If you are refering to the roller underneath, the belt nees to be replaced. Simply remove 4 bottom screws and then the roller, Place new belt on roller and thenon motor shaft, pull belt with the roller to install in position and install bottom plate.
This is an older model Steam Cleaner. The upper tank, fill with hot tap water up to the fill line, then add 5 ounces of carpet solution to the water using the upper cap to measure. Make sure the lower letank is secured and turn it on, tilt the handle back, pull trigger to release solution to floor going forward, then release when pulling back slowly to extract. I am not sure if the manuals are available online, however you may be able to locate a Hoover dealer which may have a digital copy. They can be found through the hoover.com
