Question about PNY Verto GeForce PCX 6600GT, (128 MB), (3 pack) Graphic Card
Nav4_disp conflict? My 6600gt worked fine when I first installed it. I updated the drivers, played Splinter Cell double agent and everything was fine. Tried it again later and problems began to occur with screen blank-outs and random screen specks/lines. After about 15 minutes the screen goes blue with a failure message - partially stating a "Nav4_ conflict" and the program is caught in a loop?
  • Madsnoopi Mar 06, 2008
    I mis-typed. Should be "Nav4_disp conflict".
    Genius:
  • 1,601 Answers
The nv4_disp fix I was able to successfully restore my computer to tip-top shape in 5 easy steps. Here’s my 10 minute solution.
  1. Boot your computer into Safe Mode w/ Networking. For Windows XP users, this is accomplished by pressing F8 repeatedly when your computer is booting up. You will be presented with several options. Choose “Safe Mode w/ Networking.” This will boot Windows XP into Safe Mode, but you will be able to browse the Web.
  2. Go to NVIDIA’s Web site and download the latest display drivers for Windows XP. I saved the 20MB file to my desktop for easy locating later on.
  3. Remove the NVIDIA display drivers currently installed on your machine. To do this, right click on “My Computer,” then select Properties. Click the “Hardware” tab, then click “Device Manager.” You now see a list of hardware devices installed on your computer. Double click “Display Adapters.” You should now see your NVIDIA card listed. Click it once to highlight it, then click the “Uninstall” icon in the upper right of Device Manager menu. Say “peace!” as the NVIDIA drivers are removed from your machine.
  4. Install the updated NVIDIA display drivers. Double-click the NVIDIA setup file you saved to the desktop earlier. The installation will run its course.
  5. Reboot your computer.
After following these steps, Windows XP should start up as usual (prior to our little nv4_disp bug). Your “nv4_disp” problem is officially solved.
What caused the nv4_disp problem? In short, I have no idea. I’m actually still trying to figure this out, so I welcome any comments about what could have been the cause. In doing some quick searches across the Web, however, I see that this is actually a common problem.
Posted on Mar 06, 2008
My problem is that when i tried to update my asus made ati eah5770 graphics card it malfunctioned my computer. I could not increase my resolution from 640*480 and it also shows only 4 colors instead of...
Go to www.ati.com and download an updated driver for the 5770 When you install the software you'll have the chance to install or uninstall you want to uninstall so this will remove any old ati drivers that might be causing this problem. Then go back after you restart the computer and run it again but this time install the new drivers and this should take care of your problem.
As far as the Acer 1912 LCD here are your specs:
  • 1,280 x 1,024 native resolution, fine 0.294 mm dot pitch
  • Wide 140-degree horizontal and vertical viewing angles
  • 250 nits of brightness, 500:1 contrast ratio, 16 ms response time
Mar 04, 2011 | Computers & Internet
Every time I put in a disc it came up 'Open Tray' isntead of 'Play game'...why
What console is this for? If it's for the X-box 360 then it's a problem with your laser. Either it's dirty or it's gone bad. Try blowing into the cd-rom slot (either yourself or with a can of compressed air) if this doesn't work then try getting a laser lens cleaner and running that through your x-box a few times. if THAT doesn't work then your laser has gone bad and you will need to contact Microsoft and ask for a repair order.
Aug 12, 2010 | Ubi Soft Tom Clancy's Splinter Cell:...
When im trying to play my regular xbox it flashes red and yellow
If the XBOX does this before it even starts up, you have probably got a bad hard-drive. Your best option would be to try a game that does some kind of dashboard update. ( Splinter Cell, Mech Assault, 007 Agent under Fire, Ninja Gaiden Black?, Google for a list) A dash-board updating game, should bypass the start-up process and attempt to reinstall the dashboard.
If that doesn't work, your xbox will need a professional repair.
Mar 01, 2010 | Microsoft Xbox Console
Wont even finish loading the opening ubisoft screen on start up for splinter cell double agent
Sounds like the disc is scratched go to yo nearest game store and get it cleaned.
Dec 24, 2009 | Ubi Soft Tom Clancy's Splinter Cell:...
Problem on splinter cell: double agent
I use www.gamespot.com and www.cheatcc.com and it will give you the walkthrus for that game. I don't have that one for my 360 yet.
May 13, 2009 | Ubi Soft Tom Clancy's Splinter Cell:...
Every time i try to load the first level my computer keeps crashi
it sounds like you're running low on RAM. Try closing all other programs before you run this game. If it still doesn't work you may need to upgrade your RAM. Has this game ever worked on your computer?
Feb 28, 2009 | Ubi Soft Tom Clancy's Splinter Cell:...
Xbox 360
Greetings iS Assassin,
I would ask the store to check neighboring stores or their distribution center for the game you want. I did a search on my local stores in MN and while the game is also not available here, there are 36 in the centralized warehouse of X360-SPLINTER CELL DOUBLE AGENT LE.
Hope this helps.
Thank you,
Agent Dort,
Go Ahead. Use Us.
Apr 14, 2008 | Microsoft Xbox 360 Console
PNY Verto GeForce PCX 6600GT, (128 MB), (3 pack) Graphic Card Logo
658 people viewed this question
Top PNY Computers & Internet Experts
David
David
pankaj rautela
pankaj rautela
Alun Cox
Are you a PNY Computer and Internet Expert? Answer questions, earn points and help others
