Question about SanDisk Sansa m250 MP3 Player
Sansa Sandisk M250
It has been working fine for a few weeks. I left it hooked up and syncing when I left to go to baseball practice. When i got home, it said you can now dissconnect. I did. the player came on and said no files.. I turned it off and now I can't get it to come back on at all What can I do??
  • rebellady Mar 07, 2008
    I tried the soft reset. It didn't work. I was unable to do the #2 suggestion because the player won't turn on... I downloaded the recovery tool in the link you suggested... but now it doesn't show up on my computer.. I'm fixxin' to disable my spyware dector and try it one more time... thanks .. if you have any more suggestions I would be greatly appriciative...
    Brigadier General:
  • 6,966 Answers
Hi XX,
Thanks for asking me to be your Tech Buddy.
For Sansa units, a couple of things you can try:
a. do a soft reset - press on the Power/Menu for 15 seconds;
b. do a full settings reset - Main Menu/Settings/Reset All;
c. do a Format - Main Menu/Settings/Format but all in the internal memory will be erased.
If for some reason your version/model do not have a format option, please refer to this solution posted by another expert, computerrep.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 06, 2008
  • Louie  Role
    Louie Role Mar 06, 2008
    Hi again rebellady,
    The XX should be your handle/name, I was templating, sorry for that.
    Any development(s) with your Sansda pls?
SansaDisk Sansa m250 (2GB) "Finalizing update"
You need to go to the Sandisk support site and down load the Updater program. Run the updater on your player. This in a way reinstalls the software on the player kind of like reinstalling the operating system. [
Jul 20, 2010 | SanDisk Sansa m250 MP3 Player
Files not deleted from m250
Try this solution:
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release, right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
Good Luck,
I hope this helps
Nov 14, 2009 | SanDisk Sansa m250 MP3 Player
Sansa m250 not working, need help soon
Plugging it into another computer changed the formatting of the player.. I would format the player from the menu itself, but if that fails:
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Jun 26, 2008 | SanDisk Sansa m250 MP3 Player
I WANT TO DOWNLOAD SANSA M250 SOFTWARE
What version of windows are you using, did it install by itself without any troubles? It should show up in windows media player in sync or transfer to device.
Jun 01, 2008 | SanDisk Sansa m250 MP3 Player
It will not do anything
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Mar 06, 2008 | SanDisk Sansa m230 MP3 Player
The pc doesn't recognize the m250
http://www.sandisk.com/Retail/Default.aspx?CatID=1532
download the sansa connect recovery tool
download the manual and it will tell you how to reset your mp3
Feb 26, 2008 | SanDisk Sansa m250 MP3 Player
MY sansa connect 4gp crashes my computer
Go ahead and do this, in case the DB is corrupted:
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
Dec 30, 2007 | SanDisk Sansa e250 MP3 Player
My sansa m250 says "not enough space for Music DB Please Free 8MB".. when...
I received the same problem, I thought I had done a Sync by mistake and had used of all the space. I had to re-format the player and start over.
Jan 27, 2007 | SanDisk Sansa m250 MP3 Player
Can't sync file
Try formatting your unit and reinstall your playlist it will work.
Jun 21, 2006 | SanDisk Sansa m250 MP3 Player
SanDisk Sansa m250 MP3 Player Logo
1,013 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
