Question about Kitchen Appliances - Others
Bulb change on Revere Projector
Hello, light went out on Revere projector Eight. Uses a CZX 120v 550w I don't want to bust it. What do I do?
Yep. Very Helpful. I also had to disconnect both casings for the bulb and the switches. Then, I had to pull the bulb out of the tower, then push with both hands, ever so slightly, then twist twice to the left, then the bulb came out. Thanks for your help.
Posted on Mar 06, 2008
    Scholar:
  • 52 Answers
You might have to press down on the bulb and then rotate it slightly before pulling it outward. Try both directions. Keever
My slide projector light won't come on. Every thing else works
Check the base where the bulb connects, pins get bent and don't connect to bulb at times
Nov 18, 2014 | Kodak CAROUSEL 650H ELH Light Bulb Lamp...
Revere 8880 bulb is gone and i need a new one. What bulb should i need?
Contact: www.bulbman.com for the correct lamp for your projector!
Good Luck !!
Jul 05, 2011 | Office Equipment & Supplies
How do I change the lamp? Lamp came with no directions. This is a HD72.
Hello there,If your movie projector light bulb has stopped working, there are some simple steps to take to get your movies playing again. The hardest part may be finding the correct replacement bulb. There are so many different models with their own specific bulb. Here are some steps to follow to replace your burned out light bulb.
  • Locate the bulb in the movie projector. You may need to use a screwdriver to open the bulb compartment. Check your owner's manual for proper procedures.
  • Step 2.Remove the movie projector light bulb or lamp. The bulb must be cool before you take it out. Use a tissue or cloth to remove the bulb because the glass bulb is very fragile. Do not throw away your bulb yet, you may need it to help find a replacement.
  • Step 3.Find replacement bulb. The Better Lamps website offers a wide variety of light bulb models. From their homepage select the brand of movie projector you have and using the model number from your old bulb, buy a replacement.
  • Step 4Replace the movie projector lamp or light bulb. Do not touch the bulb with your skin. This can transfer oils from you onto the bulb resulting in a hot spot which can make the bulb burst. Use a tissue or cloth to handle the new bulb to screw it back into place and then replace the cover.
  • Jul 31, 2010 | Optoma HD70 DLP Projector
    Infocus IN72 - blinking RED light
    firdt off, did you reset the lamp counter? did you clean the dust out of the projector? it may be overheating as well. if the lamp looks ok, you may have just blown the ballast. try projector doctor online.
    Mar 03, 2010 | InFocus IN72 Multimedia Projector
    Hitachi ED-S3170 Projector problem
    If the bulb is under warranty then take it back.
    Jan 26, 2010 | Hitachi ED-S3170 Multimedia Projector
    I can not turn the light on my super eight projector. I have changed the projector bulb with no success. All other features of the projector function properly. The projector is made by elmo moder FP-A
    I would use a volt/ohm meter to test the bulbs, If they are known to be good, open up the projector and look for a fuse.
    BTW- Elmo was purchased by Canon many years ago.
    Jan 02, 2010 | Cameras
    Viewsonic PJ550 lamp
    Problem 1) The projector should put out a burst of 7000-15000 volts to start the lamp, and then immediately drop down to 60-100 vlts to keep the lamp lit. It sounds like the bulb blowing took out your ballast, or the ballast going out took the bulb (uncontrolled current = overheated bulb = boom)
    Problem 2) Thats not a problem at all. HID lighting uses an arc to create light, just like welding creates light. Since it uses an arc, and not the heating of metal, there is no filament to test the resistance of. All the bulb is, is a special mixture of gasses and two very durable electrodes, with a gap in between.
    Nov 27, 2008 | ViewSonic PJ550 Multimedia Projector
    Projector problem
    I generally fix this by re-seating the bulb housing. Take it out and put it back in. Look for cracking at the base of the bulb on the mirrored surface. It could be a barely functioning bulb that isn't busted, but can't initialize. I would take it to a shop that has the same bub type in a housing and make a quick switch.
    Jun 20, 2008 | InFocus ScreenPlay 4805 Multimedia...
    Kitchen Appliances - Others Logo
    467 people viewed this question
    Top Kitchen Appliances - Others Experts
    Angel Joseph Jr.
    Angel Joseph Jr.
    Marvin
    Marvin
    Irene Tulloch
    Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
