Question about HP iPAQ H1940 Pocket PC
I can't install a certain HP update.
HP has released an update to the iPAQ h1900 series. This update fixes the problem of the calender jumping around to different dates. Whenever I try to install it, it copies a .cab file to my device, but it won't install.
Here's the update:
HP iPAQ h1900 Series Pocket PC - Real Time Clock Update
Were you able to install this update? And what ROM version do you have? Someone I know who was able to install never updated the ROM to v1.10.
  • turbo4 Mar 06, 2008
    I forgot to mention that a hard reset didn't solve the problem.
  • turbo4 Mar 20, 2008
    Thanks for your help, but that's what I did in the beginning. I synced it and ran the extractor on my PC. The problem is step 3. On step 3, an install dialog box shows up on my device, but the progress bar never advances. Then it just closes, and the update is never installed. I found the cab installer that gets copied to my device, but it won't run.
    After some experimenting, I find out that this update installs just fine on a ROM version 1.00. I have a hypothesis that this update doesn't work on v1.10.
  • HP Master
  • 13,433 Answers
1. Download the SoftPaq to a directory on your hard drive.
The file downloaded is a self-extracting executable with
a filename based on the SoftPaq Number above. 2. Establish an Activesync connection between your iPAQ Pocket
PC and host PC.
3. Execute the downloaded file and follow the on-screen instructions
to install the Real Time Update.
4. Follow the instructions to perform a normal reset on the iPAQ Pocket PC.
on step 3 you should see the setup on your pdas screen do you see this?
Waiting for your reply. :)
Posted on Mar 19, 2008
  • Ekse Mar 21, 2008
    do you need the update? do you have the problem the fix is made for?
How can i install the latest version Windows Mobile on my HP IPAQ rx 5935 Travel Companion?
Simple answer: you can't, sorry.
All Windows Mobile versions are customised by the supplier to suit the specific device that they're sold with, that's also why Microsoft do not provide the end-user with any support at all for WinMo and refer all such matters to the vendor instead.
HP never released an update even to WinMo 6 for your device, so you are stuck with the original WinMo 5.
Jul 01, 2011 | HP iPAQ® rx5935
Tip
HARD RESET HP iPAQ h1900 Series 1910/1915/1930/1935/1940/1945)HP iPAQ h6300 6310...
While holding down the power button press in on the reset button (reset hole) with your stylus (located on the left hand edge of the unit rather than the bottom) for about 5 seconds.
on Mar 10, 2010 | Cell Phones
Model 2003 ipaq, can't get past alignment screen
try a hard reset(hold down the 2 outside corner buttons,calender and home, then use the stylus and press the button on the back). if this does not help, go to HP support site and get the latest ROM update, download and install. this will completly set device back to factory settings, your sync folder will still have all contact, pics, appmt.,etc. hope this helps.
Jan 17, 2010 | Microsoft Windows Mobile 2003 for Pocket...
How do i do a hard reset on HP ipaq X11-21204?
u have given a wrong Model number this is not a model number infact a part number pls try to find the correct model number from HP site thru photo identification if u dont find ur model other wise i am providing u detail below to try the hard reset on various series of HP IPAQS kindly be sure that ur ALL DATA WILL BE ERASED pls rate me FIXYA if i fixed ur problem
How to Perform a Hard Reset on an HP iPAQ
Performing a hard reset on an HP iPAQ is relatively easy, but is a dramatic step in the management of your handheld organizer. A hard reset will completely clear the memory of your device and restore it to the state you received it in from the factory. A soft reset, on the other hand, simply closes running programs and restarts your pocket PC.
Instructions
Difficulty: Moderately Easy
Step1
Read the owner’s manual. If you don’t have to do a hard reset, you shouldn’t, and you definitely don’t want to do one by accident. So familiarize yourself with the hard reset protocol offered in the manual.
Step2
Make sure you want to clear all personal settings, saved data and personal files from your PDA. If there are files you wish to retain, save them to a removable disk, or send them to your computer’s hard drive to be retrieved at a later date before performing a hard reset.
