Question about Kenmore 62602 Electric Dryer
Kenmore dryer making excessive noise
Dryer started making screeching noises over the weekend. You'll hear it for a while and then it goes away. Now it won't turn on. I think it's only 4 years old. Could the motor bearings be shot. I am going to take it apart in the morning and check it out.
  • 1 more comment
  • mzcutup Mar 12, 2008
    My dryer (110.62612101 in which I couldn't find on here; 5 years old) did the same thing yesterday and completely conked out after about an hour of doing so. Prior to that, I have been having to manually turn the dryer off for about 2 years now because it would not turn off or advance towards off on its own. Other than that it worked fine, which is why I'm trying to see if it will be cheaper to figure out what is wrong with both problems and fix or get a new dryer.
  • curlymo Mar 30, 2008
    I have the same problems
  • calvinc Jun 16, 2008
    Thought it was the bearings but it was the rollers. Everything new inside so it should last a while longer.
    Cal
    Problem Solver:
  • 14 Answers
It has rollers that support the drum that sometimes go bad.. I have one that got a penny stuck bewtwwn the drum and the seal and that was all that was wrong.. pull the dturm and see what you find.. rollers are cheap.. replace the belt at the same time..
Posted on Jun 13, 2008
  • 55 Answers
Likely the main drum bearing in the back. I have seen these go bad, and loud squeaky noise tells you. You can get a new main bearing and replace. It is in the center of the back of the drum, accessee through back panel of dryer usually.
Posted on Mar 10, 2008
My Kenmore 800 series gas dryer makes a very loud screeching sound when I start a drying cycle it can last up to 15 minutes what do I need to do
The loud screeching noise is either the belt pulley or one of the 2 wheels that support the drum. There's quite a bit of disassembly to reach them.
Aug 11, 2017 | Kenmore Dryers
My Kenmore Dryer, Mdl #86681800 won't start when hot
The most likely reason it that the electric motor is failing; the thermal protector on the motor is resetting after the motor cools down. The buzzing is due to a locked rotor in the motor while it is overheated.
Another much less likely possibility is that there is excessive drag on the drum causing the motor to overheat because it is working too hard spinning the drum. Excess drag is due to worn rollers, etc.
Try rotating the drum in the CORRECT direction by hand and see if it seems really hard to rotate. You can try this on a friend or relatives machine to see how much drag is normal.
To determine which way is the correct rotation, just start the dryer, open the door and look fast! To test, just turn it in the same direction as it was rotating before it stopped.
Mar 09, 2013 | Kenmore Dryers
Kenmore elile electric dryer screeches and now it wont run
Worn out. No solution to keep it running. Had a dryer I had to trash that did the very same thing........
Aug 27, 2012 | Dryers
The dryer makes a scraping noise when it has a full wet load. if you lighten the load by about half the noise goes away, except when it first starts up.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 07, 2011 | Kenmore 600 6965 Electric Dryer
Dryer is making a loud screeching sound
heatman101
Asker
Jan 05, 2011 | Kenmore 800 7982 Dryer
My kenmore elite HE4 electric dryer is making a screeching/high pitched noise. It would dry the clothes, but I can't stand the noise. Before the noise started the dryer would occassionally not start if...
Hi- The bearing(s) might be worn or the drum wheels sticking but if it is not starting sometimes you most likely have a motor issue. You'll need someone to come out and take a look at it.
Sep 24, 2010 | Kenmore Elite HE4 Electric Dryer
Screeching noise
heatman101
sdgs
Jun 18, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Kenmore 62602 Electric Dryer Logo
1,573 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
