Question about Dell Inspiron 2200 Notebook
Laptop to Tv
Can I connect my laptop to my TV via my VCR, the VCR has the coloured plug sockets but the TV does not. Laptop has a video out socket, 15 pin.
I have the cable from video out with the three coloured pins at the other end.
  • 9886977340 Mar 20, 2008
    i have an inspiron 2200 and i m unable to connect it to my new sony hd tv which is blue ray disc compaatible...ihave connected the cables they asked me to connect.
    Genius:
  • 3,587 Answers
To make this work, we'll need all the model numbers and connector types. Otherwise, it's a guessing game, no?
Posted on Mar 06, 2008
I have connected my laptop to my element tv via vga cord;sound is comin frm laptop..want the sound frm TV; THEN, I have a headset/microphone ... can I connect my headset/microphone to the TV?
If you need to get sound from your TV, you should have a sound input socket in your TV. If you have that you can connect an audio cable from your sound sound socket to your TV.
The second option is that your laptop and your TV should have HDMI ports. If its there, you can use an HDMI cable(instead of VGA cable)to connect the two. With HDMI cable, you will get both video and audio through that single cable.
If you need more help please let me know
Jul 02, 2017 | VIA Computers & Internet
How do I hook up my dvd/vcr to the tv
On the back of the cinavision you have two groups of sockets. The yellow socket under Video out is picture. Red and white is sound. Connect them to the TV's yellow red white sockets marked Video In 1. This connection will give you picture and sound from either the VCR or the DVD deck.
There's a better picture quality available for DVDs only from the Component video out sockets (green red blue). Next to them is another set of audio sockets (red white). Connect all five sockets to the TV's input number 2. The colours match up. The picture from Component will be clearer and sharper.
On your Sharp TV remote, select Video 1 to watch VCR, and Video 2 to watch DVDs.
Nov 07, 2014 | Sanyo DP39842B 39" 1080p LCD TV...
How to concert laptop to tv
what do you mean by concert, Do you mean connect?
If you do then you will need a 15 pin to 15 pin vga lead. Connect it to the 15 pin socket on the laptop, connect the other end to the tv's 15 pin socket if it has one. Then select PC on the tv's input source menu using the tv remote. Switch on the laptop and it should display on the tv.
May 06, 2012 | LG Computers & Internet
Directions for plugging your 4head hi fi stereo ito your tv
You don't really say what make or model is the TV or VCR. However if you have a TV with a scart socket you can get a scart lead and connect the VCR via that. If the VCR has two scarts connect it via AV1 sometimes black whereas the other might be blue. If the TV has more than one you will have to try each one, unless it says VCR on the scart socket, till you get the best picture.
Dec 09, 2011 | Televison & Video
I've been trying to use s-video cable to connect
At the rear or side of the PC there should be either or both of a 15 Pin DIN Plug, HDMI socket. or a Yellow RCA or 4 -7 pin DIN. Now IF these are present then YES you can connect to a TV. Now some TV's have a connector a DB15 MALE, so that the cable from the PC to the TV, is DB15. this plugs in directly, with appropriate DB15 cable. This, however, will ONLY take the VIDEO to the TV, Audio is delivered via the "Audio Out" Jack on PC, and Plugged into the AV Sockets on the TV, with a dual cored coaxial cable, they are Red & White. Some PC's also have a Yellow RCA Connector, OR a 4 -7 Pin DIN Socket, that requires a Special Adapter Cable (That generally came with the unit, and are colored and marked as to output) to use, for Video/Audio Out to TV. This signal is Composite or SVHS Video & Stereo Out. This connects up TO the TV's Composite/SVHS input Jacks and the Red & White Audio IN, RCA Jacks, &/or DIN SVHS socket.
First you need to know if your PC can output to a TV. Then you need to get the adapter & cables that connect the PC to the TV. Then you need the correct TV drivers installed for your video card. When they are all installed, you need to "Enable" that Monitors, the TV's, Desktop. You need to set either a "Cloned" display or "Spanned, Extended Desktop". Go to "Display Settings" Now ensure the TV/Monitor connected has the correct input/output display settings. Adjust the screens resolution via the resoloution "Slider", it is best to start with, 800x600 32 bit color. or even lower. and once working OK, THEN increase to max resolution, your TV can handle, find out from manual. Once it is all connected up. It should all just work great. Now, from then on, &, to get it to work every-time, the process is. Turn everything OFF. Connect the leads between PC & TV, Turn the TV, ON. Then, startup the PC up. It should "Detect" that it has TWO "Monitors" ie: One Monitor & One TV/Monitor, & you should see your desktop appear after a bit. Now you have screen 1 & screens 2. Now, if you are using "Cloned" mode, then whatever is displayed on the Master monitor, will be displayed on the TV. If you used Spanned, mode, in this mode, however, you will have to."Drag" the Video window, over to the TV, and it is though, you have one "Big Desktop". Now IF using Nvidia or ATI then BOTH of those have thier OWN, Control Panel, this, all then can make it all a lot easier to do it. So I would suggest that this method be used. But if you get stuck, or just want to do it by hand, then the the "By Hand" method is the only way.There is a great program called MultiMon, this allows great control over dual displays, and is well worth installing.
