Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Can I repair this problem myself?
I have never worked on a TV before but I am a high level mechanic. Would you recommend me change the blue CRT on this set myself?
  • RCA Master
  • 8,617 Answers
You could do it but you would need the service manual to be able to do the tube and lens alighnment. You have to align the tube and lens before you can adjust convergence, and if you dont alighn properly you will kill your convergence ICs trying to compensate. If you would like me to post a link where you can get the manual let me know.
Posted on Mar 06, 2008
The video is frequently replaced by blue screen. is the IC gone?
To get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Apr 03, 2015 | Televison & Video
My Sony WEGA kv-32" TV
The "D" board is the main circuit board assembly containing most of the set's power and deflection circuitry. It's the board that typically causes most of the problems because there's so much on it. Unfortunately, this board is no longer available from Sony as a part, and must be repaired to the component level. Many shops don't want to (or can't) get into that depth of repair, so they quote a high price on board replacement. There is no single part you could order to repair this board yourself, I'm afraid. There are some companies in the business of repairing boards, but you're still looking at $200 to $300. With the price of a 32-inch LCD set now around $300 to $400, there's no point in trying to fix a TV when it's just a few dollars more for replacement.
Jan 01, 2011 | Sony FD Trinitron WEGA KV-32HS500 32" TV
I have a Samsung rear projection tv, the picture is faded and the colors are not crisp or clean cannot watch it like this what do you think the problem is?
If this is a CRT-type rear-projection TV, the CRT coolant fluid is probably broken down. It's supposed to be clear, but after a long period of TV operation, it turns a yellow-brown color. If you unplug the TV and remove the back, you can look into the tops of the three picture tubes. They should be a clear red, green or blue color, with no yellow-brown tint.
CRT coolant can be changed, but you need to be very good at mechanical work to do it. Besides the safety considerations (picture tubes and other parts may carry a high voltage charge even when the set is unplugged), spilling broken-down coolant on electronics is usually disastrous, so you have to be very careful.
LCD panels used in projector applications may lose contrast if they are overheated (this can be caused by failure to keep the vents clean as recommended in the owner's manual).
You would have to provide your set's model number to get more specific information.
Oct 27, 2010 | Samsung Televison & Video
My tv looks like im in a fog what can i do to fix this? It appears to be heavy on the blue side also. 51MP392H/17
You need to change the glycol in the Blue CRT. To be honest... this is one of the most miserable jobs you could ever want to do. You need to pull out the blue CRT, remove the drain plug, empty the glycol, disassemble the mechanical seal, clean the scale off the CRT and C lens, reassemble the mechanical seal, refill with glycol, install the drain plug, install the CRT in the TV and then, re-converge the TV. Sound fun?.. it's not. The first time I did one of these the glycol leaked all over the place and destroyed the TV. Also, glycol is just nasty... slops up your hands and your tools and your work area. If you tackle this, good luck to you. You can get the glycol from MCM Electronics. I hope this was insightful, best wishes.
Apr 24, 2010 | Philips Magnavox 51MP392H Rear Projection...
The screen is fine but suddenly changes to blue and red speckles making it almost impossible to see the picture. We tried adjusting the wires but that no longer works.
Color filter circuit of your TV, seems to be intermittent. You can not solve this problem your self, so it is recommend to take your TV to service center.
Good Luck
Rating the solution is highly appreciated.
Mar 07, 2010 | Sharp 27N-S300 TV
Samsung CRT HDTV - Red, Blue, but No Green.
If their is no green chances are the chip for RGB on the tubebase has packed up its usually something like a TDA 6107Q
Jul 06, 2009 | Samsung TXJ3676 36" TV
Philips 60
First of all,this is a major labor intensive repair on Philips TV's changing the blue CRT because the new CRT does not come with the coolant that is sealed between the lens and the tube.If you have never done this type of repair before you should not attempt. Changing the convergence board is one thing (you can solder in two STK392-120 IC's and repair the board instead)
but changing the CRT's can be a nightmare.If you are brave go to PARTSTORE.com and get the parts $600+ (I would order the service manual too...you will need it)
Aug 27, 2008 | Philips 60PP9202 60" Rear Projection...
Sony KP-51HW40 51 blue crt
Check the info from this website on how to remove shorts from CRTs. This is not a DIY for sure.
The CRT you can remove it yourself, just be very careful when removing the high voltage wire that is connected from the HV trippler to the CRT anode. The CRT anode cable stays with the CRT.
Good Luck.
May 08, 2008 | Sony KP-51HW40 51" Rear Projection...
JVC TV
On projection TV's there are three tubes red,blue and green. It sounds like the green driver transistor is open. Check for loose connections or cold solder joints on the crt board at the back of the green tube.
Apr 07, 2008 | JVC AV32F476 32" TV
Tv goes pink....
I cannot, in good faith, go about recommending shops, as I am not in the referral business. However, Ruckers TV in Arlington has done me right in the past....accordianman
Feb 09, 2008 | Televison & Video
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
57 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
