Question about Kenwood KDC-MP335 CD Player
No sound? i have just installed this unit and used a "no splice " install kit , but it does not produce sound?,,,,it is in a 95 bronco any ideas?,,,,oh and i am a auto tech for 10 years so it was installed correctly , i was just wondering if there was a setting that maybe i didnt set up.
  • Anonymous Apr 08, 2008
    JUST INSTALLED THE UNIT IN MY 1997 EXPOLRER, CAN'T GET ANY SOUND
    Novelist:
  • 100 Answers
My only idea is that there could be a factory amplifier that isn't getting juice. Go to installdr.com and they have the harness pinouts under "quick radio wiring info" in pdf format. Best of luck.
-Andrew Hawkins
Posted on Apr 04, 2008
How to install supco receptacle kit
You turn power off to the unit at the breaker. Unscrew the one or two screws that hold it on with a philips screwdriver. Cut both wires on the old one close to the box of the bad part. You need to splice the 2 sets of wires together, normally using porcelain wire nuts to insulate the raw wire or if it comes with shrink tube, install the tub on one wire before you twist the raw wires together, then slide the tube over your splice and heat it with a lighter evenly until the tubing shrinks covering the raw wire.
Nov 26, 2013 | Supco RR110 Plug-In Receptacle for...
Ive been having issues on & off with my speakers that i installed back in april in my 95 GMC Sonoma. It seems that on some days i can listen to them at a pretty good volume. Then all of a sudden they'
Sounds like a bad ground. Try reattaching it first. Double check any splices also. And the source for the amp, if you tied on to speakers or spliced, double check it.
Aug 09, 2013 | Car Audio & Video
Is a special "powered" module
I would use a Curt 56024 T-Connector Kit. This lets you connect the wiring kit without needing to splice any wires.
May 24, 2011 | Hyundai Veracruz Cars & Trucks
95 full size bronco transfer case 4x4 shift motor froze put new one in now it wont shift right
My brother has a 94 Bronco, we had the same problem upon installation of the new transfer case motor. In our case, all we did was liberally coat all moving parts of the transfer case motor with grease.
Jul 14, 2010 | 1995 Ford Bronco
1986 Ford Bronco Dash/Instrument Light Problem
"painless wiring kit" maybe available for your application. sometimes not so "painless" though
Apr 11, 2010 | 1986 Ford Bronco
How to install a stereo into an Xterra 2004 4wd
Your installation kit should come with a plug and play connector for you vehicle. If not, buy one. No cutting wires or splicing. Sooo much better.
Mar 27, 2009 | 2004 Nissan XTerra
Installing an aftermarket head unit into a 1994 Ford Bronco
are you using and after market harness to go from your bronco to the harness to the new radio. if so make sure all the colors are matched up (e.i. purple to purple, purple/black to purple/black). did the speakers work before the aftermarket unit. Also check the wiring at the oem speakers
Dec 28, 2008 | Scosche Industries Scosche Slc4 Speaker...
Stereo Upgrade in 1997 Sentra
hi there. I am not sure about the speakers. But there is a wiring harness available for a aftermarket head unit. I have a '97 sentra the base model XE version. I have just put in an alpine head unit and you defenately hear the difference even on factory speakers. But you will need 2 kits to install an aftermarket head unit in the car. 1. A dash kit. I got mine from canadian tire for about 20 bucks, it comes with instructions on how to put it together and its straight forward, just make sure u get the one for your year and make of car.
2. The wiring harness. there available at mostly every car audio place for about 10 bucks. again make sure u get the one for your year make and model of car. installing this is difficult so unless your good at electronics get it professionally installed. you have to splice the wires into the back of the aftermarket unit, then the plugs plug right into your existing factory car harness.
hope this solves your problem, the dash kit is easy to put together and install into the car, but the wiring harness is a bit difficult, i had my harness installed for about 40 bucks and u save money if u put the dash kit togehter yourself because thats 1 less thing they have to do. good luck.
Nov 29, 2008 | 1997 Nissan Sentra
Kenwood KDC-MP335 CD Player Logo
50 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
