Question about HP Compaq Presario 2100 Laptop
My hp 2100 presario laptop in not booting - HP Compaq Presario 2100 Laptop
    Master:
  • 497 Answers
Startup problems
If the notebook doesn’t respond when you turn it on
• Connect the AC adapter.
• Reset the notebook by inserting the tip of a paper clip into the reset button on the
bottom of the notebook. Then press the power button to turn it on.
• If the notebook still doesn’t respond, remove the battery and AC adapter, remove
any PC cards, and undock the notebook if docked. Then plug in the AC adapter
again, and reset the notebook using the reset button.
If the notebook won’t boot from battery power
• Make sure the battery is properly inserted and fully charged. Check the battery
charge by removing it and pressing the pad on the side of the battery. The lights
show the charge level.
• If available, try another battery.
If the notebook won’t boot from the floppy disk drive
• Make sure the floppy disk drive is selected as the boot device.
• If you’re using a USB floppy drive, use the BIOS Setup utility to make sure
Legacy USB Support is enabled. If your notebook also has a built-in floppy
drive, use the BIOS Setup utility Boot menu to make sure the USB floppy drive
is the first device under Removable Drive.
If the notebook stops responding after booting
Check whether you are connected to a TCP/IP network with no DHCP server. This
can cause a long delay at startup because DHCP is enabled. Contact your network
administrator to determine the proper TCP/IP configuration
***IF THE NOTEBOOK HAS POWER BUT WONT BOOT INTO OPERATING SYSTEM-
Press F2 when you start it to enter BIOS to check your BOOT ORDER to make sure your HD is listed first on the list.
If it is not listed remove it and reinsert it and then try again.. GREAT LUCK!! Please Rate Me, K? Thanks- Lucky4lynn2
Posted on Mar 06, 2010
SOURCE:
How to change boot up menu to cd rom
when your laptop sets up press F10 that will take you to your BIOS ...next go to "ADVANCED" Next go to BOOT OPTIONS...NEXT go to BOOT ORDER.... To change the order of your boot, use the + and - keys, after you get the cd-rom first in order, hit F10....go over to the "FILE" and save changes and exit. Your laptop will restart on its own ! to change the setting back just reverse the boot order ! :)
Jan 26, 2013 | HP Compaq Presario 2100 Laptop
Keypad on my compaq presario 2100 laptop not working at all
try using other keyboard. like a usb type or a ps2 type. then replace the keyboard on your laptop
Apr 07, 2010 | HP Compaq Presario 2100 Laptop
HOW TO REPLACE THE POWER JACK ON A COMPAQ PRESARIO 2100 LAPTOP
There is a site that will give instruction on how to repair this but it you will need soldering skills and delicate handling to do so.
try this site see if it helps.
http://laptopsplanet.com/compaq-presario-dc-power-jack-repair/
Mar 31, 2010 | HP Compaq Presario 2100 Laptop
How to reset bios pasword compaq presario 2100
Here is the service manual for your laptop
http://h20000.www2.hp.com/bc/docs/support/UCR/SupportManual/TPM_319733-002_rev3_us/TPM_319733-002_rev3_us.pdf
On page 2-61 it gives the explanation on the boot block jumper under the heading-->Repairing the BIOS IC..
I hope that this has been very helpful for you
Dec 04, 2009 | Compaq Presario 2100T Notebook
I can't find and install driver modem for compac presario 2100
Here is the link to download your modem driver.
DONT FORGET TO RATE !!
Thanks
Mar 12, 2009 | HP Compaq Presario 2100 Laptop
Quickrestore- keeps shutting down mid-process
Sounds like the cd/dvd is not reading the cd's correctly, Not sure if my compaq restore cd will help but here is the link to cd 1
Download the file burn ISO to cd and boot from cd,
For giggles did you try an external cdrom?
Mar 29, 2008 | HP Compaq Presario 2100 Laptop
Compaq presario 2100 modem problems
http://h10032.www1.hp.com/ctg/Manual/c01122313.pdf
It doesn't look like it to me...
Jan 01, 2008 | Compaq Presario 2100T Notebook
HP Compaq Presario 2100 Laptop Logo
297 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