Right, well, IF your TV has a DB15 Female Plug on it then you CAN, connect it up and it will work, as a second "Monitor". OR If the laptop, has a "Composite Video" a Yellow RCA socket, then you can, connect to the TV's Composite IN. & it will be a second monitor. Otherwise you cannot, the VGA signal is NOT compatible with a TV's input. SOME cards have a connector that plugs into the DB15 and to the TV, but they are "Special". In saying that though you can "Micky Mouse" things together and get an output, but it real poor quality, and disappointing results, there are various posts on the net about doing this if you wish.
Remember DRIVERS, you also need the drivers installed & setup correctly in order for the hardware to work. As a tip, When connecting to a TV, always connect like this......First, plug all cables into TV's correct Video input(s). Connect up the Sound, plug all cables into laptop, turn TV ON. NOW, start the laptop, you should now soon see the an image.
NOTE: Some laptops & other devices, have HDMI out, sometimes, the AUDIO is not passed through, the HDMI cable, & the Audio must be run from Audio/Line OUT on laptop to AV IN on TV.Also some laptops have a socket that a multi-way 4/5/6/7 pins. A connector plugs into this, you then can connect to these connections, as you would normally.
Mar 06, 2010 | Acer Aspire 3690-2196 Notebook
How do you turn a mintek tv into a computer monitor?
Connecting this up will be easy. What you do is get a yourself a set of the right, for your setup, cables. That uses EITHER one of the formats, of these described, below. You will need, either, a THREE way Cable, or three separate " Coaxial Cored" Cables with RCA PLUGS on them. ColoredYellow, (Video) Red, & White. (Audio) AV. OR If you have SCARTConnection Sockets, it's a big Black Socket at rear of unit(s), you get aSCART Cable.& It's all inside. Now some units, use a standard calledComponent Video, that uses, a Green, Red, & Blue Plugs. Now, with the Component setup, you will also ,need, Two more Cables, for the AV Audio. these are, Red & White.(So with Component Video there are 5 Cables/Plugs in all). In any event ALL Cables go Color to Color, at each end, plugging into the corresponding Colored RCA Jacks, on either machine, or VCR or TV. Now if you have SCART, then it simply plugs in only one way. It is that simple. So connect up with the leads your set uses, and select the correct "Input" from TV/Remote, it is NOT on a "Channel" it will be on AV, AUX, and Press "Play" on VCR/DVD whatever.... should be all go.
Mar 05, 2010 | Mintek DTV-263 26 in. TV/DVD Combo
How to connect a dvd recorder ( & player ) a VCR & Foxtel to a plasma THP46G10A do you have diagramatic sketch of connections
samsung 42" plasma hooked up to LG vcr/dvd combo and foxtel IQ box. all working but only by plugging vcr cable into video camera sockets on side of plasma tv?? reason only place with a yellow plug socket? on rear of tv colours are only red,green.blue? and white. nothing for the yellow can you give any advice on correct hookup proccedure please.
Dec 18, 2009 | Panasonic Televison & Video
My zenith vcr recorder is recording blank but not my tv show and I don't know why. I have it plugged in to my tv - I have cox cable and a tivo box. My cable box runs ino my tivo and then to my tv. My vcr...
It seems to me that you have only got one set of RCA Cablec between the TV and VCR ( from VCR Video out to TV Video In), as such the VCR only works in playback mode, you need a second set of RCA cables (from TV Video Out to VCR Video In) then select the appropriate input (Video) for the VCR. make sure to follow the colour coding on the RCA plug / socket arrangement
Jun 18, 2009 | Zenith VR4206HF VHS VCR
Labtop to RF TV?
Hi
If you have a SVHS input on the VCR,or the TV, you should be able to get video that way. You will also need to run sound from the h/p out on the laptop, and corresponding audio connection on the TV/Sound System, or you could still use the laptop for sound. Up to you.
Have a quick look for any SVHS input sockets on the back ot he gear and let me know what you find. Cheers
regards
robotek
Nov 19, 2008 | Televison & Video
Can't re patch tv with set top box to watch tv
Hi.
Ok here goes.
1) Take airial lead from the wall socket in to antenna in on freeview box.
2) connect short usually black airial type lead in to antenna out socket on freeview. plug the other end of this lead in to aerial in on vcr.
3) connect the other end of this aerial type lead to airial plug on the back of tv.
4) now if you have 2 or more scart sockets on the back of tv set plug in the scarts in this order.
Freeview box scart with tv on it connect to scart 1 on tv set.
Freeview box vcr scart connect to vcr in scart socket on vcr.
Vcr scart marked tv plug scart from here to scart 2 on tv
If you have 3 scart sockets on tv you can connect dvd using scart to scart socket 3 on tv.
If Tv has only 1 scart the aerial leads will stay the same as I have stated,
Freeview must go to scart socket on tv set.
leave second scart from freeview to vcr plugged in so you can record freeview by putting vcr to line 1 or AV 1.
you will need to put tv on channel (0) & tune this channel to the video play a tape that you recognise then go to tv tuning & tune tv untill you see video playing then store this on channel (0).
DO NOT USE AUTO TUNING IT WILL PUT CHANNELS IN THE WRONG ORDER JUST USE MANUAL TUNING.
Now to view Dvd you will either need to purchase A scart switch box. Or have keep unpluging freeview scart from tv so you can plug in dvd .
If your tv has red yellow white phono sockets you can plug dvd in to these, you may need to purchase phono leads.
Hope this helps.
http://dysonmanuals.llc.nu/
Chris..
Jan 08, 2008 | Televison & Video
Dell Inspiron 2200 Notebook Logo
134 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
