Question about Gateway 7330GZ Notebook
Power Led Problems
I have a Gateway 7330 gz laptop, When I unplug the machine from the the led stays on, even when I take the battery out and replace it. The battery seems to discharge quickly also, what needs to be replaced? John
  • 133 Answers
You need to change the battery
Posted on Mar 06, 2008
Gateway laptop pa6a no power
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Apr 01, 2013 | Gateway Computers & Internet
I replaced the ac adapter on the motherboard of the Gateway NV5207u and now when I try to power it on, won't power on. battery light red
Mar 30, 2013 | Gateway NV5207u Notebook
Laptop will not come on. Indicates that it is connected to power source although it is loose. What should I do? Is it the motherboard or the d/c adapter? I have a Gateway 7330 GZ.
Try another 19volts adapter. If problem still the same and the laptop not powering-on, there's something wrong with the motherboard circuit and not the DC JACK cause it indicates that you connect an adapter.
Apr 05, 2010 | Gateway 7330GZ Notebook
Toshiba A75 - S209 Power LED Blinks non stop, no boot
Here are some troubleshooting steps. From your description, my impression is a bad motherboard.
http://www.fixya.com/support/r3581893-how_to_troublehoot_a_portable_compouter_
Jan 13, 2010 | Computers & Internet
No power. All power cords checked and tight. With
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
Jan 06, 2010 | Gateway MP6954 Notebook
Cannot get my computer to turn on
remove all external peripherals. remove laptop battery. remove ac adapter.
plug ac adapter to wall power socket without the laptop connected check if the ac adapter led will stays on. if yes then connect it to the laptop and check if the ac adapter led turns off. if yes motherboard laptop has problems and need to be replaced.
if ac adapter led stays off without connecting laptop, try different wall power socket, if still ac adapter led is off then replace the ac adapter.
if ac adapter has light stays on then connected to laptop but laptop cannot even power up even the ac adapter led is on then laptop motherboard needs to be replace.
Dec 09, 2009 | Dell Studio 15 Laptop
Dissassemble a gateway 7330 gz
well power button on the plastic or the real power button on the board??? have ya taken out the top plate off over the power button???
Nov 15, 2008 | Gateway 7330GZ Notebook
Gateway 7330 GZ Hinges
Order a front bezel and a hinge kit from any where on the internet for your model
There are screws on the front face cover of your display remove and replace remove the keyboard and there are 3 screws on each hinge to remove.
Aug 14, 2008 | E-Machines M2350 Notebook
Gateway Notebook PC 7330 GZ Power Problem
The most common problem is the plastic that covers the switch breaks. It's a poor design. Take out two screws along the top edge from the bottom near the middle and pry off the keyboard access cover. Then take off the circuit board and you should be able to turn it on and off.
Jul 06, 2008 | Gateway (SL1450-30151382) PC Notebook
Gateway 7330GZ Notebook Logo
79 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
