Televison & Video Logo
Posted on Mar 06, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
TV No Picture
LCD flat screen picture will run for 20-30 minutes and then no picture. Sharp LC 32D40U 2 years old.Sound live and channels will change (no channel indicators)
  • mbarnwatt Mar 06, 2008
    Thanks for the suggestion keever, but the vents are clear and used vacuum to blow and suck any detrius from the interior... No Joy.
  • mbarnwatt Mar 14, 2008
    Just an update...
    Called Sharp, then an authorized service center. Tech said it was the lamp behind the display, the replacement display was $1900.00 if available but it was not available...
    Have a call into Sharp asking what they can do to assist, will relay final results on this forum.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 15, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1669
Points
Had the same problem and glad I found this site. Picture would go black, but sound and faint image would still be on the screen if you looked real close. We keep thinking we pushed a wrong button on the remote and changing a setting.
Took the back of the set off and a little 3 or 4 wire connector was basically unplugged near the power input. Plugged it back in, put on the cover and back in business.
Thanks for the helpful posts. The economy is bad, but a dead TV is worse!
-TB
slowxturtle
Level 1:
  • Posted on Dec 02, 2008
slowxturtle
Contributor
Level 1:
Answers
Questions
0
Helped
1669
Points
Commentor on March 07, 2008 seems to have the fix. My LC-32d40u has had the same problem for a year now. To temporarily fix it, I turn off the TV and Bang the back of it really hard. Then turn it back on and it will work again for a few more hours. Which basically creates friction on the contact points and creates a better connection. I opened up my TV today to try cleaning the contacts as mentioned above. The "ground points" where the inverter board met the plate, as the commentor mentioned on Mar 07, 2008, were worn out and turned from a silver to a black on those spots. This is probably due to me banging the TV and creating friction that rubbed some material off the plate.
I put the tv back together and it turned on okay. Will have to check next couple days to make sure, but this is probably the reason for this problem, not overheating. I do not think a new inverter board needs to be replaced since it seems to be only a temporary fix of a few months from other commentors. Changing out the inverter board probably creates better contact temporarily and so fixes it sometimes or maybe just temporarily depending on luck.
  • slowxturtle Dec 02, 2008
    Forgot to mention that I do not think it is due to overheating since the problem occurs the first time I turn on the TV that day and not after it has had a chance to warm up.
Anonymous
Level 2:
Sniper:
  • Expert 53 Answers
  • Posted on Mar 14, 2008
Anonymous
Expert
Level 2:
Sniper:
Answers
53
Questions
0
Helped
112698
Points
148
Try shining a very bright flashlight on the screen. Can you see the image (but VERY VERY dark)? If so, either the inverters or lamps are bad, which are only sold with the LCD Panel as an assembly, which is VERY VERY expensive. Suggest getting a new TV. The LC32D40U was a bad model.
Anonymous
Level 2:
Scholar:
  • Expert 52 Answers
  • Posted on Mar 06, 2008
Anonymous
Expert
Level 2:
Scholar:
Answers
52
Questions
0
Helped
29317
Points
113
Sounds like overheating. Is it physically mounted according to instructions so that it can "breathe"? Keever
  • Anonymous Mar 07, 2008
    I've repaired hundreds of tv's, but got out of that type of work before flat screens came along, so it will difficult for me to help you. But it does seem highly probable that something is overheating. Capacitors are infamous for "leaking" and thus running hot after having been on for a while. Many chips will also run hot after working properly for a few minutes.
    Here's what I would do if I were you. Take the back off tv and replace it using only about 2 or 3 screws. Then turn it on and as soon as it shuts down, UNPLUG THE TV and quickly take the back off again and using one of your fingers, touch all the capacitors and chips one at a time to see if you can find the hot one. Polarized capacitors are the ones that run hot. These are round and will be taller than they are wide, sort of like a cattle grain storage bin. They will have two pins soldered into the board. Touch all the biggest ones first, then the medium sized, and so on. Then touch the biggest chips and the big transistors with three pins. The components mounted on metal "heat sinks" are supposed to run pretty warm, but nothing should be REAL hot, so if you find something really hot, then replace it. Do you have a service manual or schematic by any chance? Keever
Anonymous
Level 1:
  • Posted on Mar 22, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1669
Points
9
My 32D40U would turn on for 5-10 seconds (Please Wait would appear) and the screen would go black. Sound Normal. It would also sometimes do this after running 5-10 minutes. I read somewhere that the inverter board would come loose and lose proper ground. I took the set apart, removed the board, and cleaned up the grounding points. I reassembled using some copper paste on the ground points and LockTite on the screws. I used some contact cleaner on all the connectors going to the board. I noticed two cables that are covered with copper shield tape where too tight at their connectors and repositioned the tape to give them some slack. The problem hasn't occurred since the fix.
No picture no sound but pulls up menu for channels
I would check the condition of your aerial or television reception equipment. If any of this has been damaged, come unplugged, fallen from rooftops etc these kind of issues can occur.
Sharp lc-26dv12u about 2years old. All of a sudden
Sounds like the Main mother board is the problem. When the processor chip overheats, the programming information passing through the chip slows down. Most cases, replacing the main mother board will fix the problem.
2answers
Sharp LC-32D40U shows no video few seconds after turning it ON
Modification of the inverter unit usually takes care of this problem.
1helpful
Blank screen with other displays still working
1. By View your DVR, Do you mean you can actually see a picture?
2. By "Switch Channels", are these channels being tuned by the TV Tuner?
Your LCD Panel is OK Since you have a Picture (input display in right corner)
If you can see a picture with your DVR, VCR, DVD or any external source then your TVs Video Processing is OK....if not you will probably need to replace the responsible PWB for this function
If you can see a picture with the external sources and only the TV's Tuner is not showing Video, The PWB responsible for Tuning within the TV should be replaced.
Also, if all problems are associated with only the DVR (I assume this is Sat or Cable), then it is most likely that this device is not functioning properly. Possibly lost signal or deauthorized.
32 inch Sharp Aquos is less than a year old... I changed that channel and the picture was green or gray... i changed it again and got a normal picture once but now all channels are looking blank with a...
Contact Sharp to locate the nearest authorized Sharp servicer. Sharp Aquos servicers have to give Aquos TV top priority. Sharp provides very good and fast serice on these sets.
New TV won't ''talk to'' old VCR
using the magnovox remote, reprogram the vcr's channels. set it up to use cable not air. when the vcr was unlugged it lost it's channel memory. don't buy new cables, you're getting a picture and sound so that means your rca cables are ok.
Sharp Aquos LC-32D40U-picture goes off at random times
The bad news,your set needs a new inverter board installed.With persistence to sharp,you might be able to get them to pay for the parts.
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
