Question about Roper RAS8445KQ Top Load Washer
Water Trickles in When Filling
When I start the wash cycle the water only trickles in. You dont hear the normal wshhhhh like you do when a washer fills. I've cheched the water lines and both are clear of obstuctions. Everything else on the washer seems to work normal.
  • jerasdad Apr 13, 2008
    Thanks for the help guys. I figured out the problem with the screen about a week after I posted.
Check the screens at the water inlet valve on the back of the washer, the small screens inside may be blocked due to calium buidlup from hard water, simply remove the screens and clean them out.
Posted on Apr 12, 2008
  • 185 Answers
Check the sreens in the hot and cold water valves on the machine make sure there not plugged with rust
Posted on Mar 26, 2008
We can hear water running but it's not filling the wash tub. There is no water leaking anywhere.
check that the tap is fully opened , the filter in the end of the hose is not blocked
check that the tap washer is not jammed off in the tap as they can expand and not move up to let water in
check water inlet solenoid is functional
Aug 23, 2015 | Amana DLW330RA Top Load Washer
Machine won't fill up with rinse water, it washes & spins but the water only trickles in the rinse cycle, i ahve been filling it up manually
Turn the water supply off.
Remove the COLD water hose from the rear of the washer.
Clean the silt out of the COLD water valve on the washer.
Re-attach the hose on turn on the water supply.
Jan 21, 2011 | GE WBSR3140DW Top Load Washer
Rinse water barely trickles out of my washer
Do you fill the machine with hot water only?
If so, this is what I suspect. The filters in the inlet hoses on the back of the washer need cleaning. Remove the garden hose connectors, remove filter, clean, replace.
When filling with hot only you get a lot of pressure thru one hose. When you rinse, the best you can do pressure-wise is cold rinse -- but the cold water filter is going to be more clogged than the hot so it delivers less water.
When you use warm rinse, you get mediium pressure thru both lines, again less water than al hot on filling the machine.
Apr 29, 2009 | Washing Machines
Cold water in the rinse cycle of the washer just trickles
Sounds like cold water solenoid is not opening all the way, its easy to replace, and is found inside the wash machine where the hose connects
Apr 25, 2009 | Whirlpool LSQ9600L Top Load Washer
Dishwasher will not run after filled with water
The float switch in the tank is bad,also if water only trickles in your fill valve is going bad which will not let it fill all the way to start wash cycle. Fill tub with pot of water to raise float, if wash cycle starts,replace fill valve,if not,replace float switch.
Jan 21, 2009 | Dishwashers
Slow cold water only fill kenmore heavy duty 70 902202
remove fill hoses and inspected for debris or cloggs ,,,,
Dec 30, 2008 | Kenmore 22422 Top Load Washer
Water filling oo last cycle
if only leaking on rinse cycles would suggest checking door seal for small tear as water level is higher on rinse.
Oct 23, 2008 | Fisher and Paykel Washing Machines
Washer fills slow only in the rinse cycle
ck and clean screens first both sides be sure hoses are not reversed timer has no affect on fill rate if screens are clean replace valve
Sep 19, 2008 | Kenmore 24032\24036 Top Load Washer
Water trickles in
you may likely have a faulty water valve or water is back filling through the waste hose if it is plumbed into the sink. also is the supply water pressure low? it may not be assisting the water valve to shut fully.
Jun 07, 2007 | Kenmore Elite 45986 Front Load Washer
Whirlpool washingmachine
Karen, start by removing the cold water hose to the inlet valve in back. It will have a screen in the inlet valve. Make sure the screen is clear of sand and debris. Start there and post back. Catriver.
Apr 22, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Roper RAS8445KQ Top Load Washer Logo
122 people viewed this question
Top Roper Washing Machines Experts
Marvin
Marvin
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
