Question about Radio Shack Pro-97 Handheld Scanner
WILL NOT TURN ON
WILL ONLY TURN ON WHEN PLUGGED IN TO POWER, THE BATTERYS CHECK GOOD.
  • ROZZERS Mar 11, 2008
    THANK YOU VERY MUCH, THE SPRING WAS DIRTY OR STUCK. A TOOTHPIK DID THE JOB, LOT BETTER THAN RADIO SHACK HELP. THANKS AGAIN, ROZZERS
    Novelist:
  • 142 Answers
There are generally 2 causes for this symptom.
1. The input connector is usually a 3 terminal device. When the plug is inserted into the device, a spring loaded contact is pushed away from another terminal which effectively disconnects the battery section from the device. This stops any electricity from the plug from being connected to your batteries and causing overload conditions. If this spring loaded terminal has been damaged, when the plug is removed from the device it will not "spring" itself back to its terminal and the battery power will not reach the PC board.
2. The battery case (compartment) has 2 wires going from it (internal to the device) one black and one red. If either of these wires has broken off the battery holder or broken off the PC board within the device, it will not power up.
You can also make sure that all the batteries are inserted in the correct direction. Since the unit works when plugged in, you can cross out anything else having to do with the unit.
Posted on Mar 10, 2008
Is there a fuse or breaker ? have good batterys ,no power at key.
I would check the multi-pin connector on steering and also where it connects under the seat between the batteries.
Feb 10, 2016 | Rascal 300 Electric Scooter - Used...
Scooter is fully charged but will only run with charger plugged in
check batterys separate 1 may be dead load test them
Mar 23, 2013 | Health & Beauty
My Mother had me pick up a Mega Motion 111 Travel PAL WITH LESS THAN 40 HOURS USAGE. However, it sat idle for a year and the batteries register stone red dead zero. Anyway, I followed the directions cover...
Sounds to me that all the right checks have been made...
Heres a tech Tip ,9/10 battery chargers cannot bring up a pair of dead battery's.In our case Larry thats whats happening here.There isnt enough power in the batterys to turn your charger on.
Here are some steps in testing your charger ..
1) Take the two batterys out of the scooter
2) Find your self a battery charger that you can set at a trickle charge ,this setting charges at a very low voltage
3) Trickle charge each battery to a least 50%
4) Install the batterys back into the scooter
5) Plug in your charger
Now in doing this your charger should kick on for a while ,dont worry if it shuts off .The batterys being bad is the reason for it shutting off ,we are just testing to see if your charger is working.
This should keep you out of the shop.good luck
Feb 06, 2011 | RTO Mega Motion 3 Wheel Travel Pal Scooter
Pride Sundancer. Batteries will not charge. both batteries test about 50% charge. When I plug charger in to 110v, the needle on rear of unit barely moves. When I turn on key, charge indicator on on dash...
batterys may be to low for charger to pick them back up.Sounds like new batterys to me .dobble check that charger just in case by volt testing the neg and positive wires on one battery ,When its hooked up .then do the other to see if power is getting where its suppose to be. Your checking for volt changed .Battery charger checks out good replace batterys that should do it.
Hope I was of some help have a good day.
Jan 16, 2011 | Pride Sundancer 3 Wheel Mid-Size Scooter
Batteries dead but when charger is plugged in it shows as charged
hello,,, are you sure the batterys are dead ???? do you have an electrical tester to check each battery ???? if it is not running,,,are you assuming the batterys are dead ??? your problem may lie elsewhere,,, a lose wire,,,a wire came off,,,,corrosion,,,,,check all your wires,,,,at the go-switch,,,and the battery,,, and the motor,,, a inexpensive electrical tester at your local hardware store can answer thousands of questions,,,,, good luck,,,feel free to contact me,,,,, JOEL
Aug 22, 2010 | Electric Currie EZIP 500 Scooter
My jvc boombox will not turn on
Check the Internal glass fuse as that might have shorted. You can tell this from the Glass looking Black / Browo or its Shattered.
Mar 23, 2010 | Audio Players & Recorders
My chair wont turn on..batterys are charged
IF you are sure batterys are charged and seated properly.
check for loose battery or wiring conections.
give everything a good jiggle and try again
Jan 31, 2010 | Quickie Wheelchairs Health & Beauty
My daughter has a Kodak Easy share M863 when you turn it on it shuts off right away. Why?
this is normaly flat batterys they only like high power batterys in them
try a better set of batterys first,,, good one's!
Nov 12, 2009 | Kodak EasyShare M863 Digital Camera
My Olympus SP-500Uz won't power up. batteries have been replaced
Check the Batterys again and the contacts inside the Battery Compartment. Make sure you got good Batterys......Are they in correctly ?
Sep 15, 2009 | Olympus SP-500 UZ Digital Camera
Radio Shack Pro-97 Handheld Scanner Logo
56 people viewed this question
Top Radio Shack Radio Communications Experts
john milligan
Steve
xxxxxx xxx
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
