Question about Samsung SC-D363 Mini DV Digital Camcorder
PlayBack Records well, But at the time of play back horizontal green strips comes..... What to do .... I had tried Head cleaners......but after few minutes the same happens... Please suggest appropriate solution...
Your camera must be malfunctioning(if there digital not like dust stripes) take it back to wear you got it and if you cant do that take it to someone who fixes cameras
Posted on Apr 07, 2008
My Sony DCR-TRV740 camera I just purchased (used), has a playback problem with my 8mm's. When I got the unit I cleaned it well with chamois swaps and MG video cleaner(Recommended by all experts it see
You have a clogged video head. It happens. Do not use the chamois again. Instead, purchase an 8mm head cleaner and give that a try. Only use a brand name cleaner - no generics, and make sure it doesn't come from China!
Nov 07, 2014 | Sony Handycam DCR-TRV740 Digital Camcorder
PL-L50 Pioneer direct drive turntable playing records as if it had a bad belt speed variations in playback, but direct drive has no belts of course. What could be making my records playback speed...
If there is a speed adjustment for 45 and 33 rpm records the contacts or pots need to be sprayed with some electronic cleaner to remove any dust. This is done by removing the bottom of the player and finding the control knobs inside. Electronic cleaner can be found at Radio Shack for around $10 for a large can. It does not take much. Just spay inside the control knobs inside the unit. You will find a small hole where you can put the spray tube that comes with the cleaner. Work the "pots" or knobs back and forth several times to loosen any residue inside the knob casing. Be careful not to shock yourself by removing the bottom. If you are not use to working on electronics it may be better to let someone else with more knowledge tackle the job.
Dec 02, 2010 | Pioneer Audio Players & Recorders
I have a Canon ZR90A and started noticing horizontal gray lines displaying across the screen when it plays back. What is causing this?
The most common cause of horizontal lines during playback is dirty heads/tape path. If you have a head cleaner tape, try playing it for about 5 to 10 seconds and then try your tape again. Repeat as necessary. Try not to run the head cleaner for long periods of time because you may wear down your heads quicker (cleaning cassette is somewhat abrasive). If you do not own a head cleaning tape, I highly recommend purchasing one. Sony (in my opinion) makes the best miniDV head cleaning cassette. We use this brand in our repair shop and they last for years. I have posted a link to the particular tape I am speaking of. Your local camera/camcorder shop may have these for sale.
http://www.amazon.com/Sony-DVM12CLD-MiniDV-Cleaning-Cassette/dp/B0000632H7
Hope this helps you.
www.austintelstarservices.com
Sep 12, 2010 | Canon Video Cameras
Recording and Playback error
I'm not sure what the solution is, but I am having the same probelms, and I would appreciate any help with this since I am shooting a childrens camp and I am fairly isolated and don't have the time to swop cameras or send it to get fixed. I need to know if the recording is fine (video and audio) but the playback is not working correctly...or is it not recording correctly or playing back correctly. The sound cuts out from time to time in playback. Thank you.
Dec 09, 2009 | Sony Dvcam DSR-PD150 DV Digital Camcorder
Got a brand new samsung d381 camcorder and when you playback recordings there are horizontal green lines across the screen and no sound, what am I doing wrong? or should I send it back as faulty? I have...
SOUNDS LIKE YOUR HEAD IS STUCK OR YOU NEED A DRY CLEANING TAPE RUN TROUGH. SOMETIMES WHEN U USE OLD TAPES THEY ARE DUSTY AND THE DIRT CLOGS THE HEAD. TRY A GOOD TAPE CLEANER
May 28, 2009 | Samsung DouCam VP-D5000i Mini DV Digital...
Playback Problem
Hi , video head are need to clean , try ask video store if they have video head cleaner .
Jan 20, 2008 | Sony Handycam DCR-TRV22E Mini DV Digital...
Playback
That's dirty video head! Try to playback new tape for five minutes, do it for 2 to 3 times, this will serve as your videohead cleaner. eject then reinsert then playback, eject again for at least 3 to five times. most camera has a built in videohead cleaner that activates during eject, initial play and reinsert mode. you can even try to play the whole blank tape! thats 1 to 2 hours of playback! If the problem is still there after doing those things, you need pro fix then.
Sep 13, 2007 | Samsung SC-D353 Mini DV Digital Camcorder
Video playback
may still need to be cleaned andy.Sometimes cleaning tapes wont get the dirth out.This is more than likely what is wrong.How old is cleaning tape you tried may be time to try new cleaning tape,.
May 21, 2007 | Samsung VP-W70U Camcorder
Audio meltdown!!
Use a head cleaner tape (available on eBay most likely) and clean the recording heads.
Mar 14, 2017 | JVC GRD650US DIGTL VIDCAM 32X ZOOM 16:9...
Even after using head cleaner, no playback
SOUNDS LIKE YOUR MAIN BOARD IS GOING OUT. NEED TO SEND IN FOR REPAIR
Feb 01, 2007 | Samsung SC-D353 Mini DV Digital Camcorder
Samsung SC-D363 Mini DV Digital Camcorder Logo
64 people viewed this question
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
