Question about SanDisk Sansa m250 MP3 Player
How can I get my Sansa m250 to power on??
I've had this player for a couple of months and it has worked fine until nowThe player won't do anything.. I took out the battery and tried to reset it. But nothing.. Now my computer won't even recongize it at all I have the Sansa updater installed on my computer, but even that won't let me reconize the player.. Please help....How can I get it to power on?? The battery is brand new and was playing it ealier???
Same problem i had a while back - i called sandisk and they replaces it
Posted on May 04, 2008
    Genius:
  • 1,027 Answers
If your Sansa Connect won’t start check to make sure the device is
charged and the hold switch is in the unlocked position. If the device still
will not start, you may need to run the Sansa Device Recovery application.
With a copy of the Sansa Device Recovery application installed on a PC,
you can connect your to the device via the USB cable to the PC, and
restore the device software to an uncorrupted state. However, all of your
subscription settings and content will be removed from the device.
http://www.sandisk.com/Retail/Default.aspx?CatID=1532
or google the sansa connect recovery tool
Posted on Mar 06, 2008
My Sansa M250 is only 1 month old and won't recognize Music folders now when I plug it in. My PC does recognize the device but now it only shows Audible, Config and Record. Before it showed playlist,...
reset the device to factory defaults thats it....
check your usb ports are working properly in not i recommend to re instal the usb device drivers also
Jun 27, 2011 | SanDisk Sansa m250 MP3 Player
I have a SanDisk Sansa m250 MP3 player , when I plug the USB
it most likely dosent work on vista due to its age and or sansa never made a driver for vista. try sansa suport and look for drivers and downloads. there might be a driver there
Jun 23, 2009 | SanDisk Sansa m250 MP3 Player
Problem with max. volume
Not Mac compatible largely.
ALL Mp3 players have a disclaimer telling you not to play it at max volume. Get adjustable headphones to resolve problem
Mar 26, 2008 | SanDisk Sansa m250 MP3 Player
I have Sanso m250 2.0gb mobel. Logo screen is appearing when i power on after that i am unable to play the mp3 songs or play FM Radio etc..
Try doing a hard reset on a Sansa m250:
  1. Turn off the Sansa. Just pull the battery out for a second.
  2. Plug the Sansa into a computer4.gif, and open "My Documents" in the computer.
  3. Open the Sansa file as if it were a drive, then go to the "MUSIC4.gif Specific storage" file.
  4. Right click the "MUSIC Specific storage" file, and press "Format."
This should hard reset the Sansa m250. I do not know if this will work on other Sansa m200 type .mp3 players. You can start over with your playlists. This has worked for me.
Dec 23, 2007 | SanDisk Sansa m250 MP3 Player
Sansa - sandisk m250 troubleshooting
  1. Turn off the Sansa. Just pull the battery out for a second and then reinstall the battery without pushing any further buttons.
  2. Plug the Sansa into a computer, and open "My Documents" in the computer.
  3. Open the Sansa file as if it were a drive, then go to the "MUSIC Specific storage" file.
This should hard reset the Sansa m250. This solution has worked for me.
Dec 20, 2007 | SanDisk Sansa m250 MP3 Player
Not enough space to listen
If it''s any consolation, the same thing happened to me after I loaded about 1.6 GB (~250 MB left) of music on my Sansa m250. I tried to delete the required 8MB, but the directory structure got destroyed to the point where my computer wouldn''t recognize the device. I called their technical support and they''re having me send it back to them for a replacement! It''s not you, but the player! I don''t know if there''s anything that can be done from a consumer standpoint.
Jul 09, 2007 | SanDisk Sansa m250 MP3 Player
Sansa m250 not powering on
OH wow this is the same problem i am having. I hadn't used it for a few weeks too. and now it is doing the same thing yours is....???? tells me it probably isn't a *individual player thing*...God i hope we get a solution. I use mine for powerwalking. At least i can coonect to the PC get it started up and go. But how frustrating when i am flying etc. can't take it with me then!! Looks like i'll be getting a new one. it will be my 3rd in less than a year!!!
Apr 13, 2007 | SanDisk Sansa m250 MP3 Player
My sansa m250 says "not enough space for Music DB Please Free 8MB".. when...
I received the same problem, I thought I had done a Sync by mistake and had used of all the space. I had to re-format the player and start over.
Jan 27, 2007 | SanDisk Sansa m250 MP3 Player
SanDisk Sansa m250 MP3 Player Logo
187 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
