Question about RCA HD52W59 HDTV Projection Television
Getting channels set with out the remote
I bought a used TV from a store and told it wouldnt turn on. I get it home and it fires up and plays dvd's but when I hook the cable up to it I cant get the channels set. When I hit channel up and down I get differnt video options ( vid 1, cmpt1 ect. )...
When I called a TV repair guy he told me all I need to do is preset the channels for the tv by the sounds of it. Can anyone tell me how to do that without a remote??
~Eric
If the tv does not have the menu option you will have to get a unaversel remote
Posted on Mar 19, 2008
Why can't I play DVD's on my AWA 46" LED LCD TV LE4603-05?
Have you seen an AV input selector on your TV or remote?
Have you start playing the DVD and run a channel scan to see if it comes across it, if so, store the channel that the TV finds.
Are you using correct cable?
Jul 21, 2014 | Televison & Video
Hello, we have an Orion DVD/TV combo and have no remote for it. Is there any way to play a DVD without the remote the Play button alone on the unit does not play the DVD from its menu? We live in...
You should be able to do a channel search and come across the inputs either at the upper end or the lower end of the channel search. Using the channels on the TV itself, not cable or satellite, scroll through the channels until the desired input is found. Once on the desired input open the DVD player and insert a DVD and close the drawer. The DVD should start to play automatically. When it gets to the place on the DVD to actually "play movie" press the select/enter button on the remote. As for the replacement remote I would get a universal remote. They are far fairer in price than an original replacement remote and every bit as reliable. Just make sure to take the model of your TV/DVD player with you to make sure the remote you purchase is compatible. You probably need to go no further than your local hardware store or department store. Save on the shipping too. However if you are set on getting the original remote here is a place http://www.orion.newremotecontrol.com/catalog_item.php?catnum=076R0DT090 they also sell a few generic remotes for a few dollars less.
Regards, Tony
Apr 17, 2011 | Orion TVDVD091 9 in. TV/DVD Combo
We bought a samsung tv off display and the tv is on store mode and we do not have the remote to change it.
frist turn on tv
press the menu botton
press the channel donw botton to go to setup
on setup press the volume +
press the volume botton again
press the source botton to enter in the plug and play option
press source botton and select store or home by pressing the volume botton
and then press the source botton again
after this just turn ur tv off and than on
Nov 30, 2010 | Samsung TV Remote Control
Can't find dvd channel on my tv...
hi does your dvd player have scart lead connection if yes select av1 or ext1 thanks
shaun
Mar 06, 2017 | Zenith SY2569X TV
No connection DVD to G25189TK. No external channel set. (3 or 4)
to see the dvd video you should select the AVmode using your TVremote.if the wires are not properly connected you cant see the picture or video.try to connect the wires in the front panel or the back panel.try to connect the wires as per the notes given as audio input,video input etc.
Dec 06, 2008 | RCA G27647 27" TV
Prima HDTV has a black screen on TV, but works fine while Playing DVD
try turning the channel up or down with the tv remote to input 1 or 2 depending on which one is being used for the dvd player. tv should use input 1. dvd should be on input 2.
when turning the channel set it to show the dvd screen, then go up 1. if it doesn't show, return and go down 1.
Oct 22, 2008 | Prima C2012 TV
Can't get to "Video 1" to play DVDs
try turning your dvd player on and then doing a channel search if that does not work just buy a RF modulator and hook up your dvd player to it and it will run on channel 3 or 4 and will switch over by itself when you turn on your dvd player
Feb 26, 2008 | Emerson EWF2703 27" TV
I am stuck on channel 2
some tv's default to channel 2 after being unplugged.since it is a older tv ,the buttons on the remote and the tv maybe worn down.on the tv itself try pushing the buttons down a liitle harder. if you have aux or line in/video inputs,scroll down on the channel button to log into a aux channel for the dvd player.as for the remote try buying a cheap universal remote to see if that works.
good luck
wg
Feb 02, 2008 | Zenith A25A23W 25" TV
DS24205 TV INPUT PROBLEM
if you have a sky remote or know someone who does you could try programming it by using one of these codes, try them all one at a time
Sanyo 0159, 236, 073, 100, 064, 174, 185, 367, 039, 245, 246, 398, 241, 572, 583, 037, 132, 182, 244, 191
Jan 05, 2008 | Sanyo DS24205 24" TV
RCA HD52W59 HDTV Projection Television Logo
59 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
