Question about Edirol UA-4FX External Sound System
About sound card
I m running Windows XP Service Pack2 with in built sound card on the motherboard. The problem is my system does not display sound every time the computer starts. Sometimes sound properties in Control Panel is disabled then I cannot move the slider of the volume. Also whenever it shows the sound properties I cannot hear the sound after increasing the volume full. My speakers are alright and drivers are up to date still I don't know what is the problem. I had also reinstall Windows XP still there is same problem. Details are :
Intel(r) 82801AA AC'97 Audio Controller
Manufacture: Intel
Driver Provider: Microsoft
Kindly solve my problem.
  • 3 more comments
  • Sibworld Mar 07, 2008
    Thanks for reply. Here is motherboard model.
    Motherboard Name A-Trend ATC-7401M
    Motherboard Chipset Intel Whitney i810E
    Whenever I had installed Windows XP on my system it automatically accepts drivers for graphics and sound but now sound is not working.I have a motherboard CD and I had installed graphics,sound driver etc but it does not show my sound . Also whenever it shows the sound properties I cannot hear the sound after increasing the volume to the full.
  • Sibworld Mar 08, 2008
    I also think this is the only solution .
    Please tell me the procedure how do I disable the on-board sound card.
    Also tell me which sound card is best according to my motherboard 810E.
  • Sibworld Mar 14, 2008
    As you have said before I had installed new internal sound card at PCI slot and disabled the on board audio.
    My new audio is :
    Audio Adapter Yamaha DS-XG Audio CODEC
    Now the problem is that when I play music,movies it plays for few minutes say 4 minutes and then there is no sound from the speakers. Also Windows Media Player is not playing any audio flies and it hangs after some time.
    When I restart the computer the sound comes and then again after few minutes sound goes away.
  • Emelio Navaja
    Emelio Navaja May 11, 2010
    Tell me the correct motherboard model.
    because ac97 sometimes needs and updates.
  • Emelio Navaja
    Do you have a utilitiy?
    Genius:
  • 1,226 Answers
Try this , Plug in your speaker to your desire sound card. If it is BUilt in Maybe AC97. If is an add-on then you plug it on the add-on sound card.
and then go to control panel ..see pictures,...
about sound card - 4d551af.gif On the default device change the or select the device you are using and then click OK. Just do this incase you have multi device.
melnavz
Posted on Mar 08, 2008
    Novelist:
  • 113 Answers
Some systems do a speaker autodetect - and if your speakers are not powered on when the system boots, the sound may not function until a reboot
Another possible issue could be due to bad drivers that sometimes load, and sometimes not. I usually find that Microsoft's drivers are less than ideal, and in many cases just may not work. And onboard sound may not work properly if the chipset drivers are not loaded as well. Did the machine or motherboard come with a CD? If so, put it in and let it run to install all of the drivers. If not, we need to determine the exact model of motherboard to find where we can download the drivers from. On the motherboard there should be either a model number and version silkscreened onto the board itself, or a label, generally with a bar code as well as numbers. Sometimes this label is on the board itself, and sometimes it can be on top of one of the headers for USB or the parallel port if it has one. Post these numbers or any other model information you can find.
Posted on Mar 06, 2008
  • Phil
    Phil Mar 08, 2008
    Your original post indicates that the sound driver is from Microsoft, and I thought that may be the issue. However, I now have found quite a few people who are having the same type of sound problem with their Intel motherboard based 810E computers. So the best solution might be to disable the on-board sound (let me know if you need instructions to do that and I'll provide them), and put a PCI sound card into a free slot on the computer. This will almost certainly work, and you will also get better audio sound!
  • Phil
    Phil Mar 08, 2008
    To disable the on-board sound, you have to enter the bios when the machine first starts up. On most standard motherboards you press the "Del" key, though some use the F2 or F10 key. When you turn the computer on, the first text only screen you see should list the key on the bottom, if the Del key is not the one.
    Once in the BIOS, the sound is usually listed under the "Intergrated Peripherals" section. Just set it to disabled, save your settings and exit.
    You can probably get a decent Soundblaster sound card for $25 or less at any local computer store. You can also order from the web, for example, here's one at Newegg for $19:
    http://www.newegg.com/Product/Product.as...
I just installed a D945GTP and in device manager under "Other Devices" it shows "PCI Device" and "PCI Serial Port". Anyone knowI have everything installed.
You can download the motherboarddrivers from Intel WEB site. Select your model motherboard/device, and makesure you select the Windows XP or Vista version of the drivers that matchesyour Windows operating system. Please click on this link andselect your model motherboard : - http://downloadcenter.intel.com/default.aspx?iid=gg_support-au+home_downloadctr
Dec 10, 2010 | Intel D945GTP Motherboard
Audio driver
http://download.softpedia.com/dl/67726aafea796ee43af7c61c08816bbc/4a479ec8/100030373/software/system/info/everestultimate502.exe
<<download this then get back to me once you have installed it
Jun 28, 2009 | EliteGroup ECS P4M900T-M2 Socket 775...
I have Dell inspiron 1525 laptop with windows Vista home premium
go to bios setup n change sata driver to ATA from AHCI n  also disable da flash play module
Mar 18, 2009 | Microsoft Windows XP Professional for PC
Sound solution plz
goto control panel switch to classic view , double click add remove programs , then when the list comes up look for service pack2 and remove , then restart computer
Oct 25, 2008 | ASUS P5VD2-MX SE Motherboard
Sound card driver
just go to the website of your manufacture.
mostly good companies provide
even if u dont get just go to realtek site and from there you can download the driver.
or atlast go in google search and just search for the driver by completely mentioning the model name,brand name or if ur computer is assembled the type the name of your motherboard.
Aug 02, 2008 | Intel ESS ES1868F Sound Card
Intel d865perl sound card drivers
left click this link & choose you're operating system for the Intel D865PERL motherboard drivers. (Reinstall the driver software).
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=949&lang=eng
For windows XP/home & pro. Click on this link;
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=949&OSFullName=Windows*+XP+Home+Edition&lang=eng&strOSs=45&submit=Go%21
After reinstalling the software & you're sound does not seem better than the built in sound chip may be going bad.
Other factors can also cause the effects you are having. Run windows system defrag. Also run windows Disk cleanup. These tools are found in windows System tools. Lastly you can buy & add a PCI sound card into an emty PCI slot to bypass the built in sound card. If you choose to do this you will need to enter the bios & disable the built in sound device.
Good Luck!
Mike
Jun 27, 2008 | Intel Desktop Board D865PERL...
Windows xp pack2,vpn
try do windows up ? reinstall sp2 run cc cleaner free tool online dl new vpn software from microsoft
Jan 07, 2008 | Computers & Internet
Audio driver installation failed from mother board cd
The most common solution was this: open device manager click "system devices" disable "microsoft UAA bus driver for high definition audio" uninstall "UAA bus driver" make rescan devices (Note: Not all had this step. You may want to skip it.) D.W. install realtek driver the realtek driver includes the UAA driver too.Hope this helps.
Aug 29, 2007 | E-Mu 0404 Sound Card
Edirol UA-4FX External Sound System Logo
123 people viewed this question
Top Edirol Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
David
David
Ben Armstrong
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
