Question about GE Ovens
GE JTP11WP F2 fault
I have a GE JTP11WP built in oven. It started giving F2 faults during regular baking and after it was turned off. I pulled the oven, the fan was off. I replaced the fan, reinstalled and it worked fine.Sunday morning when baking muffins for church, another F2 occurred. We turned oven off and back on, and it worked, but seemed to be at a lower temperature. I was going to replace the sensor, but no one could tell me if that was the problem. I am retired and dont want to spend money on something that may not be the answer. I would appreciate any help or advice.
5 Suggested Answers
catriver
  • 878 Answers
SOURCE: F2 Oven overheats
jaz3133, it's probably the temp sensor that has gone bad. You should be able to get it from the front. It's the probe that comes out from the back wall of the oven. You can have someone ohm it out. Should read approx 1100 ohms at room temp. Part number for the temp sensor is WB20K5040. Make sure power is off befor removing the sensor. Catriver..post back.
Posted on Mar 04, 2007
bigg t
  • 640 Answers
SOURCE: Whirlpool oven fault f03 shown
f03 error is a sensor error.you could have taken an ohm reading on the thermistor to see if it was bad.if you replaces the t-mistor then the only other component responsible is the board.make sure all the connections on the board are clean and tight before you replace it.
Posted on Sep 29, 2007
jonniewalker
  • 1031 Answers
SOURCE: ge stove flashes f2 and beeps
F2 is a oven sensor error . remove and or replace the oven sensor if doesn't stop replace oven control
Posted on Mar 31, 2009
  • 11800 Answers
SOURCE: model # JTP11WP...Oven was on
F2 signals overheating or, generally, a incorrect temperature reading. So either the fan or the temperature sensor have failed and you will have to replace it. The beeping is generated by the controller board to notify you that a critical error occurred and the oven will not work until the failed part is replaced.
This is the sensor http://bit.ly/erc2c3
you'll see the rod-shaped temperature sensor sticking out of the back wall at the upper left, held in place with two screws.
Unfortunately the motor for the fan is no longer available, its production has been discontinued. The only source for it are repair shop that have dismembered old appliances.
Posted on Mar 15, 2011
F3 and F2 Errror messages on my GE convection oven
F2 & F3 are fault codes relating to the oven temperature sensor
F2 during bake means a temperature of over 630 deg has been reached
F3 means shorted oven temperature sensor
What it means is you will most likely need to have the oven temperature sensor (thermostat) replaced .
Dec 19, 2010 | GE Profile JTP56 Electric Double Oven
30 " Convection wall oven
F2 During BAKE Control senses oven temperature above 615F-630F If actual over temperature condition occurred: Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature. F2 During CLEAN C ontrol senses oven temperature above 915F-930F If actual over temperature condition occurred: Look for welded relay contacts. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective. Check door lock switches.
Nov 26, 2010 | GE 27" Built-In Double Electric Convection...
Turn oven on to bake when it reaches temp oven cuts off and f2 sh
This indicates the oven has reached an over temperature. You will first need to check the temperature probe for the proper reading. Refer to the tech sheet located somewhere on your stove. It should be around 1100 ohms. If this checks out good the ERC electronic range control will need to be replaced. Here is a couple links that should help
http://appliancehelponline.com/oventempprobe.html
http://appliancehelponline.com/ovenerc.html
Jul 27, 2010 | GE Profile JTP18 Electric Single Oven
Should the fan on my built in electric convection oven come on during normal 'bake' mode (ie not 'convect' mode ?
There is a fan for cooling down whole oven, it can turn on and off during the regular bake or broil cycle to cool down the oven on the outside. It's controlled by its own thermostat, so it will even stay on for awhile when you turn the bake off.
Mar 03, 2010 | KitchenAid KEBC107 Electric Single Oven
Bake element doesn't heat, broil does. When I turn on pad, it goes to 100 but won't heat up
replace element. it is approx 19 dollars. 2 screws in back and then 2 screws holding element to wires. not a hard job
Nov 12, 2009 | GE JKP45 Electric Double Oven
What are Fault Codes F2 and F5 on a GE built in electric oven model JTP45WDW2WW? Is there a site where the fault codes can be accessed?
Both codes most likely relate to a failed circuit in the lock mechanism and or a failed circuit in the temperature sensor circuit.
Sep 17, 2009 | GE Profile JTP56 Electric Double Oven
F2 and F3 error codes in GE electric wall oven
Call GE answer center 1-800-626-2000 ask for tech help, Have you Model # off you data plate ready.
May 09, 2009 | GE JRP15 Electric Single Oven
Ovens Logo
159 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
