Question about Panasonic Palmcorder PV-DV52 Mini DV Digital Camcorder
Blinking power light
I own a panasonic palmcoder pv-dv52 and just today discovered that the power light blinks and refuses to play tapes. I have read the other posts concerning the same matter along with the possible solutions posted (taking off the cover and then replacing it, without touching anything inside). Have you any solutions other than this, or will this suffice?
  • thomasstunts Mar 13, 2008
    This is my own post that I will answer. I was leery about taking off the cover as recommended by other folks, so I posted this concern to see if anyone else would have a different answer. No one else posted, so I figured I would give it a try. Just like the others testify, taking off the outside cover (actually, I didn't even take it completely off, I just lifted it maybe a half inch), PEEKING - NOT POKING, then putting the cover back on, actually does work! For how long, I don't know, but if the light starts blinking again, I guess I can just do this again. I hope others find this helpful should they stumble across this : )
    Habit-Forming:
  • 187 Answers
Call panasonic if there are that many posts maybe it is a recall issue and they should know about it.
Posted on Oct 03, 2017
4 Suggested Answers
SOURCE: Panasonic PV-DV53D
I was having the same problem. here's the solution that worked for me - should do it for you as long as your camera stays on long enough. 1. Take out the tape - mine stayed on longer (without blinking) when the tape was not in. 2. press the menu button (near the viewfinder) 3. Use he wheel on top next to the viewfinderto scroll through the choices 4. Choose "display setup" by pushing the wheel in 5. Choose "C. Rest" by pushing the wheel in 6. Turn camera off 7. Next time you turn camera on you should be able to view tapes and record. hope that helps!
Posted on Nov 01, 2006
SOURCE: Panasonic PV-DV103D
This is actually a problem with the ribbon cable. When the tape is put in and the tape door is pushed shut it jars the internal ribbon cable. Years ago I found this tip online & it fixed it!
Quote
"Ok, here goes, I had the exact same problem on my pos Panasonic pv-dv203d. After many times of taking it apart and many frustrating calls to Panasonic, I've finally figured it out, I hope it helps on your cameras.
Remove the bottom plate from the Camera (four screws, plus one near the LCD screen).
Pop off the bottom plate of the camera
Look at the ribbon cables carefully, and make sure they are all snug in the plugs. The tape transport mechanism may move them out of place."
Every now and then our will start to act up & hubby unscrews the bottom of the camcorder (Panasonic PV-DV203D), gently maks sure the ribbon cables are in place, replaces the bottom plate & it's worked for us every time. i hope this helps!
Posted on Jul 12, 2008
I have a panasonic pv-df205, the timer light is blinking and I can't get a picture.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Jul 28, 2014 | Panasonic PV-DF205 TV
Tip
Recording or playing back
for all of you who have this problem. You can't record or playback anything and your power light is blinking. Just turn it on and off on and off. I did this for about 5 minutes. Just turning off and on and then trying to play or record something then took out the tape and blew with a duster for cleaning your keyboard and that worked. This has happened before and well that worked for me. Hope it helps anyone outthere.
on Jun 15, 2007 | Panasonic Palmcorder PV-DV103 Mini DV...
Vcr hi-fi light blinking
You just have a dirty main video head. You can get a head cleaner tape or you can buy a tin of Servisol Video 40.
To clean with the Servisol, remove the top cover of the VCR. You will see a big shiny video head. Spray that head with the cleaner. You can also wipe it over with a cotton bud if it is very dirty. It's a good idea to clean all the surfaces that the video tape touches. If you don't know which, when you first take off the cover with the VCR on power, put a video tape in a press play then watch where the tape runs. Eject the tape, then clean with the spray and a cotton bud. You can even spray the cotton bud and then clean with that if you are not happy just spraying into the unit.
Make certain that the sprayed areas are dry before trying a video. It dries very quick anyway.
Jan 29, 2014 | Panasonic Pv-7451 Omnivision Vhs Vcr W/...
Tape will not eject
Probably tape stuck, unless u know what u are doing take it to a repair shop. Fixing it takes a minute
Dec 31, 2013 | Panasonic Palmcorder PV-DV52 Mini DV...
Red power light flashes twice and unit will not record. I will not play a tape, none of the tape keys work (rewind, fordward, or pause, etc). I do get a picture in both the vcr and camera mode but the tape...
That is caused by leaking capacitors. Not a lot the layman can do about it except purchase a new camcorder or send it to Panasonic for repair, if not obsolete.
Apr 23, 2017 | Panasonic Palmcorder PV-DV52 Mini DV...
Powers off
the capstan motor of the camera is not running that why the power display is blinking and when you eject the tape there a portion of the ribbon that left..it is a poor connection of the capstan motor to the main board of the camera...
Dec 15, 2007 | Panasonic Palmcorder PV-DV102 Mini DV...
Camcorder is not recording
the capstan motor of the camera is not running that why the power display is blinking and when you eject the tape there a portion of the ribbon that left..it is a poor connection of the capstan motor to the main board of the camera....
Dec 13, 2007 | Panasonic Palmcorder PV-DV53 Mini DV...
Blinking Power Button
Try removing the case screws from the right side of the camera. Soak the screw in Electronics Cleaner (you can find this at Radio Shack). Handle the case carefully as there as some wire and a wire tape connector attached to the case. Carefully replace the screws and power up. Remove the battery before you start removing screws. This seems to have fixed mine for now
Nov 18, 2007 | Panasonic Palmcorder PV-DV52 Mini DV...
Panasonic PV-DV103D
Quote
Mar 12, 2007 | Panasonic PV-DV103 Mini DV Digital...
Panasonic Palmcorder PV-DV52 Mini DV Digital Camcorder Logo
78 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
