Vulcan cx90 ducted heater
I wish to upgrade my vulcan cx90 heater thermostat (controller )with a honeywell touch pad controller what is the wiring required
  • rajarv Mar 18, 2009
    I suspect my Vulcan ducted heater thermostat unit is not working but was told this unit is no longer available. On enquiry, I was tod that a Honnywell 1319158 was the replacement. When looking at the Honnywell over the counter I could see it was not a diect wire to wire replacement as it had a different pin out arrangement. i could not get a circuit so am stuck as to how to meke the substitution. any help?
  • 86 Answers
240 volt wiring required.
Posted on Mar 17, 2008
  • tinkerler Jun 21, 2011
    I have the same unit.. and I eventually found out it requires a wiring mod on the furnace outside... it is not difficult... but i'd recommend getting someone qualified
    the thermostat basically connects directly to the gas valve. If you google around you'll find that most of the basic old thermostats need to connect up to the "R" and "W" terminals on the thermostat. If you google around for info wiring a gas valve to a thermostat you should be able to work it out. If you can't you shouldn't really be attempting it.
    1 - switch off the power to the heater
    2 - disconnect wire 15 from "TH" terminal on gas valve
    3 - disconnect internal heater wires from "A" and "B" terminals on terminal block, and tape them up
    4 - connect two wires from the terminal block to gas valve. A to TH on gas valve and B to TH/TR on gas valve
    5 - note the colors of A and B wires
    6 - connect the thermostat to the wall, tape up C-F, connect A and B to the "W" and "R" on the thermostat
Honeywell CT3400. New batteries but touch pad has become unresponsive
Turn the furnace power off for 10 minutes (the control wiring up to your thermostat is powered from a transformer in the furnace) & turn it back on. Make sure you have 24 volts to the Red wire on the thermostat.
Nov 21, 2013 | Honeywell Programmable Thermostat Heater
I have a Vulcan Ultra 21E ceiling ducted unit The LED flashing fault is no 8 which is a gas interruption. The unit fan runs, ignition starts full flame and gas flows for about 2 secs then shuts down The...
Just been thru a similar problem with my Climate Technologies Vulcan High Efficiency Ducted Gas heater which in this case is installed under the house. This heater is about 7 years old and I have previously (2 years back) refurbished the controller by replacing the main power supply electrolytic filter capacitors.
I also had a communication problem with the Touch pad Thermostat which in the end required replacing the entire touch pad as one of it's voltage regulators had gone intermittent (Touch pads are available on E-Bay). To operate the heater while the touch pad was out of commission I installed a manual switch between the heat contacts on the heater controller. Closing the switch causes the heater to permanently run if it has no thermostat. Once communication with the touch panel was restored we were able to try and find the intermittent heater fault.
Again I have been getting Fault Code 08 "Gas Interruption" however the heater was lighting OK and then going out after about a minute or so. In the end I found 2 distinct heater faults.
Fault 1 was the flame sensor where the weld between the wire and flame probe rod had broken but it was still touching. This meant it was sensing Flame OK and then later would go open with expansion as the temperature rose. I fixed this by replacing the Flame Probe with a new one sourced from Reece HVAC.
At this point I celebrated thinking it was fixed!
Fault 2 after the flame sensor issue was cleared the fault still persisted but slightly less often.
The heater was cycling 3 times to get going and then locking out, requiring a reset from the touch thermostat or heater controller board. Sometimes the heater would achieve a onging burn for a long period, and other times just locking out after 3 tries.
Careful observation of the flame, through the observation holes after it lit, showed correct flame sensing but as soon as the nominal 65C duct temperature was reached the combustion fan (modulates) throttles back too far and the flame goes out, the flame sensor switches off and gas valve is then closed. The pressure differential across the burner manafold controls the Gas flow rate so if the combustion fan goes too slow the flame goes out due to lack of gas.
On the control board there is a potentiometer marked "MIN GAS RATE" this needs to be tweaked clockwise until the burner remains lit when the nominal 60-65C duct temperature is reached. Don't turn it up too far or the heater may not throttle back enough and end up going out on overheat.
Once a stable flame is achieved when throttled, try the heater in the economy mode which uses a lower recirculating fan speed and check the flame still remains lit. My problem was most obvious in the Econ mode.
Hope this helps someone else - It took me over a year to solve this one. NeilP
Aug 21, 2011 | Heating & Cooling
My Vulcan CX90 ducted heater works fine other than the base of the ducted heating unit is coroded and needs replacing. This the part that the unit sits on which connects to the return air and outlet pipe....
80 Series Burner Base. PART 1318011
Here is the complete listing
www.reece.com.au/new/pdf/products/Reece_Gas_Reference.pdf
The problem is that this part number is not available on net for sale.
May 23, 2010 | Heating & Cooling
Brivis Ducted Heater works Non-stop
When you disconnected the W wire, was the R wire hooked up? If so then you either have a bad tstat or the R and W wires are shorted together.
Jul 23, 2009 | Honeywell Heating & Cooling
Wiring diagram required
Just wondering if you h
Apr 19, 2009 | Washing Machines
Replacing Round Honewell Mercury Thermostat
try to get one that is made for oil heat, the installation is easy only two wires, and the instructions make it easy.
Oct 23, 2008 | Honeywell Electronic Programmable...
Vulcan ducted heating not working
How many wires for the thermostat do you have? If you tell me I can help. The green flashing, instead of red, in my experience, means a thermostat problem.
Feb 24, 2008 | Heating & Cooling
Wiring a Honeywell Deluxe Programmable Thermonstat
did you mark which terminals you removed the wires from on the old stat? If not you will need to look on the furnace and see what letters they are connected to .. then connect to the same on the thermostat.
Feb 11, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
1,648 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
