Question about Sony MBX-49 ASSY Motherboard
Sony Viao, won't power up
Had my charger plugged into laptop was working fine, next night tried to power up laptop nothing. There isn't even a LED showing on the laptop that the charger is plug in nothing. Have checked power from charger and thats ok.
HELP! my sony viao made a little "click" sound and just died on me. What can this be? It's been having battery issues for a while now, and I have been charging it constantly. There is not light showing at all! not even the battery symbol. The adapter is showing a green light. can someone tell me if this is fixable and how much?
Thanks
Sam
Posted on Aug 26, 2009
-lju nv
Posted on Mar 09, 2008
  • 26 Answers
First you need to insure your power supply is putting out the required voltage. that will be the least of your problem. your plug on your mother boiard could be damaged and not delivering voltage to the battery. in that case you will need a new mother board.if you have ever picked up your laptop without unplugging it and pulled aganst the plug socket you can cause damage to the socket resulting in poor battery charge resulting in the failure your experiencing
Posted on Mar 08, 2008
  • 95 Answers
Laptop motherboard power pin, broken solder connections. Quite common on all laptops. Can be bought from ebay for cheap, if you are mechanically inclined and can solder you should be able to repair it yourself, if not need to find someone who is good at electonics and have them repair it for you.
Posted on Mar 29, 2008
  • 75 Answers
If you do this (you remove your Laptop main battery and adaptor for aprox 10 min then fix again battery and adaptor then on power button m/c is on.)
if thers no function maybe theres a problem in the inside Motherboard of your laptop, try to open inside and trace the supply circuit division chek the fuse.
Posted on Mar 07, 2008
    Master:
  • 351 Answers
Sir,
My Motorola electrify won't turn on or charge. It
maybe your battery or your phone os .... try a new battery if nothing happens... try re flash your phone
Jun 02, 2013 | Cell Phones
Nikon s6300 won't turn on
Coolpix Cameras are tricky to use with chargers. I will assume your USB Charger EH-69P is 100 - 240V 50/60 Hz so it CAN work in many places around the world with an adapter. Do not go over 240V or you could damage it.
These cameras like to have the power supply connected when it is on to charge - meaning if you have it connected and you plug the charger in the wall it will NOT charge. So if you plug the charger in the wall first and then plug the cable in the camera it will work. The camera is actually ON when it charges and I never REMOVE the memory card when it is ON.
When you have a dead battery. Plug the camera in and make sure the ON LED lights and the Charge LED flashes. Then don't mess with it. Let it charge completely (Charge LED stops flashing and is OFF) and then unplug it. It will turn off. Then later you can turn it on.
May 08, 2017 | Nikon COOLPIX Cameras
HP Compaq Presario CQ60 Won't Charge
Three blinks in a row is the LED code for a memory issue.
Turn the laptop over, remove the panel over the RAM, remove the DIMMs (it will likely have 2 in it), place one in at a time and try powering the system on.
One of the two is likely bad although it is possible (although very unlikely) that both are bad. It should boot up when the good DIMM is in place. Once you have identified the bad one, buy a replacement or possible choose to upgrade the total amount of RAM.
Jan 04, 2013 | Computers & Internet
Won't turn on?
stop leaving it plugged in all night it will over charge ur battery if doin so
Sep 07, 2012 | HEWLETT-PACKARD Computers & Internet
Have not used my Garmin since January 2011. Sitting on shelf. Plugged in to my car charger and would not turn on. Would this mean it needs charged?
After three months, I'm sure the internal battery needs to be charged. But even so, it should work when plugged into the car charger. The first thing you should do is check that the charger cord is connected properly at both ends. Mine has a green LED on the plug. If yours does, make sure that light goes on. Try jiggling the connectors at each end of the power cord. If it still doesn't work, the next thing to try is replacing the power cord. (Maybe you can borrow a power cord from a friend). If the power cord isn't the problem, I'm afraid the problem is in the Garmin itself. Good luck.
Apr 18, 2011 | Garmin nuvi 1490T GPS Receiver
Sony Viao laptop just started shutting itself down while I was working on a word document. Laptop will not stay on more than a minute or two after booting up even if nothing is open. Battery is charged
Disconnect external devices. Remove battery and power cord. Then reposition them again. Be sure battery is locked with the switch at the bottom of the unit. Keep charger connected. If issue continues it may require service.
If you can see VGN-CS on the upper left corner of the lid (your unit's model number) you will need to call Sony as this is a known issue
Mar 26, 2011 | Sony Computers & Internet
My led in the adapter blinks
Its probably Ac adapter fault try different good known adapter if the issue will be the same then its fault of Mother board power circuit.
Jan 01, 2010 | Dell Latitude C640 Notebook
Sony vaio vgn series doesn't turn on no power
You should try another ac adapter.If that does'nt work the power jack where it plugs in may be bad or the power board under the power button is bad.You should try another ac adapter first though.
Aug 04, 2009 | Computers & Internet
Sony VIAO will no longer power on
try running it without the battery in, and only the wall charger plugged in. otherwise it sounds like it is a bad charger or possibly even battery. if this still does not fix it, then it could be that the power converter on the laptop has burned out.
Jun 02, 2008 | Computers & Internet
No power
I think this is not a very big problem check your charger adaptor and try to replace with another one i think it will solve the problem.
Sep 09, 2007 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
Computers & Internet Logo
450 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
