Question about Acer AL1716Bbd 17" LCD Monitor
Dvd/cd drive problems
The computer somehow does not recognise the dvd/cd drive. I have been been on the net, but am reluctant to download programs which should fix it. The drive does seem to recognise CDs but not DVDs. I would be grateful for your help.
Kind regards,
Maggie Wright
  • Maggie1234 Mar 08, 2008
    Hi Keever, thanks for your tip.
    I tried to to take the drive out but am not too sure how to do this. Managed to take the side panels off but could not take the top off without having to use force which I am not sure I should do. Would be grateful for some hints. I am sure once I can take the drive out and clean it, it should hopefully work again.
    Also noted when I had a look that a cable with P3 written on it is connected to drive. There is also a cable with P4 on it which does not seem to have a purpose. Could this be the problem.
    Looking forward to hearing from you.
    Thanks for your help.
    Maggie Wright
    Scholar:
  • 52 Answers
Take the drive out and carefully take off the top. The lase shines through a very small glass cover that looks like a small light bulb. Clean the very fine layer of dust off of this glass "eye" and this MIGHT fix your problem. I have seen this happen dozens, if not hundreds of times. Keever
Posted on Mar 06, 2008
  • mack paulk Mar 10, 2008
    The p4 cable might have to be hooked altough sometimes some machines have extra wires that are not supposed to be hooked up. Look for another location labeled P4. Also, punch the machine up on a search engine and you might find a service manual with wiring pictures. Keever
    Also some computers have two drives------one is for cd's and the other for dvd's. If you are lucky this will be the problem.
Dvd not recognised, drive recognised
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
Apr 05, 2012 | NEC MultiSpin ND-1300A (ND-1300A)...
DVD drive recognised but disc not recognised
not sure how its recognised on control panel
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps you
Dvd-rw dvr td 09a ata Drive not recognised by software
if its not recognised in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps you
or
or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
hope this helps
Feb 10, 2012 | Pioneer Computers & Internet
My dell latitude d531 laoptop could not recognise my dvd/cd drive. It is not shown on My computer
Hello!
It may be possible that the connection got somehow loose.
so, try to remove it and then refit it again.
it is very simple to remove the DVD drive and refit it. (it's just a matter of removing one or two screws.)
you can see the Manual that came with it to learn how to remove and refit it.
Please keep in mind that it may Void your warranty, so read the manual before attempting it.
Jun 28, 2011 | Dell Latitude D531 Laptop Computer PC...
My macbook pro doesn't recognize my rosewill usb 2.0 burner. How do I install?
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps
Jun 23, 2011 | Rosewill USB Slim 8X DVD Writer for Mac _...
Dvd RW Burner stopped working after only having it for a year
Check whether the CD/DVD drive has been detected/recognised in device manager. Also check the device status in device manager. Try to install the latest drivers for CD/DVD drive will solve your problem.
Dec 15, 2009 | Gateway (1531356) DVD±RW Burner
DVD RAM drive does not recognise DVD-R discs
As the prices on these items go down I am afraid the quality sometimes goes down as well. I have personally had 2 DVD burners fail on me in the past 5 years. You can contact LG if it is still under warranty or just replace it. The problem with lower end electronics like burners these days is the price to repair it cost 3x or higher than the cost of a brand new unit.
Aug 21, 2009 | LG Computers & Internet
DVD WRITER IS SUDDENLY NOT RECOGNISED & THE DVD ICON IN 'MY COMPUTER' IS MISSING.
Use the net to download driver. Then you can try using your drive. Otherwise your drive may have gone defective itself not allowing windows to see it.
May 12, 2009 | Televison & Video
Hi there, my cd/dvd re-writer is not working on my Dell Inspiron 5100. Not been on this computer for a few years. Just had to take alot of viruses off. I think it's a software problem that causing the...
XP home should automatically detect and install the device.
**** Please Do-Not-Rate This Post, Until Your problem Has Been Resolved ****
There are a few concerns here:- if the drive has been virused, it may have been instructed to shut-down or corrupted the Drives Logical Board.
If you go to My Computer/Control Panel/System/Hardware/Device Manager.
See if your drive is recognised There, DVD/CD Rom Drives.
If it isn,t Click the small screen icon, top of page " Scan for hardware Changes " this should detect the drive if it,s recognisable by the system.
If it is, right click/Properties. And see if the device has any conflicts ( usually noticed by a yellow Triangle/exclamation Mark. Or drivers not installed.
Failing this, you can go into the systems Bios Screen. F2 at bootup. and see if the device is visible in there. And whether it,s enabled.
If none of this works, please mail back here.
If you rate this solution, without fixing your problem. i may be reluctant to assist you further.
Mike @ cmpurepair.
Mar 14, 2008 | Televison & Video
Read only cd-r not dvd
Have the same problem, it used to work and suddenly it wont do it anymore. I guess this is due to windows XP updates. Windows says that the driver is up to date and I also installed the latest firmware. I am using Nero 7 to burn. I had troubles before but somehow fixed it. Now when I insert a DVD (data) and try to open the dvd drive the whole computer hangs. The content shows for a moment before the computer freezes so it IS in the DVD.
Oct 13, 2007 | Samsung SH-S182D DVD RW Dual Layer Burner
Acer AL1716Bbd 17" LCD Monitor Logo
50 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
