Question about Maxent MX-42HPM20 42 in. Plasma HDTV
Replace the connection box
Is there an upgrade box to replace the original one? There is no hdmi connection only componet cables. Also is there a owners manual to download. Thanks
  • mets23 Mar 07, 2008
    I see in the owners manual it shows a hdmi connection, but its not there on my tv. I have 2 tvs one connected to hdmi and the other to thru componet and I must say both look good, but the hdmi looks better. More like 3d. One would have to think that in order to add the hdmi you would have to change out the main board and maybe some other parts. Im not really sure though.
    I was hopeing that I could pull the old box off and add a new box, but the manual shows the hdmi is not part of the box at all, but by the pc connection on the back of tv.. They must have made more then one variation of this tv. thanks
    Genius:
  • 1,019 Answers
this might help You:-
http://www.pcworld.com/article/id,126365-page,1-c,televisions/article.html
And This Also:-
http://www.washingtonpost.com/wp-dyn/content/article/2006/07/21/AR2006072100016.html
Hope this is of assistance to you.
Theres not a lot of Information on this, but i,ll keep searching.
Mike @ Compurepair.
Posted on Mar 06, 2008
  • Mike Waldron Mar 07, 2008
    No problem buddy.
    High definition is always the best output signal where lcds and Plasmas are concerned.
    It appears that they made 2 or maybe 3 varients.
    and Obviously different price ranges, you may be able to get a replacement-upgrade on the set.
    Happy-viewing whatever you decide to do.
    Mike @ compurepair.
    Sergeant:
    Champion:
  • 209 Answers
I'm pretty sure that pretty much no Tv's have an upgrade to HDMI.
While looking for a manual I noticed that the version on the maxent website does have a HDMI possibility.
http://www.maxentusa.com/_coreModules/eShopping/productDetail.aspx?productMasterID=27
  • 818 Answers
  • Maxent Master
  • 19,396 Answers
  • Ginko
    Ginko Mar 06, 2008
    As far as I know the only replacement for connection box is always same part , I guess is the same on your tv.
    regards
WD-65734, cable DVR, audio receiver and digital remote: picture goes black for 1-20 seconds and then returns, but audio is stable. Status led and lamp led are NOT on. Any suggestions? Thanks,
well are you using an hdmi cable, cause if you are there is a known issue with the communciations where it will lose communication if you reremove the hdmi cable then turn the box off slide the cable back into the box then turn the box back on it should restore the pic and audio just fine. if this is your fix then its one of three things a faulty hdmi cable or an out of date hdmi cable meaning the version is no longer support for the video production. or it's the hdmi output on the cable box. or it's a poor seat/faulty hdmi input on the tv. easy fix is try to replace the cable or use componet cables (red/blue/green) if this is not the setup of your tv/cable box then i will need more info.
Aug 20, 2012 | Mitsubishi WD 65837 65 in. HDTV
Mitsubishi ws-55805 HDTV Control to HDMI
there is a converter box , where you can connect everything and convert in to hdmi output , you can buy this boxes on the internet or at the redioshack
Feb 12, 2012 | Mitsubishi WS-55315 55" Rear Projection...
I have a samsung 56 inch dlp tv. The audio on the hdmi only works about 10 percent of the time. Any suggestions, I talked to a local electronic store and they said that the hdmi needed to be upgraded.
If you have replaced cable, and it does it on all hdmi inputs, Then it's the hdmi ic on the main logic board. The hdmi ic's are smdi ic's and are hard to replace. Might be easiest to get a new main digital board. You can componet input it has the same resolution as hdmi, You can use that.
Sep 28, 2011 | Samsung DLP HL-P5663W 56" TV
I have a pioneer vsx-30 with hdcp error on the face i see it when a scientific atlantic cable box is connected through a componet connection
Component cables don't have the ability to carry decrypted HD info.
HDCP is "High Definition Copy Protection"...In theory, it prevents you from running the HDMI cable out of your receiver, and into a recording device, thereby recording HD content without a license for it.
HDCP handshaking is done between devices that run HDMI, or DVI.
If you're running component from your Cable box, and then HDMI out to your TV, then the content you're carrying from the Cable box may not be getting decrypted properly when it gets upscaled onto the HDMI port from Component.
IT could also simply be that you're using an HDMI 1.1 or HDMI 1.2 cable, which may not be able to carry the high bandwidth stream of your Receiver and TV.
Please be sure that all HDMI devices can support the same HDMI version, and also be sure your HDMI cable is labled "HDMI 1.x compliant". . .e.g. if your TV and Amp support HDMI 1.2, make sure you're also using an HDMI 1.2 Cable.
Apr 21, 2011 | Pioneer VSX-305 Receiver
The tint keeps changing from a red base to a green base and back again, what could be causing it
Hi Check the componet cables, especially if you are using HDMI connectors. Also if you are using a cable box disconnect if from the tv and run the cable signal directly to the TV to see if problem persists. If all cables are connected tightly and secure, then replace the main digital board.
Jan 24, 2011 | Philips 50PFP5332D 50 in. Plasma...
Best way to hook up all my componets
The best way to use the Denon and get your money's worth is to connect all devices to the Denon using HDMI connects if possible, if you use HDMI make sure you assign the audio if needed.
HDMI from Denon to TV. the Denon will upconvert all signals to HDMI to the TV
Jan 29, 2009 | Denon AVR588 Receiver
Connecting my tv to cable,vcr and dvd
what is the problem not enough connection areas usually you would connect your VCR to your cable box and set channel three on your cable box for the VCR then using one of your other inputs from your TV for the dvd player . Is your DVD player HDMI or Componet?
Dec 28, 2008 | Televison & Video
HDMI connection???
Hi Greg,
Again, if you have a high definition dish box with HDMI output,and a dvd player with HDMI output,please connect them both directly to your TV HDMI inputs.
When watching TV(dishnetwork box).remember to switch the HDMI video inputs.
Same as your DVD player,you need to switch it under your TV video input.
solutiondoct
May 28, 2008 | Denon AVR-2807 Receiver
Using surround sound
Good Day;
Connect HDMI cable to TV then audio cable back to "SS".
Good Luck, big IRISH.
Dec 15, 2007 | Hitachi 53UDX10B 53" Rear Projection...
No right channel audio when using HDMI connection to HDTV
Since it is easier to replace, I would go with the cable box first. Sometimes there are software upgrades for the TV's that fix such issues but, almost all HDMI issues are with the cable box not the tv.
Jan 27, 2007 | Arris DCT6200 DTV Receiver
Maxent MX-42HPM20 42 in. Plasma HDTV Logo
99 people viewed this question
Top Maxent Televison & Video Experts
Jaime Hernandez
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
