Question about Sony Cyber-shot DSC-W55 Digital Camera
Drains the battery power
Every time i turn it off and turn it on, it gives me time set up menu. It also drains the battery when the camera is turn off.
Pls. let me know the solution... Thanks
  • Anonymous Jul 19, 2008
    Clock set menu is displayed every time powered up.
  • 104 Answers
Sir,i think rare using ur camera,replace ur battery and everytime u charge proporly
Posted on Mar 06, 2008
I have a nextbase 512gw nextbase dash cam when in parking mode will it drain my battery. Thanks. Davie
you should fit a power magic pro this will protect your car battery from going flat there is 2 voltage settings on it 12 volts and 12.5 volts so when the battery voltage drains to 12/12.5 v it will turn OFF your camera enabling you to have enough battery voltage left to start your car
Jan 28, 2018 | Cars & Trucks
Reset fujifilm s2940
There is no complete reset, other than removing the batteries and letting the camera sit until the internal battery drains (at least 24 hours).
There is a RESET command in the Setup menu, which will reset everything except Date/Time, Time Difference, Background Color, Battery Type, and Video System.
Feb 15, 2012 | FUJIFILM S2940 Digital Camera
Kokak eassyshare z812is drains new battery in 5 miutes & makes a humming noise
The humming is probably your image stabilizer, and may be normal. Try turning it off in your camera's menus to see if that improves battery life. If it does, you may need to consider higher power lithium batteries if you wish to continue use of the image stabilization feature.
Dec 16, 2011 | Kodak EASYSHARE M1063 Digital Camera
I have a nikon s570 and it drains the battery even when turned off
Try replacing the battery. If the camera is still draining power from a new battery, call Nikon directly and explain the situation. They might have you send the camera in and send you back a refurbished model.
Mar 15, 2011 | Nikon Coolpix S560 Digital Camera
Recently purchased the Sony DSC-W290 and I have
how long do you usually charged the batt? to make charge last slightly longer leave the batt inside the charger for an hour after the charger light goes off. if you have a fully charged batt you should be able to take approx. 300 pics or 2.5hrs approx.batt life. for viewing pics it should give you approx. 6800 pics and approx. 5.5 hrs. of course, number of still images and and batt life may vary depending on the camera settings.so if you're zooming in and out,using the flash,going from camera to play mode, turning cam on and off, using other settings and features of the camera, this will cause the batt to drain much faster.also ambient temperature also affects batt life.if it's very cold, the batt drains a bit faster.also, it's recommended that if you're not using the camera to remove the batt.retaining the camera settings, date & time will cause batt to drain even if your not using it. if did this and still you think it's odd that your batt drains quickly and looses charge even if it's fully charge, it might also indicate that what you might be a defective batt. one way to find out is to try using the same type of batt from a friend or a relative that has one to confirm and further isolate issue.anyway, supplied accessories has the same warranty that applies to your camera.so you may send it out and have it replaced if needed.hope this helps.thanks:)
Apr 08, 2010 | Sony Cyber-shot W290 Digital Camera
Kodak Z1085 IS - drains battery even when camera is not on
the camera takes 1.5v to operate it
anything less the camera will shut down
recharge batteries are only 1.4v so at full
recharge it won't last long
The best batteries are litheum that have the right
volts and capacity to keep the camera going.
try turning or the camera stablizer setting...
might save your battery power.
Mar 17, 2009 | Kodak EASYSHARE Z1085 IS Digital Camera
Power on problem
Batteries are probably dead. Try getting rechargable batteries since Samsung S630 really drains batteries.
May 11, 2008 | Samsung Digimax S630 Digital Camera
WONT STAY ON
check your batteries...sometimes cheap batterie or regular batteries do the same to mine...you may need to spend the little extra and purchase batteries for a digital camera ect....good luck
Sep 26, 2007 | Vivitar ViviCam 3780 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
54 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
