Looking for part/number and location Pioneer SD-P4681
Hi..I have a Pioneer SD-P4681 with the famous convergence problem..The blue goes to the right and stays there.Normally after the TV is shut off for some time you can readjust it and your good for a while.But the other night,it finally bit the biscuit and the blue is permantly out to the right.
I've read in several posts here and elsewhere,where the convenrgence chip has gone bad,so I am goign to assume that this is my problem.
Can someone give me an idea of which component it is exactly on in my TV.The video baord is a AWV-1478-A part number on it if that helps
I have someone lined up to do the work,and am ready to get the parts,but I can't locate it and I need to find the part number first before I order to ensure the proper peices.
If someone can help,would appreciate it...
Thanks
Aaron
    Master:
  • 518 Answers
I found this on one site:
Remove the speaker grill then the panel behind that you will find a board mounted to that panel find the big ass Ic ( STK4277 ) and change it,
problem solved almost every time
Hope that helps...
Geno
Posted on Mar 06, 2008
The picture looks double with the red convergence adjustment will not work took back off all color lights seem to be working
Go to menu setup look for convergeence,see no convergence adjustment.U have an open Fuse at (FL231)located right side of the Flyback Transformer.There is 3 in a roll small
brown rectangle looking caps,but they are Fuses,it will be in the one in the middle.
Aug 20, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
Hello, I have an older Pioneer SD-P55A3 projection tv. I have a problem where the picture at the bottom of the screen appears distorted or, more accurately, "warped". There is yellow and blue that does not...
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 16, 2009 | Pioneer SD-P55A3-K 55" Rear Projection...
Pioneer SD-582HD5 Picture looks 3D with red and blue copies of images seperated on the screen..
Replace BOTH of your convergence ICs they are big black ICs will have part number on them if 110s use 180s.
Feb 18, 2009 | Pioneer SD-582HD5 58" Rear Projection...
Convergence
convegence amp ic are bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 13, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Right side convergence
A convergence IC has burned out. If I remember correctly, those Pioneer sets have one huge convergence IC, but that IC only has 5 channels in it so they use another smaller dual STK IC and one half of it is used for the 6th channel and the other half is the vertical output. Look on the convergence board, find the blue convergence jack, identify the blue horizontal channel, follow the traces and replace the IC handling the blue horizontal channel.
Aug 28, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
HELP TO FIND IC's CONVERGENCE GENERIC NUMBERS
STK392-180 http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Aug 01, 2007 | Pioneer SD-643HD5 64" Rear Projection...
Blue convergence on Pioneer SD-532HD5
The converence IC's are the problem. Unfortunaely, I do not a service manual for that unit. You will find the IC's mounted on a large heat sink. The nuers usually start with STK-xxxx. Find these IC's and copy the number off them. Usually the can be replaced by generics. You can order them directly from Mat Electronics 1-800-628-1118. Be extremely careful when you desolder these ICS the foils are easy to lift. Use desoldering braid(chemtronics) 10-25L. Also ask for BOB and tell him that Tom from TOM's Tv suggested him. This will insure you the lowest price. Also some times the current limiting resistors open up. Always replace both convergence ICS. In your case only one is bad. Replace both anyway. (they only cost about $12.00 @ Any further questions, contact me. These are great TV's and well worth repairing!!! Scrivitron
Jun 22, 2007 | Pioneer SD-582HD5 58" Rear Projection...
Televison & Video Logo
217 people viewed this question
Top Televison & Video Experts
