Question about Panasonic CQ-VD7001U Car DVD Player
TOC reading... e1 error
I just bought the in dash dvd player. i haven't installed it you but i hooked up the power onto my battery and seems like everything is working. however, when i put in a dvd or cd, it says TOC reading and then after a while e1 error shows up. This happens regardless the type of cd or dvd i use. will a dvd cleaner work??
  • dlai85 Mar 06, 2008
    that sounds like a good idea... but i haven't actually installed the unit. I want to be 100% sure that it is correctly working. I was wondering if not having everything wired up would be a problem?? i basically just powered it on my battery to make sure it powered up and assumed that if i put a disk in the player it should start playing at least. am i wrong?? should everything be wired up and it should start working no problem??
    Champion:
  • 227 Answers
Buy a cd cleaner kit, if it doesn't work have some one capable re-align you laser len. When the unit get use for times the len got tired(worn and mis-align). Goodluck.
Posted on Mar 06, 2008
  • hogan doan
    hogan doan Mar 06, 2008
    If it is powered on and you can operate you radio then you hooked it up right or else no source would worked. Always bench test before install, it would save lot of times.
My cd is not recognize I get a message that read TOC
If a read head burns out or the alignment has changed, the laser is inoperative. If a CD/DVD was a copy or reproduced on a computer it too may not be read. If the medium works on other devices, then the players laser may be defective.
Mar 01, 2014 | Harman Kardon CDR2 2-Disc CD Recorder
Toc not available
Problem solved: Downloaded service manual and after studying it for awhile found the fault.
1. On power up in "timer record" mode the 520 proceeds to record selected input until the timer shuts the power to the 520 off.
2. TOC info is stored in memory along with error code history.
3. On power up TOC is read from memory and written to disk and second recording started.
4. Found BT451 had failed (causing loss of 2 above) as soon as the power is removed from the 520.
5. Replaced BT451
BT451 1-528-739-11 BATTERY, LITHIUM (SECONDARY)
(Sanyo ML2016-HJ1 40mA/h 3v rechargeable is suitable replacement) shop around as prices vary
I actually fitted a Lithium battery removed from an old satnav I had lying around! bit of overkill really as it 1400mA/h
Note a faulty BT451 can cause quite a few other problems as well so it's worth checking out and replacing if low or not holding it's charge...........
Sep 02, 2013 | Sony MDS-JE520 Mini Disc Player
When I input a disc and hit play I receive an error which says "TOC ERRORa".
Possible that the disc is not reading and so the the TOC- table of content error must be referred.
It can be due to a poor head tracking or the failure of the data being read or processed.
Clean the head and use a good disc to be checked once again. If so the optical head can be faulty as it might be getting weaker.
Nov 06, 2010 | Sharp MD-MS702 Personal MiniDisc Player
My dvd player won't read copied dvd movies but willl read store bought dvd movies in the device manage is says "unable to recover TOC error 0x13570001
one answer is to format the movies after you record them on dvd player. They would then be more likely to be read by the pioneer dvr.
Mar 01, 2010 | Pioneer DVR-107D DVD±RW Burner
Sony mdm-x4 when I load a disc it shows me blank disc, before that TOC reading. how can I get my record back?
You cannot remove power from a minidisc player after you are done recording as it updates the TOC when you power down. If you had switch set to timer "REC" and power up the unit it should update the TOC, otherwise all is lost.
Jan 22, 2010 | Audio Players & Recorders
When i inserted my mini disc it said TOC Reading then said Toc Error and C14. What is the problem?
Sounds like you lost power when you were finishing recording a disc. On a home unit it got unplugged before you had the TOC written, or on a battery unit the battery died when it was writing the TOC (table of contents) for the disk.
Jan 01, 2010 | Audio Players & Recorders
E1 Error on Panasonic CQ-C1110W Car CD Player
If you receive an error reading or the cd ejects automatically briefly after being inserted, the headunit needs to be repaired or replaced
Jul 01, 2008 | Panasonic CQ-VD7001U Car DVD Player
IT READS ERROR 181
Hard drive crapped out. Send it back for repair.
May 05, 2008 | Alesis MasterLink ML-9600
DVD tray will not open
When a disk is stuck inside the player , try following the procedure below:
Unplug power cord.
Plug back power.
Turn on the unit and press repeatedly the eject button at the same time. If you successeed in ejecting the disk before the player starts reading TOC(disk initial track), then the disk will eject.
If that does not work, then there is an internal fault, in that case the unit must be taken apart to remove the disk.
Feb 25, 2008 | Dual Presidian DVD Recorder
Toc code keeps comeing up on my kenwood kdc x5589
Hi, toc error means that the laser is struggling to read the Table of Contents which tells the unit where all the information is on the disc, it may be something as simple as the lens needs cleaning or something as complicated as the laser needs replacing, but you could try running a cd disc cleaner through it first. Good luck......
Jan 24, 2008 | Kenwood eXcelon KDC-X559 CD Player
Panasonic CQ-VD7001U Car DVD Player Logo
373 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
