Question about Compaq Armada E500 Notebook
Unable to boot, I can't installed WIN98
I'am installing WIN98, but my laptop is not reading the installer and there is a message "NTDLR missing". What should I do to fix the problem?
    Problem Solver:
  • 5 Answers
Go to bios go to divese option in bios , and disabale your sata mode
if still not change your Operating system cd .
Posted on Mar 06, 2008
    Brigadier General:
  • 6,966 Answers
NTLDR is NT Loader which indicates that the hard disk originally contains an NT OS such as Windows XP. The laptop not reading the installer is possibly a CD ROM or CD disc problem. Most (but not all) NT OS would be using an NTFS type of HD format. Windows 98SE would only read and install on a FAT(32).
What perhaps you can do is to remove the HD from the laptop and using an external 2.5 interface to USB connect it to a 2nd PC and re-partition that HD as well as format it to FAT32. You can also make that HD bootable (do a Google) and copy the entire CD installer of Windows 98SE to a folder inside that HD.
Once back to the laptop, it should boot to a C: prompt, go to the folder where the Win98SE installation/setup files are located and run setup.exe.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Windows 7 boot manager missing after buying and loading restore disks from hp
The error befalls when your PC is unable to interact with Windows due to the corrupted Windows installation, or it is trying to boot from a wrongly configured or improperly connected hard drive or flash drive among other external medium...... read more
Aug 31, 2012 | Computers & Internet
Toshiba l20-217 model-2xe 01p00uen ser no.
To repair missing NTLDR orcorrupted system file/s, boot up with the Windows installation CD then - Press R to repair wheninstructed. Press 1 or Enter to repairthe C:\Windows folder. Then type chkdsk /r and then press Enter. The repair process willtake quite a long time.
Jun 03, 2011 | Amstron Toshiba Satellite L20-217 Laptop...
I just installed a formatted samsung sv 2044d. when i try to boot up i get a message saying NTLDR is missing. i put in the windows 98 cd and nothing happens. can you tell me what is happening. ...
The drive you installed is formatted (wiped clean). It has no operating system to boot from... tthat's the NTLDR error.Power off the machine with the Win98 CD in the CD drive. Power up the machine and while the machine is POSTing (starting up showing you what's in it) watch for something saying to hit any key to boot from CD and at that point press any key . The machine should then boot from the Win98 CD and start the install
Dec 18, 2010 | Samsung (SP0411N) 40 GB Hard Drive
Im getting the ntldr is missing message on my acer aspire 3100 that i just bought from a friend. I have no idea on how to fix this
That is the NT Loader in win98 was boot.ini regardless the OS will not continue without it. You can simply place your OS CD in set your boot order in bios to boot from cdrom. Do a manual windows repair. This will re-install the missing boot loader.
Dec 30, 2009 | Acer Aspire 3100 Notebook
Error message NTLDR missing on formatted hard drive
You need to either reinstall windows, or take the hard drive out, hook it up as a spare drive to a working computer and copy NTDLR to the root of the laptop hard drive. It would be much easier to reinstall windows. You can always use the recovery portion of Windows, but if I were you I would just do a format and reinstall. NTDLR is just a startup file for Windows XP, that does not mean your hard drive is gone or anything. Please don't forget to rate!..Thanks
Jul 14, 2009 | Compaq Evo D500 PC Desktop
Computer boots up then shows windows 98 scrren
you may face either harddisk failure, a driver problem or virus infection:
tools: original win98-cd (or a bootable image
version of it), antivir-software on cd!
- please check whether it is possible to boot from win98-cd, with cd-rom support, not from harddisk.
(such option should be availabe after bios-load is over)
if not:
leave the setup process without fully installing
(press F3 button when asked for repair or install option)
in both cases :
type at the dos-prompt:
(command for changing to harddisk, windows-folder, booting windows from harddisk, but without loading all the drivers as usually)
win98 should come up in protected mode or give error messages.
- access cd-drive and execute vir-scan.
- delete and/or repair infected files
- turn down, attempt to reboot from hd
- if still impossible reboot from win98-cd,
run repair of installation and try once again
standard boot
problem solved? if not, take down error messages consult fixya again!
Jun 13, 2009 | Dell XPS M140 Notebook
Fujitsu Siemens Scenic T on windows 2000 Pro SP4
to fix it:
u should boot up with windows 2000 cd
go to repair windows then go recovery console from cd rom
now u'r in dos mode:
if u'r cd rom drive is d: and u'r hard disk is c:
just type this:
c:\copy d:\i386\ntldr
it's ntldr not ntdlr
then type:
u'r pc will restart and everything should work fine.
Hope this Helps. Regards Khushroo
Mar 09, 2009 | Fujitsu Siemens Computers & Internet
Acer Aspire 5610 Laptop
If it had vista installed first then u are sol, unless u use a new hard drive. That is probably why your cam and several other things don't work. The laptop was designed for VISTA.
Oct 17, 2008 | Acer Aspire 5610-4648 Notebook
Ntdlr error messages
If your pc is showing a error before starting windows it means your system is corrupt or damaged. This can be fixed with chkdsk or a repair windows install or a clean windows install.
That is something you cant prevent from showing. It will always come up when there is a problem with the operateing system.
Feb 17, 2008 | Systemax Neotach 3300 Notebook
Missing or corrupt \system32\hal.dll
You didn't need to replace the hard drive if there is a missing NTLDR file, it just means that the boot sector is missing or corrupt. You can fix it by putting in your WinXP CD, and choosing REPAIR.(This is known as the Recovery Console and it's in DOS just to warn you...) Then you can type the following at the dos prompt: fixmbr - Fixes corrupt master boot record fixboot - Fixes corrupt boot sector bootcfg /rebuild - Fixes corrupt or missing boot.ini
Mar 28, 2007 | Western Digital Scorpio WD800UE 80 GB Hard...
Compaq Armada E500 Notebook Logo
146 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