Step3
For the HP iPAQ h1900 series, hold down the power button while you use your stylus to hold down the reset button (on the left side of the iPAQ). Hold these buttons for a few seconds until the screen fades to black.
Step4
For the HP iPAQ h2000 Series, press down on the far left and right buttons (calendar and iTask, respectively). While you do this, press and hold the reset button on the back of the iPAQ until the screen fades.
Step5
For the HP iPAQ h5000 Series and H3800 Series, the procedure is the same as the h2000 Series with the only difference being on some models the Today button is used instead of the iTask button.
Step6
For the hw6500 Mobile Messenger Series and hx2000 Series the procedure for the hard reset is precisely the same as for the devices in step 4.
Step7
For the rx3115 and rx3715 models, hold down the Mobile Media button (on the far left) and the iTask button. Then press down the reset button with the styles for a few seconds until the screen goes dark.
Step8
For the rz1710 and rz1715, follow the same procedure as the devices in step 7, with the difference of pressing the Today button (on the far right) instead of the iTask button.
Step9
To turn on your HP iPAQ after your hard reset, either press the reset button again, or plug it into an AC power source.
Tips & Warnings
* If you’re iPAQ is simply slowing down or having problems, try a soft reset (reboot) before resorting to a hard reset.
* Read your iPAQ’s instruction manual to familiarize yourself with how to do a hard reset, and the effects of performing one.
* Do not perform a hard reset unless you are okay with or intend to erase all non-factory installed data and settings from your HP iPAQ.
Mar 17, 2009 | HP Computers & Internet
Where can I get a free upgrade for my HP Ipaq rx3115 for windows Vista?
For compatibility with Vista it should only require installing the newest version of ActiveSync which is free from Microsoft's site. But, If you mean the Pocket PC OS Revision, I don't think you can legally update the OS beyond a version number (Like 3.3 to 3.5) and if your not able to sync with certain Office components, etc. because of the OS, there isn't much choice legally but to buy the upgrade.
Mar 13, 2009 | HP iPAQ RX3115 Pocket PC
Memory on HP ipaq 114.
there are two types of memory my friend
1. RAM
2. ROM both built in PDA
third type is Storage Card u can store music and photos there but u cannot merge it with RAM or ROM so pls try to understand this difference
secondly if u want me to help u out on this memory shortage
then u can reset the device i mean hard reset and re install ur applications by time ur ROM is occupied by some useless files and ur performance is de graded try to refresh ur OS
Hard reset
HP iPAQ Setup Assistant
Use HP iPAQ Setup Assistant to simplify configuring settings on your HP iPAQ.
HP iPAQ Setup Assistant lets you save the settings on your computer. This can help you restore configuration settings on your HP iPAQ at any time. HP iPAQ Setup Assistant also allows you to perform a factory reset on your HP iPAQ and view detailed product information.
To hard reset HP iPAQ 114:
- press and hold the 3 buttons Windows, OK and REC
- press the reset button for about 3-4 seconds and release it
- release the 3 buttons
u can see the video for that but it is in russian lang but self explanatory
http://www.youtube.com/watch?v=BG68AzNBsds
third option is if u want to really get rid of this slow performance and shortage of space just get a clean CUSTOM ROM from
http://forum.xda-developers.com/ for ur PDA strictly at ur OWN RISK
pls rate me fixya if i have fixed ur problem
Mar 01, 2009 | HP Computers & Internet
Sync Iphone with outlook
just install itunes and you can sync calendar and contact to your iphone. You cannot sync the notes and tasks but. I have just bought an iphone and before I was using an HP ipaq like you. Everything is synced except for the notes and tasks. You cannot even see any word or excel files you had on your ipaq. Cheers
Aug 21, 2008 | Apple iPhone Smartphone
I have a HP iPAQ and ran the battery down. On recharging when I go into calender the button will npt move from one week to the next. Can you help
remove the battery and then plug it back and then check
2. reset the ipaq by going into settings
even after this is the problem persist reload the software contact the tech for tht
May 20, 2008 | HP Computers & Internet
Trouble with calender
Sounds like a software bug.
Sep 11, 2005 | HP iPAQ RX3715 Pocket PC
HP iPAQ H1940 Pocket PC Logo
183 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
