Question about Microsoft Xbox 360 Console
Internet if you connect u 360 to your wan slot would that damage you 360
Todo
Posted on Mar 06, 2008
I got a two day gold pass and a xbox 360 i also got tmobile broad band internet on my pc so how do i get started with xbox live without an adapter or do i need an adapter
Requires a Router/Switch
(2) ethernet cables
Using your PC as the main Internet Provider, connect one cable from the PC's ethernet jack to the WAN jack/port of a router. Next hook up your XBox to one of the wired 1-4 jacks/ports on the same router with the other ethernet cable.
Mar 09, 2011 | Microsoft Xbox 360 Console
Cant connect to router
Hi this is priya .......
got your issue .....
If you are using a belkin router please try with the following steps
Step 1: Connect modem>>router
Step 2: Check whether you are able to go online
step 3: If you are able to go online connect the modem to the yellow slot on the router and then connect your computer to any one of the grey slot
Step 4: Open a new internet explorer page and type http://192.168.2.1
Step 5: You will get a router set up page
Step 6: Check towards the left column below Internet wan click on connection type and it will ask for the password and leave it blank and click submit
Step 7: Select the connection type as dynamic and hit next
Step 8: Below host name please click on change wan mac address and then hit submit
Step 9: Your status will be connected
If you have any issues please contact Belkin technical support 18002234456
Thanks .....
With regards.....
Priya
Oct 20, 2010 | Computers & Internet
My pc has room for one ethernet cable and its already taken to a router box. i have no idea what its for but now there seems to be nowhere to hook up my 360. i want to hook up for xbox live and netflix....
Simply put
You need to plug your xBox 360 into the Router not the PC.
The Router should have more than one ethernet slot. (That is what is generally meant by the term Router).
Therefore:
1. Plug one end of the Ethernet cable into your xBox 360.
2. Plug the other end of the Ethernet cable into an available slot on the Router.
If your Router is constantly connected to the Internet then this should solve the problem. If it is not, then connect to the Internet via your PC and then when the internet is on the xBox should find it.
Hope this helps. Regards,
Feb 09, 2010 | Microsoft Video Game Consoles & Games
Does not connect to the internet
connect the modem to router in the modem slot
connect ur computer to the wired or the pc slot
1. open ie or firefox
2. type 192.168.2.1 in the address bar
3. click on restore factory default under utilities on left side
4. password blank click submit
5. then click mac address on left side under internet wan
6. password blank and click clone then apply changes
7. rite top corner the internet status must be connected
Feb 08, 2010 | Belkin (F5D7231-4) Wireless Router
My laptop can't find a connection to m router.
Step 1 : Connect modem - Router - Computer ( Wired )
Step 2 : Open router setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left side under internet WAN click Connection Type
Step 4 : leave the Password Blank and click submit
Step 5 : Choose the connection type as dynamic and click next
Step 6 : Leave the Host name blank and click apply
Step 7 : On the left Under Internet WAN Click MAC Address
Step 8 : Click Clone and Click Apply changes
Step 9 : If the Internet status on the top right is connected
Step 10 : Then check if you have internet
Step 11 : if not Then unplug the Power Cable from the Modem And the Router
Step 12 : Plug the power Cord to the Modem
Step 13 : Wait till all the lights are on
Step 14 : Plug the power to the belkin
Step 15 : Check the color of the light in the belkin
Step 16 :If green then Check if you have internet
If not working then call belkin
Dec 29, 2009 | Belkin (F6D3230-4) Router (F6D32304)
Router cannot connect to the internet
I assume you are following my instructions.
Did you connect the LAN cable from the DSL or cable modem to the WAN or Internet port on the wireless router?
To test if the modem is working properly, connect the LAN cable from the modem to the LAN network card on a computer and see if you can access the Internet.
If if doesn't connect to the Internet, contact your ISP and they can check the connection to your modem to determine if it is working properly.
Dec 03, 2009 | Linksys WRH54G Wireless Router
Problem with RV042 linksys router
Ah Wan 2 doesnt like to receive a DHCP address you will have to get static Ip addresses
Jul 11, 2009 | Linksys RV042 VPN Router
Cant connect to xbox live need an ip address how do i get one
When the SurfBoard modem is powered up and connects to the internet on the WAN interface, it automatically gets an IP address from your ISP. When another machine is powered up and is connected to the modem via a USB cable, it is automatically using the WAN IP address to communicate with the world. If it is connected via the Ethernet connection, the modem automatically issues it its own IP address for use on the internal network via DHCP. The modem's internal Ethernet connection is 192.168.0.1. The next machine powered on will normally get an IP address of 192.168.0.2.
May 30, 2009 | Arris SURFboard® SB5101 Cable Modem
WAN
The wan port is what you hook your modem to. Wan stands for Wide Area Network, which in your case is the internet. Your house with your 2 pc's and networking equipment would be considered a Lan, local area network.
The 4 ports on the router are switch ports, when you hook the modem up to the switch instead of the wan port the modem will only allow traffic from one physical, (MAC) address to pass through, this is why only one of your pc's can access the internet. The wan port on the router has its own MAC address, so the modem will associate with the wan port and trust all traffic that comes from that port.
Finally, after you have connected the modem to the wan port, pull the power cord on the modem then plug it back in to reset it, this will force the modem to orient with the wan port.
Jun 01, 2008 | Computers & Internet
WAN
WAN s not for your use now. dont dig with it bro..
tel me one thing.. what kind of connection you have? does the modem stores the password or you type the pass each time manually to connect to internet
Dec 25, 2007 | D-Link DI-704P Router
Microsoft Xbox 360 Console Logo
15 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
