Question about Sony Ericsson K550i Cellular Phone
DISPLAY On the right top of the screen two close ball poit pen ink like lines appears. The lines are about 0.5cm long. It appears just near the end of the poited side of the battery meter.
    Problem Solver:
  • 3 Answers
Goto www.sony ericsson hopefully your phone is under warrantee otherwise a new screen could be expensive. parts section is were you need to go
Posted on Mar 12, 2008
Error oxc18a0007
If you observe an INK SYSTEM FAILURE message or 'Oxc' error then the permanent PRINTHEAD may be electrically damaged (unfortunately it is not replaceable; you can verify this by performing the following):
To bypass INK SYSTEM FAILURE message please see the HP Printer Diagnostics Tests file (pdf) for instructions: http://inkjet411.com/?page_id=1813
Verify the permanent built-in PRINTHEADs electrical performance inside this legacy printer model by running the TAP 43 diagnostic test (either one of the procedures below applies to all printers which use HP02 or HP363 ink cartridges): For additional HP02 support information, please visit our HP02 system support page which includes videos of everything mentioned below: http://inkjet411.com/?page_id=1372
A.HP02 ink-series printers with KEYPAD (i.e. keypad numbers 1-9)
Tap 43 PRINTHEAD Health Diagnostics:
Video Procedure: http://inkjet411.com/?page_id=2391
    1.Press * and # keys simultaneously.
    2. "Enter Special Key Combo" will be displayed.
    3.Press 123 to display the 'Support/Service' menu.
    4.At 'Support/Service' menu, click the Right Arrow 3 times until Special Reports menu is displayed.
    5.Select Ok, then click Right Arrow 2 times until the 'print-mech button tap' menu is displayed.
    6.Select Ok ('code = 0' will be displayed); click and hold Right Arrow until 'code = 43' is displayed. Use the Left Arrow if you need to decrease numerical count.
    7.Select Ok. The test page prints.
    8.Check the 4th line at the top of the printed report; an electrically good/stable PRINTHEAD 'Pen Status' will state "Pen Status: Pen OK".........if any other message is displayed then the PRINTHEAD may have failed and may need to be replaced (if part is still available). It is suggested to perform the 'Printer Reset' procedure below to first rule out printer firmware related problem.
    B.HP02 ink-series printer models that DO NOT HAVE a KEYPAD:
    Internal Test Print:
    1. Press the Menu button, press the Right Arrow button to select 'Tools', and then press 'OK'.
    2. Press the Right Arrow button several times to select 'Print Test Page', and then press 'OK'. The test page prints.
    Tap 43 PRINTHEAD Health Diagnostics - See Video Procedure: http://inkjet411.com/?page_id=2377
    1. Turn ON the printer.
    2. Press and Hold the "Print Photos" & "Red Eye Removal" buttons.
    3. Release both buttons.
    4. You will see a new screen that says, "Enter Special Key Combo"... The Key combo is: press and release in sequence the "Red Eye Removal", "Print Photos", and then "Red Eye Removal"
    5. Scroll through the menu by pressing the right arrow button until the display says 'Special Reports'.
    6. Select Ok, then press the arrow button until the 'print-mech button tap' menu is displayed.
    7. Select Ok ('code = 0' will be displayed); click and hold Right Arrow until 'code = 43' is displayed.
    8. Select Ok. The test page prints.
    9. Check the 4th line at the top of the printed report; an electrically good/stable PRINTHEAD 'Pen Status' will state "Pen Status: Pen OK".........if any other message is displayed then the PRINTHEAD may have failed (unfortunately the PRINTHEAD is not replaceable). It is suggested to perform the 'Printer Reset' procedure below to first rule out printer firmware related problem.
    NOTE: Costco USA/Canada, Fry's Electronic's, Microelectronics (along with some Best Buy stores in Canada) provide a top-notch refilling/chip re-programming service today...check it out:
    http://www.costcoinkjetrefill.com/pricing
    For additional and advanced HP printer diagnostics, please visit: http://inkjet411.com/?page_id=1813
    To help solve other HP02 ink-series printer/printing related issues please visit http://www.inkjet411.com
Jul 26, 2013 | HP Photosmart C5180 All-In-One InkJet...
