i given the print thats paper size missmatch error coming in xerox worcentre display.please problem the solve
  • Anonymous May 12, 2009
    My Xerox M20i showing trubleshuting "scanner lock"
    President:
  • 2,072 Answers
What you need to do is look in the area where your copied pages come out, Between the paper tray and the bottom of the scanner.
On the underside of the scanner you will see a green latch, It is the only green item on the underside of the scanner. About 2 inches long and a half inch wide.
Turn off the machine, push that lever in, then, and it may resist some, pull it toward yourself until it snaps fully to the front of the machine.
Normally what happens is people hit it with the top of their hand removine their copies.
You can take a piece of electrical tape or duct tape and put over it to secure it in place.
You can also, remove the seal glass, the piece of glass about 1 inch wide on the left side of the scanner. It just has 2 phillips screws in it. This with the machine unplugged, and pop that green latch out and flip it around. There is a tab that will keep it from moving. That latch is for shipping purposes.
Posted on Mar 06, 2008
  • Rick Kasper Mar 06, 2008
    Did that work? There are some other things that can cause that message, but that is the most likely one.
    Let me know please.
    Your welcome.
My workcentre 3550 multifunction printer is constantly printing the configuration report, how do i fix that?
Anthony,
I'll assume your printer is wasting paper.
Firstly remove the paper, that should stop it, then try and enter Centreware, check the www.Xerox.com website as to how to do that. From there you will have more control from there.
Replace the paper as a check, and hopefully the problem will be sorted.
Good Luck.
May 24, 2014 | Xerox Corporation WorkCentre 3550 Laser...
Hi,i have Xerox Pe220,i am not able to copy as paper comes out blank but i can print from computer,i have replaced new cartridge but same result and put back the old cartridge,PLEASE HELP!!
Iffi,
Are you making copies on the glass or ADF? If you are getting blank copies using both the glass and ADF than your CIS(scanner) unit is bad.
Mar 22, 2011 | Xerox WorkCentre PE220
Hi, I have a xerox workcentre which I cannot get to print or copy as the scanner seems to be locked and the only message showing is "scanner locked" does someone have a solution to get my printer...
Look underneath the scanner assembly, you will see a green or orange tab, this is the scan lock. Push it back and forth a few times, it may be stuck. Then reboot your printer.
Hope this helps.
Dec 29, 2010 | Xerox WorkCentre M20i All-In-One Laser...
Scanner locked
Check your green scanner lock which is under the scanner area right in that area where your copies comes out of the machine. This is the most common cause of the "scanner locked" condition. The lock gets accidentally engaged as it is located right where you reach in to get your copies.
If the lock is not the problem then you may have a scanner drive issue.
Good Luck and Thank You for using Fixya.
May 13, 2010 | Xerox WorkCentre M20i All-In-One Laser...
Xerox WorkCentre 4150, 3 vertical white lines in all feeder scans
the problem is in the scanner, open it up and see if you can find any smudges, and clean any obstruction, any ink, liquid eraser residuals, can cause this part to appear as lines on your copied faxed image.
dont concentrate on the printer this is a scanner problem
Jul 28, 2009 | Xerox WorkCentre 4150/X Laser Printer
Xerox WorkCentre M15i squeals when printing and copying.
Do not only lubricate metal shafts, but promptly lubricate the "pulleys" on the right and left side.  the will look very similar to a wheek and pulley mechanism.  The squeal happens when one "bar" connects two "wheels" and one side moves faster than the other.
Jan 23, 2009 | Xerox WorkCentre M15i Laser Printer
Copy Problem
Since you cleand the scanner and scans are fine, the other item I seen cause that problem is the power supply.
Jan 07, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Xerox WorkCentre M20i All-In-One Laser Printer Logo
716 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
