Question about SanDisk Sansa m230 MP3 Player
It will not do anything
When I left to go to baseball practice my m250 was syncing it's little heart out.. I came home it said it was full.. so I disconnected it and then it said no files.. I attempted to reformat it but now the player won't come on and my computer won't recongize it as a device.. I bought it refubished and have been using it for a couple of months Please help me
  • 8,596 Answers
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on May 26, 2008
Can anyone give me some tips regarding baseball?
If you are a baseball player then these tips are useful for you:-
1. Dedicate yourself to the baseball.
2. Practice every day.
3. Talk with your coach or trainer to strengthen you in baseball.
4. Play up to your level.
If you want to know more guidelines regarding baseball, then you go this youtube channel https://www.youtube.com/user/airplouffe86 where you can get all tips and guidelines regarding baseball.
Sep 27, 2017 | Baseball & Softball
I just purchased a rock candy Wii remote I synced it and got to the home menu However I can't select anything The only button that works is the home button Thereis no little hand that shows up either How...
You say you synced it, but i do not think that it thinks the sync was ok. Read the sync instructions again, at the end of the sync it should give you an indication that it thinks the sync is complete. Do the sync again, does it give you that indication?
Dec 21, 2013 | Video Game Consoles & Games
SansaDisk Sansa m250 (2GB) "Finalizing update"
You need to go to the Sandisk support site and down load the Updater program. Run the updater on your player. This in a way reinstalls the software on the player kind of like reinstalling the operating system. [
Jul 20, 2010 | SanDisk Sansa m250 MP3 Player
Files not deleted from m250
Try this solution:
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release, right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
Good Luck,
I hope this helps
Nov 14, 2009 | SanDisk Sansa m250 MP3 Player
Sansa m250 playlists
First you need to set your Sansa m250 mp3 player to MTP mode:
) Tap your menu button and select "Settings" > "USB".
2) On this screen, make sure that there is a check next to "Auto Detect" and NOT "MSC".
Note: Music that was transferred to the player in "MSC" (Mass Storage Class) mode will not be accessible once the player is put into MTP mode.
However, the music can still be accessed by switching the player back to MSC mode.
To transfer a playlist using Windows Media Player version 10:
- Make sure device is showing as an "audio device" and in MTP mode
- Create a playlist by right clicking a song in the library, add to>additional playlists>new or by saving a now playing list
- Select the Sync tab and click "Sync settings"
- Check "Synchronize device automatically"
- Set "View" to "All Playlists"
- Place a check next to the playlists they want to transfer to device
- Media Player should then sync those lists once you hit OK.
Once you Sync for the first time a new folder "Playlists" will appear in your m250 using Windows Explorer. Once that folder is created you can even use Windows Explorer alone to create playlists, all you have to do is right click on a song and choose create a playlist. Double click on playlist > Reference Tab, on the window you simply drag and drop your songs.
Hope this helps
Aug 28, 2008 | SanDisk Sansa m250 MP3 Player
Sansa m250 not working, need help soon
Plugging it into another computer changed the formatting of the player.. I would format the player from the menu itself, but if that fails:
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Jun 26, 2008 | SanDisk Sansa m250 MP3 Player
Sansa Sandisk M250
Hi XX,
Thanks for asking me to be your Tech Buddy.
For Sansa units, a couple of things you can try:
a. do a soft reset - press on the Power/Menu for 15 seconds;
b. do a full settings reset - Main Menu/Settings/Reset All;
c. do a Format - Main Menu/Settings/Format but all in the internal memory will be erased.
If for some reason your version/model do not have a format option, please refer to this solution posted by another expert, computerrep.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 06, 2008 | SanDisk Sansa m250 MP3 Player
Can not remove files from sansa
Windows Media Player is a little temperamental when it comes to music on the device.
You can manually manage the music from My Computer>Device Name (m250)>MUSIC Folder.
You can drag & drop files onto the device from here, as well as, right click and delete them.
Best of Luck.
Nov 19, 2007 | SanDisk Sansa m250 MP3 Player
My sansa m250 says "not enough space for Music DB Please Free 8MB".. when...
I received the same problem, I thought I had done a Sync by mistake and had used of all the space. I had to re-format the player and start over.
Jan 27, 2007 | SanDisk Sansa m250 MP3 Player
Can't sync file
Try formatting your unit and reinstall your playlist it will work.
Jun 21, 2006 | SanDisk Sansa m250 MP3 Player
SanDisk Sansa m230 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
