Computer is blank with nothing but beeps
When I turn my computer on all i get are beeps. I disconnected HD, floppy, CD burner and taken out ram and video card, now I get one long and two short beeps.
Dont know any stats about computer but I do know that the mother board is asus abv-e
Is this enough for anyone to hel pme?
    Scholar:
  • 52 Answers
Make sure the microprocessor fan is working. If so, take fan out and take processor out and then reseat it. This cleans the pins which might be corroded. keever
Posted on Mar 06, 2008
I added a sata harddrive to the pc, it never worked again, I removed the new hd and nothing. When I turn on the machine, I only get several beeps, no signal to monitor, nothing else.... help pls.
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
a computer needs its connections to continue its cycle and to have and end to function
obvisously the beeps are windows searching for some hardware it could be RAM cd/dvd hard drive or motherboard all of these must have secure connections for the computer to work
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure make sure the connections and are not faulty even something as small as a faulty electrical extensions or fan lead can cause this problem or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
May 25, 2011 | Biostar MCP6P-M2 Motherboard - v6.0,...
When I turn on my packard bell ixtreme 6052 nothing appears yet it does see computer but does not even go to bios and harddrive read light remains on and harddrive is constantly ticking like it's...
This could be lots of things (bad HD, bad Mother board, bad RAM,etc...) first you need to narrow down the possible cause, open the computer, take out every thing that can be unplugged (I MEAN EVERYTHING) RAM, PCI cards, VIDEO cards, all storages HD, CD ROM, etc... just leave the CPU and power supply plugged in, than power up the computer and listen for BEEP's if you hear a series of BEEP's this means the CPU, power supply and mother board are GOOD, than (with power OFF each time) re-install the components you taken out (ONE at a time) to see which device causes the system crash... I've seen a modem card causing a system mall function once rediculous but true...
Feb 20, 2011 | Packard Bell Computers & Internet
Unable to see monitor. saying no signal. Will not switch to monitor. When I turn computer on I hear a beep beep beep beep. Then nothing
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your
((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Jan 03, 2011 | Computers & Internet
After power on my eMachines C6537, there is no beep sound and nothing shown on screen. The CPU fan and fan in the box are working. The HD drive spin sounds normal. No problem to open doors of DVD and CD...
Disconnect the power cable open the case and pull the CR 2032 battery out for a minute. That will reset the BIOS. If you have no Beep Codes at all the MoBo might be dead. If this were just a video issue there'd be Beep codes. If there's more than one stick of RAM Pull one try to boot then do same with second stick. if there's only one stick of RAM try reseating it.
Jun 27, 2017 | eMachines C6537 PC Desktop
How do iknow if my motherboard is bad on my computer
Usually, by a process of elimination.
First, inspect the motherboard -- all those round towers are capacitors; any that are leaking (brown stuff) are bad news; any towers bulging at the top, instead of flat, are bad news.
If you turn the computer on, and the fans start to spin, and the disk-drive makes a bit of noise for a short time, then the power-supply probably is NOT the problem.
If you turn it on, and you get multiple "beeps", then it's either the RAM or the video-card.
If you turn it on, and nothing happens, it's the CPU or the RAM or the power-supply.
Disconnect the disk-drive, the CD-drive, the floppy-drive, and all USB devices. If you then turn it on, and you don't get a single "beep",
it's the motherboard or RAM or power-supply.
Test the RAM in another computer.
Temporarily connect a different power-supply to your computer;
if it starts properly, it's your power-supply.
Dec 05, 2009 | Acer Computers & Internet
How to install Linux on Dell Latitiude XPI-CD P166, 48 Mb?
OK, You will need another computer that has a CD burner and a floppy drive. I will give you two links that explain how to do this.
First is for WakePUP:-
http://puppylinux.org/wikka/WakePup
The second is for the Puppy Linux installation:-
http://puppylinux.org/wikka/CreateLiveCDorDVD?show_comments=1
Instuctions are included on these two links but you will need some help. Have a look and post a comment with your thoughts.
Nov 04, 2009 | Dell Lattitude D600 W/XP Pr Notebook
Won't boot
Turn it off.
Disconnect the AC power-cord.
Disconnect all the devices (floppy, disk-drive, CD-ROM).
Remove all "extra"add-on cards (modem, network, TV, 2nd video).
Remove all the RAM.
Connect the AC power-cord.
Turn it on.
Does it "beep", to complain that _NO_ RAM is available?
If not, the motherboard is "dead".
Oct 08, 2009 | Compaq Armada M700 Motherboard
Intel D815EEA: Won't Boot / Blank Screen / Three Beeps
3 short beeps means Base 64K RAM failure.
try to replace the RAM.
Jun 24, 2009 | Intel Desktop Board D815EEA2 (BOX815EEAA2)...
No beeping, no video displayed.
hi, The beep test is notrmally done with the small speaker attached to the computer internally, there could be a problem with the RAM installation check the RAM compatablity with the mother board, give me further details of the make and model of the mother board and RAM , i will try to help you.
Jun 30, 2007 | Abit LG-95Z Motherboard
Computers & Internet Logo
214 people viewed this question
David Payne
David Payne
