Phillips magic 3 fax machine
'refill ink jet' has appeared yet the inkfilm is only half used , it seems to send faxes but the page that prints after for proof does not print .? people due to recieve faxes are not getting them, can you help?
  • 682 Answers
In this situation i advice you to refil ink jet because ink consumption depends on the size of black area in the document and high black area will absorb the ink.
Posted on Mar 07, 2008
  • mai777 May 12, 2011
    you should disable the plug-n-print chipcard and will be out of trouble forever.
PHILIPS magic 3 with PFA331 inkfilm plug'n print
Mine come up with replace ink film when I do this how can I get past?
May 10, 2011 | Philips Office Equipment & Supplies
Tip
Hidden service menu
some faxes, such as Philips primo / magic 3 have hidden service menus.<br /><br />There in menu 97 submenu CARD TEST 1 you can turn off the plug-n-print card such as PFA331. now you can spool back the inkfilm for reuse and sell your unspent chip card at ebay.
on May 11, 2011 | Philips PPF-531 Plain Paper Thermal...
Tip
Disable chipcard check and print forever
to do it, press and hold START 4 sec.
press STOP/START 3x over
enter MENU 97 , scroll (arrow right) to CARD TEST 1
enter 0 (zero) to turn it off.
press OK.
I want to stop my philips magic 5 "replace inkflim from flashing. I'm not able to access my messages or send faxes. I dont have a replacement inkfilm. Thanks
the fax hackers are still researching the method to disable plug-n-print chipcard in magic 5 series. magic 3 series has been solved in hidden service menu.
This means you need to buy a new inkfilm with new chipcard included. sorry.
Apr 04, 2011 | Philips PPF-531 Plain Paper Thermal...
Cannot send and receive fax after refilling PG-40
I own a Cartridge World ink refilling store and I think that the fax not printing is Canon's new approach to kick out refills from their all in one machines. We cannot reset the ink level indicators on these cartridges and if people can no longer print faxes if their ink says it's low, then they can never use refills if they want to use their fax machine. I think it is also a way for Canon to make more money on their ink sales by making consumers buy new ink before theirs runs out. As far as I know there is no way to fix this problem.
Feb 10, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Using MagicJack for faxing; however, Brother MFC 290C is stating poor line condition - why? Also say's low ink Magenta - would that create this problem?
I had the same problem trying to send out faxes out using my Brother MFC 7340. I use a magic jack phone line. Page 106 of the user manual says if sending via VOIP phone line, you should press menu, then 2, 0, 1 to select "Basic (for VOIP) mode. Then press ok. Then press stop/exit. This cuts the modem speed down to 9600 bps and turns ECM off. Then retry to send the fax. I did that and can now send and receive faxes.
Jun 06, 2009 | Brother MFC 420CN All-In-One InkJet...
How to replace inkfilm in magic 5 primo fax
HI it will tell you how to replace the ink film if you buy a new one, it has instructions on the box.
Feb 25, 2009 | Philips Magic5 Voice DECT Duo - Fax /...
CHECK CARTRIDGE
when trying to copy or receive a fax machine will flash printer error and send out blank page i replaced the ink cartridge and blue air tho it but nothing seems to help
Oct 03, 2008 | Sharp INKJET FAX UX-A1000
Cant receive faxes
First make sure your line cable is plugged into the correct place. Most Brother machines have a plug for Line and a plug for Extension (EXT), make sure it's plugged into "Line".
Go into the menu on your Brother machine and select Fax, then Setup Receive and then select Easy Receive. This will usually solve most recieve problems.
Brother machines come with s default of 4 rings before they will answer, make sure none of your other devices (such as an answering machine) are set to a lower number of rings or the fax machine will never grab the line.
If you have distinctive ring, make sure you have it set up in the machine. There is a section in the owners manual for setting up discinctive ring.
If the machine grabs the line and goes through the motions but nothing comes out on the page (no black print) then make sure you are using a Brother ink cartridge (not refilled or generic) and print out the test page using the "ink" button. Allow the machine to clean a few times and see if the test page prints out correctly. If you are using refills or a generic black, you might have premanently damaged the print head. In this case take it to a service centre to have the head tested.
Sep 10, 2008 | Brother IntelliFAX 4100 Laser Fax
163 people viewed this question
jasbo
jasbo