Pen won't write though plenty of ink
There are a couple reasons a pen refill won't start writing right away. The first thing to check is the tip--often there is a bit of glue or plastic over it in order to prevent leaking.
If that doesn't work, then try one (or both) of the following two methods:
1) Place the refill (but not the tip) in some warm water. Heat will allow the liquid in the gel pen to become thinner and flow more naturally.
2) Hook a rubber band around the middle of the pen, using tape to ensure safety, and wind the pen while holding the rubber band on either side of the pen. Make sure the cap is on the pen. When the rubber band is tight, when you pull straight out on the rubber band from both sides of the pen, it should spin very quickly. The centripetal force will cause the liquid in the pen (at least half of it) to move toward the tip.
Make sure you fasten the rubber band to the pen with tape or something similar; otherwise the pen may go flying off at someone nearby. Also, again, make sure the cap is on to prevent any ink spraying out--this is unlikely in a gel pen, but it could happen.
Jun 13, 2011 | Sanford UniBall Gel Impact Rt Retractable...
How do i make all lines ring at certain desks for a norstar m7324 phone?
Programming2_bing.gif is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt,
press the show key (top right arrow).
The display should now ask for an extension number. Enter extension number you wish to program ringing on.
Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear only
press the Chng key till it says appear & ring
press next key (lower right arrow)
The display should say line 002: appear only
repeat the procedure the same as line 001 for the remaining ringing lines
press the release key when finished
Apr 21, 2010 | NorStar M7324 Telephone
I don't know how to change the time on my Chrysler Pacifica's digital clock.
If it's the round on near top of dash take a ball point pen and push the round circle next to the clock. If it's the one in the radio push button that says time then push the h button one the m button with ball point pen just like the top on before the display changes away from the time of day
Nov 04, 2009 | 2005 Chrysler Pacifica
Power went off in our office over the weekend. Now my phone doesn't ring on all the incoming lines. Help!?
Programming is done on M7310, M7324 and T7316 sets.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
Oct 27, 2009 | NorStar M7324 Telephone
THE PHONE FLASHES BUT DOES NOT RING? We had a power cut the other day and since the phones have not rung, just flash? Anyone know why? We have 3 lines coming into the building. The lines have all been...
The 4 top line/feature keys are now used for programming2.gif.
press next key (lower right arrow)The display should say line 002: appear only
repeat procedure for remailing active lines
If your system uses the older programming template,
then Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
the display says A. Configuration
the display will say1. trunk/line data
Press the next key (bottom right arrow) .
the display will say 2.line access
the display will say line assignment
Press the next key 2 times(bottom right arrow) .
The display should say ringing.
Press the show key (top right arrow).
the lines should be listed as appear only change to appear and ring
press Rls when finished
Oct 23, 2009 | NorStar M7208 Corded Phone
How do you program so that when the phone rings you are able to pick up the call without hitting a button. Also when you make an outgoing call and you pick up the phone you get an active line instead of...
Sets that are programmed to ring should automatically have ringing line preference.
press the heading key (top left arrow) til the screen says terminals&sets again
Prime line assignment is also programmed at the terminals&sets prompt.
press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you want to change the prime line on.
The display should say Line Access
The display should say Line Assignment
The display should say Line Pool Access.
Press the next key (top right arrow)
The display should say Prime Line
Press the Chng soft key till you get to the desired line or pool to pick up on
Press the release key when finished
Oct 19, 2009 | NorStar Meridian M7310 Phone
Spin ball. Cursor barely moves on screen.
Have ya tried removing the ball and cleaning the infrared screen under the ball with a cue tip? Also get all the finger grease and gunk out of that area too. You can remove the ball with a pencil or pen, use the dull end of the pen or the eraser end of the pencil, so you don't divot/dent the ball.
Aug 17, 2009 | Logitech Trackman Wheel 904353-0403...
Looks like a crack in the display
such issues have occured in the Past, Please Check if the Crack appears in the BIOS mode.Safemode also Try another Monitor to find out if it is not the wall paper because if it is then the Crack will appear in the other Displa too...
Jul 17, 2008 | Computers & Internet
Sony Ericsson K550i Cellular Phone Logo
49 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
