Question about Sony Cyber-Shot DSC-H1 Digital Camera
Recharge of flash
Hi have the Sony DSC H1 camera and really like it even though reading about problems others have had. However, I am having a problems with fully charged batteries and the amount of time the flash takes to recharge. I miss great photos because it is ready:( Does any have any advice? I bought the camera 3 yrs ago in the US but am now living in India. I am a bit skeptical of taking it to a Sony repair center. Any advice/info would be appreciated!
  • 1,170 Answers
Sony H1 camera has a delay to recharge the flash and I hope that you know that as you are using it for the last three years. If the time delay is a new issue check the MAH of the battery to ensure that it will be above 2200 at least. If the MAH is below 2200 it is natural that the time delay will be more to recharge the flash. If my solution proves good please rate it. Regards.
Posted on Mar 25, 2009
My Sony DSC H1 Camera easily get drains the batteries. I already tried to replace new batteries 3x and when i use it, just take 5 shots and the battery was drained already.
If you are shooting with flash and using alkaline batteries, this certainly could be the case. If you are using lithium batteries or NiMH rechargeable batteries and are not shooting with flash, and are having this problem, then there is likely some internal problem with the camera that is draining the batteries unnecessarily.
In that case, you'd want to take the camera to a repair shop for troubleshooting.
Mar 11, 2011 | Sony Cyber-Shot DSC-H1 Digital Camera
How do you change an interneal flash on a dsc-h1
Hi there you need to open the camera casing then you can remove the flash light. But if you want to do this at home you need to know chip level circuit board repairing. ask me if any thing else.
Jan 15, 2011 | Sony Cyber-Shot DSC-H1 Digital Camera
The batteries in my DSC H1 camera only last about 10 % as long as they used to. New batteries don't solve the problem. Can the camera be fixed? Larry
I would suggest trying a different type of battery. If you're using AA batteries, often alkaline ones don't work. Try lithium or even rechargable AAs. If it's a rechargable lithium type (a square battery) try charging the battery fully and then using it completely to refresh the lithium cells. Try cleaning the contacts (silver pieces where the battery touches the camera) with a soft cloth as they can easily get corroded. Generally battery failure is not to do with the camera itself.
Jul 24, 2010 | Sony Cyber-Shot DSC-H1 Digital Camera
Sony cybershot dsc-h1 flash bulb has blown
You need to have it fixed at a service center.
Aug 13, 2009 | Sony Cyber-Shot DSC-H1 Digital Camera
Sony Cyber-Shot DSC-H1 Digital camera that will not hold a battery charge
All rechargeable batteries got exhausted after 100s of charges or after a certain period. It need replacement. if my suggestion proves useful please rate my solution.
Mar 26, 2008 | Sony Cyber-Shot DSC-H1 Digital Camera
I cant use dsc h1 with strobe light
If you problem is that the double flash triggers the strobes early (on the first flash and the shot is made on the second flash - dark) you either:
1. Get a wire accessory to command the strobes
2. Put a simple external flash on top of the camera and use it to trigger strobes. If you don't need the light from this flash just point it up of backwards, it will still trigger the strobes. If it does not rotate, you can use tin foil. A very simple external flash will do, as the camera will flash only once with external flash.
Jan 09, 2008 | Sony Cyber-Shot DSC-H1 Digital Camera
E18 Problem with Sony Cyber-Shot DSC-H1 Digital Camera
it is due to the friction in the lense movement. your camera needs repairs.
Nov 15, 2006 | Sony Cyber-Shot DSC-H1 Digital Camera
Sony Cyber-Shot DSC-H1 Digital Camera Logo
61 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
