Question about Jenn-Air JCD2389G Side by Side Refrigerator
Question...........Reference cooling Fans
I need to know what part of the refrigerator tells the condensor cooling fan, and the cooling fan inside the freezer to turn on........Would this be the circuit board???
My unit turns on the condensor ....but the fan is off...
Also the freezer coils start to get very cold.....but the fan is also off...... Could this a defective circuit board??
    Problem Solver:
  • 8 Answers
Yes, there is usually a relay or two on the circuit board to turn on the compressor and the fan motors. either the points of one or both relays are burned or there might be a burned conductor path on the board. if the latter is the case, there would have to be a reason it burned. in other words, just fixing the burned conductor path wont fix the problem, most likely. unless someone was messing around and shorted something, or moisture shorted something, the latter being pretty unlikely. relays burn with normal use. if it is a relay, you can check and fix it by removing the circuit board (after disconnecting power to the unit first), use a real small screw driver, like for glasses, a soldering gun or iron. remove the relay/relays. they are rectangular usually about 3/4 by 1 inch and black in color, take apart and sand points. one piece cover goes around all 4 sides and the top and youll probably crack the cover getting it off, dont worry, you can fill any cracks with epoxy putty or ......
Posted on Mar 06, 2008
Samsung rs2630Ww. internal refrig fan blower not working and water dispenser not working.
This problem could be caused by the motherboard having defective relays, bad fan motor=> DA31-00103A Fan Motor Sounds like someone will need to examine the fan motor and test the voltage to the fans inside and outside the refrigerator. You will need to have this done to eliminate what the cause is. Both condensor and evaporator fan motors are the same part=> DA31-00103A Fan Motor Let me know and I will explain how to remove, test or replace the freezer/evaporator fan motor, wiring or motherboart. Thanks Sea Breeze
9_16_2012_3_30_31_pm.jpgDA31-00103A
Sep 14, 2012 | Samsung RS2630WW Side by Side Refrigerator
How do you know if a cooling condenser needs to be recharged?
Before you can answer that question the equipment must have clean evaporator, clean condensor, all fans working oiled and up to speed. Drain line in evaporator clean and opened. what refrigerant. let me know I can help. Thanks for choosing fixya. wally
Jul 29, 2011 | Breezaire WKE8000 Wine Cellar Cooling Unit
Ac cools for about 5 min has right level of freon took it to mechanic said it has head pressure of 450 sets off the pressure relief valve
WHEN HIGH PRESSURE RELIEF VALVE OPENS YOU HAVE TOO MUCH REFRIGERANT IN THE AC SYSTEM OR OVERHEATED CONDENSOR,THE COOLANT FANS NOT WORKING,COULD HAVE BAD COOLING FAN RELAY OR BLOWED FUSE.THE ENGINE COOLANT TEMPERATURE SENSOR FAULTY NOT TURNING ON THE COOLING FANS TO COOL ENGINE CONDENSOR OR RADIATOR COOLANT.
Jul 23, 2011 | 2003 Mitsubishi Lancer
True gdm 26 no longer cooling. Internal tem 80 degrees, Condensor fans running, Coil is not showing any frost or icing. Removed cover and cleaned coil and removed dust and dirt. Went out "all of a...
sounds like the compressor is not running. The condenser fans are located at the compressor. The fans in the conditioned space are the evap fans. A refrig usually does not have any device controlling the evap fans, they are to run 24/7. Freezers have other controls. Start there and let me know if I can help further.
Nov 20, 2010 | True GDM-26 Refrigerator
Inside strip of fridge is very hot. cleaned out behind fridge and the coils, etc. fan is barely moving/not moving. any suggestions???
Replace the fan. The strip has a freon line running behind it, and when it is hot, this tells us that you have a dirty condensor, bad condensor fan motor, bad evaporator fan motor, defrost problem, or a freon system problem. When you say your fan is barely moving, I am assuming this is your condensor fan motor, which sucks air through the hot freon lines in the condensor coils, and cools the freon off. If it is barely moving, it can't cool the freon. In some brands a slow moving condensor fan can be caused by a bad main control board. Good Luck, Appliance Specialists
Jan 28, 2010 | Refrigerators
Fans inside freezer will not turn - no cooling - compressor fan underneath is turning
The fans are controlled with a clixon that has a cut in at 5 degrees, and cut out at 20 degrees. If the unit is running and the fans are not comng on then I would have to say you are out of freon. But your condensor fan could be running and the compressor NOT be running which could be a problem with your compressor. Find out if your compressor is running by taking an amp draw. If compressor IS running then you are low on freon. If the compressor is running and your evaporator coil is cold and your fans AREN'T coming on then your clixon is bad.
Sep 26, 2009 | True 72 cu. ft. / 2039 liter Commercial...
I want to know about refrigerater but without compressor ,How it run ,Which technology use it
A refrig doesn't cool . It removes heat which is why the coils get hot . With the condensor mounted on the back of the fridge , air curculation dissipates the heat from the coils . Remember , this heat , is the heat being removed from the inside , by the refrigerant being pumped by the compressor . Some fridges , have a condensor fan to remove the heat from the bottom coils , and to keep the compressor cool . The thermostat , tells the compressor to cut off , when so much heat is removed from inside the ref . The property of refrigerants , is to attract heat , and since aluminum is a good conductor , the evaporator coils inside the freezer are made of aluminum . As the coils get colder , the fan inside the freezer , blows into the refrigerator , and returns to the freezer in a circular motion , thereby cooling the refrigerator . During defrost , wheather it be adaptive or mechanical , is to melt the frost accumulated on the aluminum freezer coils . If too much frost accumulation , the frost will act as an insulation , like the insulation on wire , then the ref. will not get cold .
Aug 28, 2009 | Kenmore 60721 Refrigerator
How do I install a condensor fan on an older refrigerator, top freezer, bottom fridge. The repairman told us the part we needed and we have it but can't tell how to get back panel off or do we go from...
The condensor fan cools the coils and compressor behind the refrigerator . The evaporator fan , fulls ait over the inside coils into the refrigerator section and is located inside the freezer (inside).
Jul 19, 2009 | Refrigerators
Frig stopped cooling. Bad condensor Fan Motor.
sounds like a bad thermostat,that tells unit when to kick on and off.
May 15, 2009 | Maytag Refrigerator Light Switch -...
Jenn-Air JCD2389G Side by Side Refrigerator Logo
54 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Jose Pino
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
