Power Acoustik LT-980/2 Car Audio Amplifier
Problem for Power Acoustik LT-980/2 Car Audio Amplifier
MY AMPLIFIER?
By SEXYCARLOS on Mar 06, 2008
MY AMPLIFIER DOESNT TURN OFF WEN I TURN OFF MY CAR, IT JUST STAYS ON. I THINK MY REMOTE IS CONNECTED WRONG BUT I DONT KNOE WERE ELSE TO CONNECT IT.
Best Solution
posted on Mar 06, 2008
Helpful)
c renner
Rank: Wiz
Rating: 89%, 65 votes
Try removing the remote turn-on wire from the terminal on your amp. If that shuts it off then you can use either the remote turn-on output from your head unit, or any fuse at your fusebox that only comes on with the car on.
If that doesn't shut it off the amp has an internal short and should be replaced or you could put an easily accessible fuse in its power wire and pull that when you wanted to shut it off.
Was this helpful?
Yes
No
Solution #2
posted on Mar 23, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
YEAH THATS CUZ YOUR WIRE IZ NOT ON REMOTE YOU DO HAVE IT TOUCHING A 12V TAKE IT OFF AND PUT IT ON YOUR REMOTE WIRE AND THAT SULD DO IT !
Solution #3
posted on Mar 13, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
hey man sounds like u either have ur constant 12volt touchen ur remote or u hace ur remote hooked up to a constant 12v. if u cant find a remote wire do u have an aftermarket deck?? cuz baby blue wire usually is ur remote
Popular Solutions for Power Acoustik LT-980/2 Car
Questions and Unsolved Problems for Power Acoustik LT-980/2 Car
Do you recommend Power Acoustik LT-980/2 Car Audio Amplifier?
Answer
Answer
looking for manual for power acoustik amp model # LT980-2
Answer
why does the amp make a loud noise and when i tap on the levels it eathes stop or gets worse'' with... (More)
Answer
I have a Boss C650 1000W 4-channel amp. The fuses with the fuse holders all burned! where can I... (More)
Answer
I went in to window and clicked on the sound for email notice but it will not do any thing.
Answer
everything is working fine with the amp all power supplies are good all lights are turning on rca is... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Power Acoustik LT-980/2 Car...:
Top Car Amplifier Experts
Rank: Guru Guru
Solutions: 14935
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Car Amplifier Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
